Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 03-27-2006, 07:11 PM   #1
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Default STU guys check in. Set ups
What is everyone running.
1. Engine
2. Exhaust
3. Suspension
4. Alignment
5. Tires
I'll start it off.
1. Engine: Stock
2. Exhaust: Scooby Sport shorty DP wrapped. Prodrive axleback.
3. Suspension: Tein Flex 10k/8k set to 1 front, 5 rear. Strano 32mm FSB
4. Alignment: Front Max neg camber on tein tops. 0 toe front and rear. -1.5 camber rear (planning on changing toe soon and experimenting with more neg camber in the rear.)
5. Tires: RE070 225/45 17 40 psi front, 38 psi rear(Azenis RT-615- 245/45 17 on order)
silver arrow is offline   Reply With Quote
Old 03-28-2006, 08:10 AM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
04 sti
1. Stock engine
2. Stromung DP
3. Zeal V6's 10F/8R, Whiteline 27/29 Front bar, Whiteline 22 rear
4. -3.0 F 0 toe, -1.5 R 0 toe
5. 245 45 17 Falken Azenis RT615's.
How about brakes as 6
6. Bobcat pads (changing to HP+ soon as bobcats are dead), goodridge lines, Motul 600
Old 03-28-2006, 09:51 AM   #3
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
05 STi
1. Stock Engine (APS Intake, GPMoto MAF Tube)
2. RFL Axleback
3. Zeal V6's 10f/8r, Cusco 22mm Rear, Replicat Strut Bars
4. -2.5F 0 Toe, -1.0R 0 toe
5. 225/45 RE070's
Being added soon:
Cobb DP, Hotchkis F/R sway bar kit (25.5mm), Pagid pads, braided lines, Motul, better tires (RT-615) as soon as the RE070's die and driving school
Car vs. Driver is offline   Reply With Quote
Old 03-28-2006, 10:12 AM   #4
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
I play in BSP
crystalhelix is offline   Reply With Quote
Old 03-28-2006, 10:15 AM   #5
maxQ
Member#: 2446
'11 Alfa Cloverleaf
grise
04 STi
1. typhoon intake
2. DP (Perrin?), custom 3" titanium exhaust
3. K&W DA coilovers, Strano FSB
4. -2.5 +.25" toe, -1ish 0 toe.
5. 245/40-17 Kumho MXs on 17x8.5s
maxQ is offline   Reply With Quote
Old 03-28-2006, 02:56 PM   #6
rkevans
Member#: 44204
2004 Impreza WRX STi
04 STi
1. Stock engine
2. Apex'i axleback
3. Strano FSB, Whiteline 22mm RSB, WL Steering rack bushings
4. I have no idea. Max front neg camber on stock bolts.
If I could change something:
Less front camber... I'd like to try Azenis next... Pink springs (or similar).
Results: No trophies at Ft. Myers Tour. My co-driver 'could have' finished at the bottom of the trophies with his raw times, but had a lot of dirty runs. He's been auto-xing a Miata for the last two years -- hit all the cones with the right side of the car... The car drove pretty well, I didn't.
Rick
rkevans is offline   Reply With Quote
Old 03-28-2006, 03:29 PM   #7
tuskenraider
Member#: 65699
15 WRX
WR Blue
Why is that? You probably have around -1.0 of camber with the stock bolts and -2.5-3.0 is what has been determined to be optimal for the Impreza platform by competitive autox'ers.
tuskenraider is offline   Reply With Quote
Old 03-28-2006, 03:45 PM   #8
rkevans
Member#: 44204
Uh, yes. -2.5 is LESS than -1.0. I just feel weird saying "more negative" camber. Oh, you're reading it as "Closer to Zero camber". Hmmm. I can see that point of view. How about more anti-positive. no.
I'd prefer the tops of my front tires to be closer to the inner fenders than they are now.
Rick
Old 03-28-2006, 04:28 PM   #9
Scoobie Doogie
Member#: 9805
2009 Bimmah 135 eye
Silvuh
I'm driving Got Pink's car:
K&N intake, Stone Racing equal length headers w Swaintech ceramic coating. Accessport with STU map not installed yet.
Vishnu Turbo-back w 1 high flow cat
KW V3 Coilovers with 450lb front springs and progressive crap in the rear, strano FSB, mod'd Cusco camber plates with +6.5 deg caster, -2.2 neg camber (needs more), stock STi rear tophats (will be Cusco camber plates shortly).
245/45R17 on stock STi wheels (will be 245/45R17 RT615 Azenis on Volk 17x9 wheels soon)
Need to finalize the springs/corner-balance/install accessport/brake pads & fluid/ alignment.
Dave Mac
Scoobie Doogie is offline   Reply With Quote
Old 03-28-2006, 05:08 PM   #10
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Originally Posted by maxQ
04 STi
1. typhoon intake
I thought we are limited to 8.0 inch wide wheels?
Old 03-28-2006, 05:10 PM   #11
BlkWRXWag
Member#: 31821
2015 DS WRX
That's STX, not STU. 245 tire width is consistent for both though.
BlkWRXWag is offline   Reply With Quote
Old 03-28-2006, 05:19 PM   #12
rkevans
Member#: 44204
I thought the same thing -- and I was wrong.
http://www.scca.com/_FileLibrary/Fil...talclasses.pdf
Rick
Old 03-28-2006, 05:24 PM   #13
jamesohoh7
Member#: 39070
GTF off my lawn!
Ha!.. 'setup'!? ... my setup is crap:
stock except for:
cat-back
Hotchkiss sways f/r
RT615's (245/45/17) on 17x8 Torques.
I know, I know... 'pretty much worthless' , but I'm working on it! I was waffling between running AS or STU this year, so I didn't do much (yeah, rear sway would have had to come off, easy).
The waffle landed syrup side down, so I went STU
jamesohoh7 is offline   Reply With Quote
Old 03-28-2006, 05:33 PM   #14
BlkWRXWag
Member#: 31821
2015 DS WRX
1. Stock
2. Cobb TBE with high-flo
3. Cusco Zero 2R with camber plates redrilled at 40 deg. for camber/castor, Strano FSB, Cobb RSB with Cobb adjustable billet mounts.
4. -3.0 - 1/16 toe out /-1.3 - zero toe
5. Falken 615 245/45/17 on OEM rims (on order, 5Zigen FN01R-C 17x9 with Yoko Neova 245/40/17).
Old 03-28-2006, 07:50 PM   #15
Orion
Got the F out
Member#: 4797
01 01 RS, 95 L
Aegean Blue
1. Stock
2. Stock
3. Koni OTS yellows on with stock everything else
4. Whatever I can get out of it in stock form, but then again I don't have the issues that struts do.
5. Azenis RT615 255/40-17 on Enkei RP2 17x8 et38
If there were someone locally running BS I'd be there with the same setup except for 245/35-18 V710's on OEM wheels
I retired the Subie from AutoX only to graduate it to RallyX.
Orion is offline   Reply With Quote
Old 03-28-2006, 09:45 PM   #16
Got Pink?
Member#: 72609
2005 STi
World Rally Blue
Dave Mac
You forgot the light crank pulley and recaro pole positions.
Anybody actually test different spring rates yet?
And I agree with Dave that we need more camber for sure.
Got Pink? is offline   Reply With Quote
Old 03-29-2006, 03:36 AM   #17
z3coupe
Member#: 13540
2006 MKV GTI
Gee Max, I thought Mako and Jeff kept saying the 615's were the tire to get Of course, now almost all the //M3 guys in our region are on those now - just much larger than ours
Will be interested in seeing how the KW V3's will stack up against the other brands . . . . . . Just for me, until I find a job future, all activities are on hold.
z3coupe is offline   Reply With Quote
Old 03-29-2006, 10:00 AM   #18
AtomicRacer
Member#: 84586
1995 Frankenpreza
2012 Tundra DC 5.7L
Changed for 2007
AtomicRacer is offline   Reply With Quote
Old 03-29-2006, 10:20 AM   #19
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
Originally Posted by AtomicRacer
Cobb AccessPort w/custom tune (PDX Tuning) (298hp/299tq on Mustang
Nice ... how'd you manage that much power on stock boost? That's about as much as a typical "off the shelf" stage 2 map.
Old 03-29-2006, 10:27 AM   #20
AtomicRacer
Member#: 84586
1995 Frankenpreza
2012 Tundra DC 5.7L
The dyno reads high and Jarrad and Tim from PDX have mad tuning skills.
-Paul
Old 03-29-2006, 09:33 PM   #21
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Lets keep the STU setups coming. Where are you guys on ride height? What is the standard measure? I believe center hub to fender.
Old 03-29-2006, 09:56 PM   #22
Car vs. Driver
Member#: 81620
2004 350Z
406WHP/350WTQ
I'm was at about 13.5" (hub to fender) all around, then I got corner balanced ... I haven't measured it since.
Old 04-01-2006, 10:30 PM   #23
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Their has to be more STU guys out there. Come on guys.
Old 04-01-2006, 11:12 PM   #24
crystalhelix
Member#: 35313
Spry Forester
Silver Spark
"There"
Old 04-02-2006, 12:42 AM   #25
AndrewSS
Member#: 51674
2005 Subaru WRX STi
WRB/GOLD
Well, I plan to make the switch before the first points event this season... I am not very prepped... but the driver is evolving, gotta learn!
1. Engine: Stock
2. Exhaust: Borla XR-1 catback
3. Suspension: Strano FSB
4. Alignment: -1.0 front camber, oem rear setting, zero toe all around
5. Tires: Yokohama advan A046 (oem evo tires)
plans... maybe cusco or pde camber plates, maybe a 22-24mm rsb, and maybe a catted DP - we will see what actually gets done.
AndrewSS is offline   Reply With Quote
Air Force Guys Check-in (other branches welcome) joosrsx Off-Topic 293 05-01-2010 10:36 PM
northwest connecticut guys check in 09wrxtorrington New England Impreza Club Forum -- NESIC 6 08-12-2009 02:46 PM
New Guy Checking In mmormino Newbies & FAQs 3 02-14-2009 12:07 PM
New guy checking in amfj231 Newbies & FAQs 7 12-22-2008 09:13 PM
