Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 03-25-2006, 08:02 PM   #1
Norrberrt
Member#: 110021
2003 WRXSTi
Default Clutch / Transmission..Problem..?
hye i have an 03 wrx.. i tried stallin my car in all 5 gears letting the clutch out completely in all 5 gears.. but my car does not shut off.. and if i gave it gas car barely moves.. but does not go anywhere.. and some grindind or rattling noise noise gets louder and when i shift up.. 1st gear low noise.. 2nd litlle louder.. 3rd louder..etc.. any suggestions..
Norrberrt is offline   Reply With Quote
Old 03-26-2006, 11:17 AM   #2
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
What was the car doing when this first started. Normally the car doesn't just "stop working." Were you diving it and it made a noise and then it didn't work? Or is this something that has been getting worse and worse over time?
bluescoobywagon is offline   Reply With Quote
Old 03-26-2006, 12:13 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Sounds like you blew up either the clutch, tranny or a diff.
Old 03-26-2006, 04:31 PM   #4
93 GC8
Member#: 70489
The rattling noise could be coming from your flywheel bearing which is most likely eaten up by your clutch disc therefore ruining the life of your disc.
93 GC8 is offline   Reply With Quote
Old 03-30-2006, 08:19 PM   #5
Norrberrt
Member#: 110021
2003 WRXSTi
well all of my gears go in gear .. and i heard if they dont go into gear.. it could possilbly be the tranny.. but my gears do go in.. but i mean im not sure.. depding on how much gas i gave the noise was there.. at idle there is no rattling at idle it is normal.. only in gear clutch seems to be slippin.. not engaging..
Clutch Pedal/Manual Transmission Problem on 2008 WRX rideqckslvr Transmission (AT/MT) & Driveline 3 04-20-2011 03:38 AM
clutch or transmission problem? mapleWRX Transmission (AT/MT) & Driveline 11 11-25-2009 04:42 PM
Possible clutch/transmission problem fulie Transmission (AT/MT) & Driveline 9 02-17-2009 10:20 PM
93 subaru legacy clutch/transmission problem. piperpilot26 Transmission (AT/MT) & Driveline 2 12-15-2008 07:14 PM
Clutch/Transmission problem maybe? Brupp Transmission (AT/MT) & Driveline 2 07-07-2004 11:51 PM
