View Poll Results: Do you have A/C in your swap
yes 28 53.85%
no 24 46.15%
Voters: 52. You may not vote on this poll
Old 03-26-2006, 03:45 AM   #1
azn2nr
Member#: 35276
Default ROLL CALL: Who with swaps have kept their ac?
well who has and who hasent.
i for one want to but at the same time, the weight savings are great and re hooking up everything is a hassle.
it just seems as if as it get closer to tearing my legacy apart to put the motor into my impreza im gonna be missing alot of the luxurys.
azn2nr is offline   Reply With Quote
Old 03-26-2006, 04:02 AM   #2
wickedscooby
Member#: 55963
99rs sti v5 LISC #57
eh i drive with the windows down
wickedscooby is offline   Reply With Quote
Old 03-26-2006, 09:33 AM   #3
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
I never had to touch the A/C in my car. I just unbolted the compressor, and moved it out of my way.
subbyspeed is offline   Reply With Quote
Old 03-26-2006, 10:08 AM   #4
OvenMitts
Member#: 46278
96 Impreza
"brighton"
I only use it for its dehumidifier, which is quite often
OvenMitts is offline   Reply With Quote
Old 03-26-2006, 10:18 AM   #5
kheff46
Member#: 66739
2002 WRX wagon
i kept it lines and all. but deleted it after with a different belt. not sure why, but the extra power is noticeable! powersteering is next on the list. hey i got windows, four of 'em. plus i never removed my heatercore from inside the car, just split it from the "airbox" and pushed it to the side and pulled wiring thru w/o removal. saves time, hassle, and works. but a/c is nice to have for defroster and such.
kheff46 is offline   Reply With Quote
Old 03-26-2006, 11:28 AM   #6
Slack
Member#: 17548
I didn't keep A/C because I couldn't afford to buy an A/C pump for it. I have an EZ30R and only the 2005->up a/c pumps will work.
Mick
Slack is offline   Reply With Quote
Old 03-26-2006, 11:41 AM   #7
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
I could have kept it but my TMIC was too big and was hitting the lines, not to mention my compressor was already siezed. So I went insane and stripped it out.
DoctorNick is offline   Reply With Quote
Old 03-26-2006, 06:52 PM   #8
azn2nr
Member#: 35276
hmm poll results arent helping my preswap jitters. anyone else???
Old 03-26-2006, 06:57 PM   #9
maddbmxjumper
Member#: 43044
01 sedona red ej20
stage 3 vf23 rs
its easy, just like subbyspeed said, just unbolt it and tie it off to the side. works fine, kyle
maddbmxjumper is offline   Reply With Quote
Old 03-26-2006, 11:55 PM   #10
83Rabbit
Member#: 5050
EJ18 -> EJ25 - A/C retained.
83Rabbit is offline   Reply With Quote
Old 03-27-2006, 02:15 AM   #11
tweakling
Member#: 33072
'95 EJ20g v1 STI RA
BRP, 2001 GC8 chassis
the radiator that came off my clip was huge, and the guys doing the swap really had to struggle to figure out how to position it around the AC hard lines. they got it in, but the result was that the radiator sat up too high, just enough so that the hood wouldn't quite close all the way. i gradually became more and more annoyed with it and just recently pulled it all out. while it's fairly rare that i actually use it, i'm hoping to buy a beater car with AC soon to get me through those inevitable summer periods of unbearable heat/humidity we have to endure in the mid-atlantic region. i had to commute through Wash DC every day over the summer of 1999 in a Civic with no AC. never again.
-Rob
tweakling is offline   Reply With Quote
Old 03-27-2006, 03:33 AM   #12
moss
Member#: 10197
Kept my A/C.... easy easy. Just swapped 2.5RS compressor over to WRX motor...
moss is offline   Reply With Quote
Old 03-27-2006, 06:15 AM   #13
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
I kept it initially, then the line got plugged and I removed it. Not hard to keep it if you want.
speedyHAM is offline   Reply With Quote
Old 03-27-2006, 10:05 AM   #14
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Slack,
I have an MY05 Legacy AC pump lying around with the hardlines from the pump make me an offer if your interested.
Joshua
And I kept mine simple like everyone said, plus wife would kill me.
yebokmj is offline   Reply With Quote
Old 03-27-2006, 10:40 AM   #15
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
It isn't an option to get rid of AC in Arizona, so my OBS kept it with the EJ205.
AaronB is offline   Reply With Quote
Old 03-27-2006, 12:34 PM   #16
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
the AC does not need to be taken out after doing a swap. It takes a little more wiring, but other then that, its easy to hook it back up and have it function after the swap.
snowman4us is offline   Reply With Quote
Old 03-27-2006, 02:15 PM   #17
jamesfacts
Member#: 51282
98 RS
black & blue from parking
It's all of 2 wires... but yanked mine anyway.
jamesfacts is offline   Reply With Quote
Old 03-27-2006, 04:41 PM   #18
Lachlan
Member#: 19470
1981 Brat GL
If you do RHD swap the A/C tags along very easily
Lachlan is offline   Reply With Quote
Old 03-28-2006, 02:57 PM   #19
RoundtheBend
Member#: 5034
2004 Money Pit
silverish-mud
On my BD legacy --> ver8 STi swap we retained the A/C as I didn't want to run Rim of the World without A/C. I believe we had to use the US compressor though. I can honestly say I never noticed a power difference on stage.
-Erik
RoundtheBend is offline   Reply With Quote
Old 03-28-2006, 03:44 PM   #20
Randoramma
Member#: 60649
00RS EJ205 swap
I think it depends where you are located. Our AC season is ~2-3 months (and even then it might hit 85-90 maybe) out of the year. I yanked mine because of wiring (super tired of DIY wiring by this point), weight, and cleanness. And when I removed my ac, I removed it all, even the under dash portion... Hmm, I should weigh all that stuff?
I did keep it all incase I ever want to re-install it.
Randoramma is offline   Reply With Quote
Old 03-28-2006, 05:18 PM   #21
Chewy
Member#: 5917
95 Impreza Type L
That blueish color
I use the 280 rule 2 windows down at 80mph. I did try driving to an interview doing that in 90+ degree weather before the swap. I turned the ac back on. We'll see how it goes this summer. I rearly use the a/c too. But I kept it a side incase I change my mind and want to install it.
Chewy is offline   Reply With Quote
Old 03-29-2006, 12:02 PM   #22
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
At the Track
AC removed, not needed in the play car....and I needed the weight savings
Scoobyslack1 is offline   Reply With Quote
Old 03-29-2006, 12:29 PM   #23
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I have mine...haha, but primitive...still get's the job done...
if it wasn't soo hot and humid (humid mostly) here, I would have dumped it...
Old 03-29-2006, 01:26 PM   #24
imprezdgc8
Member#: 87265
2007 Legacy Spec B
I didn't keep mine... 2.5rs to ej20g.
It was there but the tensioner for the a/c belt squeaked and it didn't work (no charge??)
I never use a/c as it is so I just ripped it all out.
imprezdgc8 is offline   Reply With Quote
Old 03-29-2006, 01:27 PM   #25
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
I left it, but then a year later removed it. I have another car to drive when it is really hot.
subiekid is offline   Reply With Quote
Roll Call: Post if you DON'T have a Myspace, Facebook, Twitter, or LinkedIn account -=C=- Off-Topic 63 12-02-2009 03:57 PM
OK Who kept their EGT sensor in catless uppipe? batchman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 01-28-2008 10:29 PM
Roll Call: Who else has done the 2.5l conversion? LiquidForce Subaru Conversions 12 04-18-2004 11:07 AM
Roll call: What header & highflow cat are you using, and do you have a CEL too? BongMan Normally Aspirated Powertrain 35 09-16-2002 07:31 PM
