Old 03-26-2006, 04:50 PM   #1
opious
Member#: 57718
99 Impreza OBS WGN
Silver now w/ 20mm rear!P
Default what clutch/flywheel to use with hybrid 2.2/2.5?
I'm planning on running a 2.5 small block with 2.2 heads and delta cams. I have the 2.2 outback 5 speed transmission. what should i use to mate them? I want to stay very drivable and i'm not looking to spend a lot of money (if any at all), so i preffer stock equipment. Am i going to have to use the 2.5 flywheel and clutch? or can i use my 2.2 clutch and flywheel?
opious is offline   Reply With Quote
Old 03-26-2006, 06:42 PM   #2
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Either the 2.2 or 2.5 should work, as long as they are both from the normally aspirated engines.
I believe the 2.2 and 2.5 are the same clutch now that i think of it.
subbyspeed is offline   Reply With Quote
Old 03-27-2006, 10:52 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
+1 for either .. but if your making more than 165 hp it may very well slip espicaaly if the clutch has any miles on it
Old 03-27-2006, 11:41 AM   #4
opious
Member#: 57718
99 Impreza OBS WGN
i've heard that with this setup and a little help breathing, the engine should make a little over that (i might be missinformed or missread, and please correct me if i'm wrong). can anyone else confirm that the 2.2 and 2.5 share the same clutch/flywheel parts? should i buy a new 2.5 clutch and flywheel or can i get away with just the clutch probably?
Old 03-27-2006, 11:52 AM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Unless you want to upgrade to a lightweight flywheel, there is no reason to change your flywheel, that is assuming it isn't worn out. As for the clutch, get the ACT stage I clutch and pressure plate and you'll be fine...
Old 03-27-2006, 11:57 AM   #6
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
or you can do what i did, and get a ACT STG1 disk, and use the stock Flywheel and Pressure plate.
It works great in my car, but im using a pull type settup.
snowman4us is offline   Reply With Quote
Old 03-27-2006, 03:02 PM   #7
opious
Member#: 57718
99 Impreza OBS WGN
how difficult is it to change the clutch/pressure plate once the engine is out? I've never done it, are there any particular tools/parts i'm going to need?
Old 03-27-2006, 04:35 PM   #8
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Its simple when the engine is out.. It'll be bolted to the back of it. There are six 10 or 12mm bolts that hold the pressure plate on the flywheel. If you get a new aftermarket clutch, it'll come with a tool to help line up the clutch disk. You should also replace the throwout bearing while your in there. That'll still be attached to the transmission input shaft.
Old 03-28-2006, 02:38 AM   #9
opious
Member#: 57718
99 Impreza OBS WGN
Anyone got any info on using this setup with my (push, i believe) setup?
Old 03-28-2006, 03:11 AM   #10
970subaru
Member#: 45703
Ive got the stage 1 exedy($160 on ebay), using my stock 2.2 flywheel. always use the flywheel specific to what clutch setup your trans uses.
970subaru is offline   Reply With Quote
what Acel. cable to use with EJ207? suberdave Pre-2002 Factory Turbo Powertrain 5 01-15-2009 06:28 PM
what legacy cluster to use with 3 wire VSS? elsanto Subaru Conversions 2 08-02-2007 08:47 PM
which clutch to use with 1.8L 5spd and 2.5 engine? 2slofouru Subaru Conversions 12 03-24-2006 08:33 AM
1994 impreza 5spd transmission: Push or Pull type clutch? What flywheel to use?? lotus2843 Transmission (AT/MT) & Driveline 2 01-04-2005 10:04 AM
What rear diff to use with STi Turbo Forester tranny? ImprezaRS dot com Transmission (AT/MT) & Driveline 0 05-30-2003 01:49 AM
