Welcome to the North American Subaru Impreza Owners Club Thursday October 27, 2016
Old 03-26-2006, 01:31 PM   #1
Member#: 110585
Default Going to stage 2
Ok here is everything I did:
1) went to stage 1
2)installed helix dp
3)from stage 1, i just changed the base map to stage 2 on my AP
is that ok? or is there anything else i need to do? (reset ecu...reverted to stock first before going to stage 2)
borlawrx is offline   Reply With Quote
Old 03-26-2006, 01:44 PM   #2
Member#: 64351
2005 Legacy GT
That should do it. Make sure to disconnect test connectors before you test it out.
Bman is offline   Reply With Quote
Old 03-26-2006, 01:49 PM   #3
Member#: 79394
02 gda
that's fine
23b_Rex is offline   Reply With Quote
Old 03-26-2006, 02:34 PM   #4
Member#: 108539
2004 wrx sedan
Are you using the stock cat back? It would help to use a bigger aftermarket one.
pingpong is offline   Reply With Quote
Old 03-27-2006, 01:51 AM   #5
Member#: 105240
04 Wingless STi
mk2 vr6
Can you just go from stock to stage2 if you already have TBE or do you have to do stage1 first?
Luckie8 is offline   Reply With Quote
Old 03-27-2006, 01:57 AM   #6
Member#: 110231
you can go straight to stage 2 - if you already have a TBE the only difference between stage 1 and stage 2 is the maps themselves.
AaronCPK is offline   Reply With Quote
Should I go to stage 2? SoCal_Scooby AccessPort 3 11-29-2009 11:29 PM
Will going to Stage 2 devalue my 04? mbakercad Mid Atlantic Impreza Club -- MAIC 5 09-15-2009 07:19 AM
About to go to Stage 2 theprodgalson Newbies & FAQs 44 10-15-2008 05:28 PM
Pretty dissapointing time after going to Stage 2 from Stock (STi) homiusang Engine Management & Tuning 22 06-01-2006 08:50 AM
AP Question. Going to Stage 2...when did you reflash you ECU? Edvig Engine Management & Tuning 6 12-27-2005 09:24 PM
