Old 03-26-2006, 08:59 PM   #1
borlawrx
Member#: 110585
Default stage 2 question
Here is what i did from stock:
1) went to stage 1
2) installed a helix dp
3) flashed to stage 2 while stage 1 was still on the ecu
that is fine? no need to reset ecu or anything right?
Also, is can't i just check which stage my ecu is on without plugging it into the car? (under the steering wheel) because when i plugged the adaptor into the wall and picked "view current stage" it showed stage 2
borlawrx is offline   Reply With Quote
Old 03-27-2006, 03:19 PM   #2
moxie
Member#: 89432
2015 Forester XT
You shouldn't need to reset the ECU, it pretty much happens during the base map reflashing process..
And yes, I believe the show current map option should confirm what base mapping you are running.
moxie is offline   Reply With Quote
Old 03-27-2006, 06:21 PM   #3
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Did you flash a real-time map, or a new base map?
If you only did the real-time map, the CEL deletes will not be there.. Only for the base maps.
subbyspeed is offline   Reply With Quote
Old 03-28-2006, 10:38 AM   #4
trbo-4
Member#: 105455
2004 WRX Wagon
Cobb Stg. 2
so you went to stg 2 with only a downpipe? I read that you needed a cat back as well. Also I am about to go to stg 2 and in the instructions for the file it says it is strongly recommended you make it your base map.
trbo-4 is offline   Reply With Quote
Old 03-28-2006, 12:34 PM   #5
CalcVictim
Member#: 57056
2006 Miata
Copper Red
with a catback you will get a little more power, but all you "need" is a downpipe
CalcVictim is offline   Reply With Quote
Old 03-28-2006, 05:54 PM   #6
superrooo
Member#: 111077
02 wrx wagon
black
the ap remembers the last map flashed. it will show w/o pluging it in.
superrooo is offline   Reply With Quote
2 stage 2 questions shoefean AccessPort 1 02-08-2008 06:21 PM
Bushur racing stage 1/cobb stage 2 questions boostdog Newbies & FAQs 9 06-07-2007 03:45 PM
AccessPort Stage 1 to Stage 2 question... UltimateLurker Engine Management & Tuning 7 07-03-2005 04:48 PM
TXS stage 2 questions andygold Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-01-2002 10:39 AM
Just installed TXS stage 2 - questions/concerns/comments ezatnova Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-19-2002 03:13 PM
