Go Back   NASIOC > NASIOC Classifieds > Private 'Wanted' Classifieds
Old 03-27-2006, 10:47 AM   #1
k_thaosta
Member Sales Rating: (5)
Member#: 20583
Default Cometic Gasket for hybrid swap
I'm doing a hybrid swap 2.0 to 2.5L sti block and I need the gaskets.. Anyone have some or make them? I'm not sure of the thickness but if anyone knows and can help.. Thanks for looking
k_thaosta is offline   Reply With Quote
Old 03-27-2006, 05:21 PM   #2
k_thaosta
Member#: 20583
bump!
Old 03-27-2006, 06:07 PM   #3
sjl1614
Member Sales Rating: (28)
Member#: 56791
06 OBS
you can call cometic directly and they will make any gasket you want.....they did for me
sjl1614 is offline   Reply With Quote
Old 03-28-2006, 07:51 AM   #4
k_thaosta
Member#: 20583
what's their number and what's the pricing?
Old 03-28-2006, 08:28 AM   #5
Pacobeagle
Member Sales Rating: (7)
Member#: 8775
2010 "Zed" 1000
Orange/White
Sti block and WRX heads? Use .051" thick COMETIC head gaskets for a 8.5:1 CR. If you use the OEM Sti gaskets you'll get a 9.17:1 CR. Also, you can use the RS head gasket and get something like 8.8:1. The last one I'm not 100% sure.
With the OEM gaskets you will have to watch boost/timing as your CR will take the place of the higher boost levels. I was running abour 18-19psi on my VF22(stock pistons)
With the .051" Cometics I can run up to 22 psi as my CR is lower now. I had to retune the map completely.
Jose
Japtrix.com
Pacobeagle is offline   Reply With Quote
Old 03-28-2006, 11:05 AM   #6
richy_21
Member Sales Rating: (201)
Member#: 58670
2005 got muuuuu?
hasnt there been issues with cometic gaskets though?
richy_21 is offline   Reply With Quote
Old 03-28-2006, 11:16 AM   #7
White 2.5rs
Member Sales Rating: (15)
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
there have been issues with everything
install them properly
Old 03-28-2006, 11:22 AM   #8
sonic rx
Member Sales Rating: (11)
Member#: 33457
Chapter/Region: PRSIC
HAHA EVERYONE KNOWS
DYNO JET IS NOT REAL WHP
use the stock head gaskets. that is what i am using. you will make more power with less timimg ,and less boost. that all equals better and safer power.my tuner perfers the stockers over the cometic. they also throw you timing off a bit.i have 2 extra sets of new head gaskets also i will sell ya a set.
sonic rx is offline   Reply With Quote
Old 03-28-2006, 11:49 AM   #9
richy_21
Member#: 58670
2005 got muuuuu?
^ thats actually what i was told.
which gaskets for hybrid? Kaldar142 Built Motor Discussion 15 10-22-2008 01:15 AM
Need gaskets for hybrid. perrin247 Built Motor Discussion 11 10-18-2007 11:53 PM
RS SOHC vs RS DOHC for hybrid swap Spilner Normally Aspirated with bolt-on Forced Induction Powertrain 25 08-15-2007 11:25 PM
Additional Necessary "Fiddly-Bits" for Hybrid Swap? mokujin22 Built Motor Discussion 7 06-28-2006 10:13 AM
tuning help for hybrid swap into 03 wrx??? werkInProgress Engine Management & Tuning 2 09-17-2005 04:36 AM
