Old 03-26-2006, 03:08 PM   #1
BlueDominion
Member#: 73591
Up Back in Boston
Rollin the RSX
Default Wierd thought on diesel
So I know diesel engines have MUCH higher compression ratios than gas engine, and are typically heavier to compensate. Also, they've got a couple other differences (no spark plug, direct injection, etc.) That being said, what do you guys think it would take to convert a gas engine to a diesel engine? Is it even vaguely possible? Probably not worth the effort, but I'm curious and figured it would be an interesting theoretical question.
BlueDominion is offline   Reply With Quote
Old 03-26-2006, 03:35 PM   #2
thahaminator
Member#: 22738
In summary...it will be easier to go buy a diesel!
thahaminator is offline   Reply With Quote
Old 03-26-2006, 04:19 PM   #3
BlueDominion
Member#: 73591
Up Back in Boston
Rollin the RSX
Thank you Captain Obvious. You could tell 90% of the people that do swaps/conversions to just go buy something more similar to what they want (an STi, a different model, etc) but then they wouldn't get to do anything new and different, let alone all they learn in the process.
Old 03-26-2006, 05:40 PM   #4
kheff46
Member#: 66739
2002 WRX wagon
subaru will make a diesel avail soon. its already made in japan avail for sale. they are the last manufacturer that makes boxers to go diesel. about time i guess!
kheff46 is offline   Reply With Quote
Old 03-29-2006, 11:43 AM   #5
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
are you sure about that?
Lat time I checked, Porsche doesn't make any diesels either...
jigga is offline   Reply With Quote
Old 03-29-2006, 12:10 PM   #6
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
Needed to convert:
Fuel system incl: Lines, pump, rail(s) and injectors.
ECU - fuel mapping on a diesel is totally different.
Remove throttle plate
Rework heads to accept direct-injectors and glow plugs and to increase compression, and to change flow characteristics.
Rework piston faces to work with new combustion chamber shape.
Probably heavier rods.
Regrind cams for optimium flow at much lower RPMs.
And then re-gear your transmission to match it to the lower and narrower power band.
O-ring the block to help head gasket handle higher cylinder pressures.
Maybe a different crank to change the rod/stroke ratio of the engine to better utilize the lower piston speeds and greater torque.
Quick list off the top of my head...
Chromer is offline   Reply With Quote
Old 03-29-2006, 01:36 PM   #7
kheff46
Member#: 66739
2002 WRX wagon
they've built them, but dont produce them. and some volkswagons were diesels and porsches, even cylinder castings say so!
it be cool if thats what they used to out torque their uber sweet transmissions during strenght testing!
Old 03-29-2006, 07:40 PM   #8
BlueDominion
Member#: 73591
Up Back in Boston
Rollin the RSX
Originally Posted by Chromer
Needed to convert:
Yeah, a lot of the things on that list have come into my head the past couple days. It would be a really tough project. Neat as all hell, though.
Old 03-30-2006, 02:30 AM   #9
serious
Member#: 22879
Think of the early 80's gm 350 that was a gas then reworked into a diesel; that's where diesels got a bad rap from.
Also, a 2.0-2.5 litter diesel will not have gobs of torque. My 4d55 mitsubishi engine is a 2.3 turbo diesel and only make 135 ft lbs of torque at 3500 rpm. My 6bt cummins makes 400 at around 1500 rpm.
The cummins is a diesel from the start and the mitsu engine is a reworked gaser like some of the early toyota engines.
It WILL be cool to see what subaru can do with a boxer diesel.
serious is offline   Reply With Quote
01 Dodge Ram (5150RAM) goes 1,000hp on diesel and 1,450hp on diesel & nitrous anarchyx Off-Topic 21 07-21-2008 12:18 PM
Something wierd going on with my car ksskateboard Newbies & FAQs 16 08-03-2005 04:04 AM
Wierd thought creeps into my head... 4x4GGG Off-Topic 33 06-29-2004 07:33 PM
Some wierdness showing on oil pressure gauge after 30K service Butt Dyno Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-03-2004 08:15 PM
Wierd bumps on my back under the skin... HalfBaked Off-Topic 17 01-29-2003 08:56 AM
