Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Old 03-26-2006, 02:11 AM   #1
drrice
Member#: 82595
let me see ur feetz
Default 2.5L spare yayy options?
mmMmMmM just what people need, a spare free 2.5 block with 1 scorched syl wall.
I was wondering
1st how much can i bore it
2 sleeves
3 shorter crank with longer con.rods so if i did bore AND sleeve it i could have massive disp.
4 any other ideas?
i am thinking of going all nine yards, i want something respectively with 450-500 hp and tons of torque with low boost, alky injection is a possibility too, tons of boost and low spool,
cyl heads are a question too should i just send mine out with multi angles ti, retainers cams and ss valves???
also wheres a reputable shop that can balance undrive/lightweight pullies with a light crank and possible flywheel?
shops links ideas appreciated
drrice is offline   Reply With Quote
Old 03-26-2006, 11:48 AM   #2
ejsportcom
Member#: 88905
shorter crank would equal les displacement if thats what you meant.... but that engine would rev to hell and back.... i like that idea.....
ejsportcom is offline   Reply With Quote
Old 03-26-2006, 01:36 PM   #3
drrice
Member#: 82595
let me see ur feetz
well shorter crank as in longer rods giving more travel so more displacement not in the cylinder walls, but also i guess more centrivical force for the crank for awesome top end
Old 03-26-2006, 08:36 PM   #4
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
No, the rods could be 20' long and you will have the same displacement! Longer stroke crank would give you more CCs. Larger bore will give you more displacement.
Crazykev is offline   Reply With Quote
Old 03-26-2006, 10:54 PM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
longer rods and shorter crank would just make your bottom end easier on itself to rev, if oyu looking for lots of torque with not too much boost, you need a looonnnnggg crank. the stock EJ25 crank is 79 mm, the EJ22, and EJ20 are 75mm, you CAN get a 84mm crank, but of course you would need custom pistons for that. bigger the crank, the less it likes to rev.
~Josh~
Old 03-27-2006, 02:28 AM   #6
N1mxer
Member#: 100987
2002 wrx
blue
if ur really confused u could just give it to me ill figer it out
N1mxer is offline   Reply With Quote
Old 03-27-2006, 12:00 PM   #7
drrice
Member#: 82595
let me see ur feetz
hah im wanting the best of both worlds, would it be a good idea to bore and sleeve? id perfer a high revs over torque. Also a matter of low boost and holding it so ill get external wastegates and an 18 or 20 g. I also just realized the blocks got a small chip, ill try to get a picture up tonight but hopefully comeone can tell me if the block is still useable
edit:also whats the highest revving street subie youve heard of? 2.0,2.5, or higher
and whats the most someones bored out to (litre wise)
Old 03-27-2006, 08:58 PM   #8
readymix
Member#: 59839
2004 WRX
Platinum Silver
What half of hte block is scorched? I have a half scorched block also if you are interested.
readymix is offline   Reply With Quote
Old 03-27-2006, 09:09 PM   #9
drrice
Member#: 82595
let me see ur feetz
oOoOo ill post pics, if im looking at the rear facing me its the left side i believe ill post pics up tonight hopefully, ill pm you
Old 03-29-2006, 02:12 AM   #10
banzai
Member#: 63926
Axis /RAW 2.2 Closed
deck EJ 20G stroker
i have heard of a 2.35L that will twist 10,500 but i can't remember where i saw that.
IIRC, it was a de-stroked 2.5L
banzai is offline   Reply With Quote
2010 Mazda CX-7 gets new 2.5L 4-cylinder option AVANTI R5 Non-Subaru News & Rumors 7 02-13-2009 01:02 PM
2.0L to 2.5L Shortblock Build/ Turbo Options? csmithwrx'05 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 08-08-2008 10:50 AM
Subaru 2.5L Turbo Wins 2008 International Engine of the Year in 2.0L - 2.5L Category Jon [in CT] News & Rumors 19 05-08-2008 03:52 PM
2.5L Motor Options imprezkid Normally Aspirated Powertrain 7 06-26-2007 11:25 AM
Cam options for 2.5L STI/FXT ? bikerboy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 12-03-2004 10:49 AM
