Old 09-30-2001, 08:58 PM   #1
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
Default Is there supposed to be a washer w/ Drain plug?
Hello all, just changed my oil today for the 1st time. WOOOHOOO! Was funny cuz the oil spilled so fast it just spilled and gave my hand a wash of 0W, lucky 0W hehe. So is there a washer thats supposed to be with the drain plug? I might of lost it if there is.
STi-Nismo Dood is offline   Reply With Quote
Old 09-30-2001, 09:14 PM   #2
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
yeah, there is. but if you can't find it...you can get one from the dealership...they're cheap
JGard is offline   Reply With Quote
Old 09-30-2001, 09:25 PM   #3
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
AHHH, Dealership is too far from my place... uhmm what if I goto home depot? I mean, if I have the spec. for the washer, I should be able to get it from there right? I only know that my plug is 17mm... how do I calulate that to formulate the washer equation? hehe Need height for washer too...
Old 09-30-2001, 11:27 PM   #4
lgkahn
Member#: 9793
2002 2010 legacy gt
red
they are special crush washers if you cannota goto dealer order them from www.subaruparts.com
part number is
subaru oil filter 15208AA024
crush washer 11126AA000
lgkahn is offline   Reply With Quote
Old 09-30-2001, 11:41 PM   #5
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
On my drain pulg the washer was so stuck on there I had to use a razor blade to separate it.
djerickd is offline   Reply With Quote
Old 10-01-2001, 12:04 AM   #6
twintwooorbo911
Member#: 8947
Hmmm..... are you guys sure that the oil plug comes with a washer on our WRX?? I've changed my own oil too my self for the first time on my WRX like two weeks ago, but I didn't see any washer. I tried to look everywhere just incase I thought I might have dropped it somewhere, but I didn't find one. I even drained out the bucket full of old oil to see if it had dropped in there but nothing turned out.
I've screwed the oil plug back in without any washer assuming that it didn't have one, but do I need one?? I've been checking under the car every single day to see if I am getting any leaks but there isn't any leaks and everything seems to be good.
I am just curious because I thought I was the only one thinking that it didn't come with a washer.
Are you guys 100% sure that our WRX comes with a washer??
twintwooorbo911 is offline   Reply With Quote
Old 10-01-2001, 09:33 AM   #7
Austin
Member#: 7089
2016 STi
Yes.
But if you put just the plug on w/o a washer and you have no leaks, then you're okay. Maybe get one for next time.
Austin is offline   Reply With Quote
Old 10-01-2001, 12:07 PM   #8
mykrrrr
Member#: 733
'16 Fiesta ST
Platinum white metallic
Arrow
I never had a washer on my RS and I do my oil every time. I guess I should get some just to be safe but I'm gonna go with that valve drain plug thingey next time...
-myk
mykrrrr is offline   Reply With Quote
Old 10-01-2001, 01:52 PM   #9
WeRX
Member#: 3652
1989 Honda Pirate
Type RRRRRR
The washer will probably be stuck on the drain plug. It is hard to see it on the drain plug but it's on there. Like djerickd said, you'll probably need to use a tool to remove it. Just go to the dealership and buy a bunch of them. I bought 10 for like $7 or something.
WeRX is offline   Reply With Quote
Old 10-01-2001, 02:31 PM   #10
Poseidon
Member#: 4864
2004 WRX
Yeah, the first time you change the oil, you'll probably have a hard time spotting the crush washer. It is usually painted over and looks like part of the drain plug. If you look closely, though, you'll see that there is a raised edge between the threaded part and the outside edge of the head. I just used a small flathead screwdriver to pry it off. A little less dangerous than a razor blade.
The crush washers are special because they are double-layered with a curve in the top part that is meant to be compressed when you tighten the drain plug. It allows a much better seal than you could get otherwise. You may not have any problems if you don't use one, but it is always better to be safe than sorry.
Jordan
Poseidon is offline   Reply With Quote
Old 10-01-2001, 02:43 PM   #11
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
Thumbs up FUMOTOVALVE
www.fumotovalve.com
you'll never need a crush washer (or wrench) to do an oil change again.
Stanley is offline   Reply With Quote
is there supposed to be play in the power steering pump pulley? japspecjohn Brakes, Steering & Suspension 7 12-02-2009 02:47 PM
what is the Test mode connector for and is it supposed to be plugged in together? CCTXRS Electrical & Lighting 2 10-24-2007 06:11 AM
Um... Is that supposed to be there? Nanners Canada Region Forum 12 06-27-2005 06:46 PM
Is there supposed to be a hole through the cat material in the stock uppipe? atf78 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-07-2002 06:28 PM
Is there supposed to be an underpan????? samurai General Forum Archive 1 05-19-2000 12:30 PM
