Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-25-2006, 11:54 PM   #1
blubaru2002
Member#: 104883
2002 wrx sedan
wrc blue
Default Utec and WOT Knock light
I have Utec and during wide open throttle my cel light flashes. i know this is because my engine is knocking.
My OEM boost gauge says i pull .13 kPa in fifth. i think that is roughly 19psi or more. I think my car can boost higher than this but i let off the throttle early when i realized just how high i was boosting.
My question is do i need to get a protune or can i just turn the boost down with my manual boost controller in order to end the engine knock.
My mbc is completely open.
mod list:
turboxs tbe catless
vibrant header and uppipe
turboxs high performance manual boost controller
turboxs UTEC
spt lightweight crank and alternator pulley
throttle body P&P and bypass mod
P&P tdo4
aem custom shortram
blubaru2002 is offline   Reply With Quote
Old 03-26-2006, 02:03 AM   #2
testes1010
Member#: 47145
2012 Gas Saver
.13 mPa not .13 kPa...big difference...
get rid of the AEM short Ram & turn down the boost until you get a Protune...none of the TurboXS base maps are designed for 19psi...turn it down to ~16psi otherwise you'll soon need a new shortblock... knocking is bad...
testes1010 is offline   Reply With Quote
Old 03-26-2006, 02:22 AM   #3
jackblaha
Member#: 69531
03 WRX Wagon
I agree with taking off the short ram...too much heat under the hood that you are sucking in. I did and it is much happier. Also agree with turning down the boost until you tune; that knock is going to kill your engine over time.
I have similar mods and am running 18.5-19 psi but that is with alky and a bigger TMIC (too be safe)
I forget who made it, but there is a tuning manual for the UTEC out there and you can tune it yourself (get a WBO2 and do a lot of reading first), or get it tuned professionally.
Good luck
jackblaha is offline   Reply With Quote
Old 03-26-2006, 08:07 AM   #4
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
If I were you, I would pull the short ram AND the utec...
No offence, but you obviously don't seem to have an idea as to how to use the utec, or much about the workings of EM. Your current ECU can run the show on its own right now with the mods you have on the car sans the intake. I would let it do it until you can get to a professional..
jigga is offline   Reply With Quote
Old 03-26-2006, 03:15 PM   #5
Gethin
Member#: 2998
and RTFM
Gethin is offline   Reply With Quote
Old 03-26-2006, 04:16 PM   #6
blubaru2002
Member#: 104883
2002 wrx sedan
wrc blue
its true that i do not know how to tune my utec. i never said that i did. please keep comments within the topic of answering the [email protected] question.
i simply wanted to know if i could turn my boost down on my mbc to stop my car from knocking.
while doing the port and polish to my tdo4 a bolt fell out from the exhaust housing where it connects to the up pipe. this was not a part of the turbo.
therefore i had obstruction causing me to never reach my real full boost. this is why i had my mbc open.
i have my utec on a baseline stg 2 map with my mbc wide open. im simply doing mods to my car before getting a protune and dont want to destroy my engine.
so will turning the boost down to 16 psi keep my engine safe until i get a protune?
Old 03-26-2006, 04:31 PM   #7
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
I am keeping comments within the question.... I am only doing you a favour by letting you know. Utec isn't for everyone (or even me for that matter), and can land you in line at your local dealer for a new shortblock if you don't know what you are doing with it. This is why i told you to pull it out. It is easy for other armchair tuners on the forums to give you advice as to what to do, but what you really need is a professional who has experience to check out a log and make a move from there.
You can turn your boost down which is always a safe option.... but you may still have issues with the fueling or timing as well....
Again, I urge you to take the safe route and pull the utec and intake until a professional can tune it and talk you though what you need to do when certain issues arise. Ultimately it is your choice....
Old 03-26-2006, 05:14 PM   #8
Gethin
Member#: 2998
You dont need to learn to tune. You need to learn to RTFM as I said above. The psi targets are all in the UTEC manual for your mods. With your setup dont go above 16.5psi tapering to 12psi at redline.
The basemaps are for 93 octane or better. If you run anything lower you need to remove some timing for starters. The boost map needs to be tuned.
Dont use a MBC unless you know what you are doing. IMHO stick to the TurboXS stages i.e. stock boost solenoid with the ABC plumbed in as per manual instructions. If you deviate from this you'd better make sure you understand what you are doing or bye bye engine.
You have lots of mods there like the shortram, pulleys, headers, P&P turbo which deviates from the TurboXS base map setup, so you need to datalog and gently take it from there. The basemaps are for XYZ mods which you dont have.
The only way for you to know what your car is doing is to datalog using logger #1.
Old 03-26-2006, 06:45 PM   #9
blubaru2002
Member#: 104883
2002 wrx sedan
wrc blue
thanx for the info Gethin... im planning on getting protuned sometime this week. Would it be wise for me to replace the mbc with the ABC that came with the Utec prior to the tune or should i just let the tuner make the call? also is there any advantage to the mbc over the ABC for the tuner?
Old 03-26-2006, 10:44 PM   #10
Gethin
Member#: 2998
keep it simple and as close to the stage 2 setup as you can, until you get it tuned. So IMHO use the stock boost solenoid with the ABC fully closed, hopefully you take it to a decent tuner who can handle the shortram for example. Call your tuner and tell them what you have and see what they say. Maybe they'll want the stock aribox back on for example. Good luck
Stage 1 STi UTEC and knock sensativity Mancini Engine Management & Tuning 14 12-20-2004 03:44 PM
WOT Knock? semabe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-29-2003 01:23 PM
UTEC and knock woes... Black-X Engine Management & Tuning 43 11-15-2003 12:33 PM
Noob UTEC Question Re: Knock and 91Octane Brian Broz Engine Management & Tuning 2 03-01-2003 08:51 PM
UTEC and knock? gossamer_monster Engine Management & Tuning 7 12-20-2002 12:15 PM
