Old 03-26-2006, 12:15 PM   #1
GvilleWRX
Member#: 110491
2004 Stage II WRX
Java Black
Default Can AP revert back after being Protuned?
Hi, I was wondering, if I purchase an Accessport Map from PDX, or if I purchase an accessport that has already been tuned by using PROtuner software at a shop, is it possible for me to revert back to the standard 04 WRX Cobb Maps? Or, once you get protuned is their no turning back?
Thank you
GvilleWRX is offline   Reply With Quote
Old 03-26-2006, 12:29 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
...yeah...provided ya SAVE everything before ya dump the map
Old 03-26-2006, 01:00 PM   #3
GvilleWRX
Member#: 110491
2004 Stage II WRX
Java Black
After its unmarried, would you just use the cobb reporgramAP_04wrx.exe file?
Old 03-26-2006, 04:25 PM   #4
GvilleWRX
Member#: 110491
2004 Stage II WRX
Java Black
Anyone know?
Old 03-27-2006, 09:55 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
Old 03-29-2006, 06:19 PM   #6
Gadiel
UTEC Guru
Member#: 19290
2004 White STI
AEM Factory Trained Tuner
You just need to flash the new base map you want to save on your ecu.
IF your car use a protuned map and then you want to install a Cobb base map you just need to save the base map on your accesport and then flash the map on your ECU.
Gadiel is offline   Reply With Quote
Old 03-29-2006, 07:42 PM   #7
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
I'm not sure what that utility does, but hopefully this will help:
ProTuner creates AP map files in the .ptb (base) or .ptr (realtime) format. It can also create streettuner map files in the .stb or .str format. All of Cobb's off-the-shelf maps are just Protuner map files that you can download and put on your AP any time you want - the only limitation being you can't put streettuner files on a non-streettuner AP and you have to stay within your year/model range.
The AP itself is just a "map file transporting and flashing" device. So if your AP currently holds a Protuned map (such as PDX or any other protuner), all you have to do is use Cobb's Map Manager program to save the PDX or other ProTuned map off the AP onto your computer's harddrive, then put a Cobb Off-The-Shelf map onto your AP. Everybody who gets protuned SHOULD save their mapfile somewhere other than the AP just in case something happens to the AP - you don't want to lose your map forever!
Once you have whatever new map (cobb off the shelf, PDX off the shelf, protuned, whatever) you just put it on your AP with MapManager and then flash it onto your ECU in the normal way. You can always go back to the PDX or other Protuned map whenever you want by the similar process. In fact, you don't have to remove the Protuned map from your AP at all, since there is room for 4 basemaps on it.
nhluhr is offline   Reply With Quote
CEL is back after being turned off BlackFighter Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 01-22-2010 10:47 PM
Newb question about turning off TGV codes after being protuned 5Skware AccessPort 5 01-20-2010 07:33 PM
can utech ecu's be reverted back 2 stock 03 bug eye UTEC 3 03-16-2007 12:18 PM
Help, can't revert back to stock with AP aakrusen Newbies & FAQs 8 07-19-2006 01:03 PM
Cant get BPV on EBAY TMIC. can it rough idle be protuned out? DLBWRXR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-01-2006 12:24 AM
