#1 |
Member#: 10197
I installed a FXT rear differential on my 01 RS, figuring I could use the same axles (VLSD, VLSD)...
However, I have a gap on either side... is this normal? ![]() ![]()
#2 |
Member#: 30695
Vehicle:BOOM , Get her to sew THAT! |
Did you give them a good whack to see if the clips on the axle stub haven't seated yet?
#3 |
Member#: 25952
NWIC
Vehicle:1995 Impreza Coupe w/ "Extras" :-) |
It looks like the C-Clips on the end of the axles haven't seated in yet. Tap on the end of the axle with a big rubber mallet to get it seated, or at least see if it's seated.
#4 |
Member#: 10197
axles are still attached to the hubs to that makes for an issue.
keith |
#5 |
Member#: 25952
NWIC
If they're still attatched to the hubs, that's not a big deal. Just undo and remove the big bolt that holds the hub to the lateral links, and then give the hub a good shove. THat should clip the rings in. You might have to loosen the other two lateral link bolts so that they will fall down out of teh way, but after you get that big bolt removed and undone, you've got alot of sliding room.
#6 |
Member#: 13617
Vehicle:2001 Legacy GT back to stock is a project too |
All I did was took a long 2x4, long enough to brace up against the axle and come out the wheel well, then hit it with a rubber mallet.
Popped them right in.Ben |
#7 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
well first of all the fxt is 4.44 and the rs is 4.11 (unless its an auto) -this is bad
+1 for wood +wacking device |
#8 |
Member#: 10197
Took a block of wood and a hammer and whacked it went it..
Its not bad... my new transmission is a 4.44 ![]() |
#9 |
Member#: 177
NWIC
ah the ol wacking device saves he day ...
| Thread Tools | |
| Display Modes | |
| What's Wrong Here? Photos | makofoto | Brakes, Steering & Suspension | 29 | 07-28-2005 11:27 PM |
| What's wrong here?? | tbert | Off-Topic | 6 | 06-23-2004 05:18 PM |
| Can you tell what's wrong here? | catass | Off-Topic | 24 | 06-21-2004 03:39 PM |
| Corvette review in todays' paper. What's wrong here? | SubEd | Off-Topic | 20 | 05-07-2004 03:49 PM |
| Do you know what's wrong here? | booger | Warranty Issues & SOA Problems | 7 | 04-21-2002 03:17 AM |
