Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 01-06-2013, 02:03 PM   #2576
yazel
Member#: 215344
I honestly would wait for a 2014 if I wanted an STi as well. It is worth it when you will probably have details and be able to order one early next Fall if not maybe slightly before.
yazel is offline   Reply With Quote
Old 01-07-2013, 12:40 PM   #2577
my name is joe
Member#: 171412
Hey guys are spherical end links stu legal? Because I've seen some guys run it and get no trouble, I don't want to run it in nationals and some guy says I'm in the wrong class or I'm cheating.
my name is joe is offline   Reply With Quote
Old 01-07-2013, 12:51 PM   #2578
yazel
Member#: 215344
13.7 ANTI-ROLL (SWAY) BARS
A. Substitution, addition, or removal of a single anti-roll bar and supporting
hardware (brackets, endlinks, bushings, etc.) is permitted. The
use of any bushing material is permitted. A bushing may be implemented
as a bearing.
B. Substitution, addition, or removal of anti-roll bars may serve no other
purpose than that of an anti-roll bar.
C. No modification to the body, frame, or other components to accommodate
anti-roll bar addition or substitution is allowed except for the
drilling of holes for mounting bolts. Non-standard lateral members
which connect between the brackets for the bar are not permitted.
Any type of endlinks should be perfectly legal especially since it is legal in stock class for the one sway bar of choice there.
Old 01-08-2013, 02:26 PM   #2579
Illini_STi
Member#: 70634
Originally Posted by Luke31 View Post
Sooo, I'm scrolling through the STU rulebook looking for ways to go moar faster. I want to put a turbo inlet on, but the rules seem a little unclear. Anyone clarify this for me before I go spend 250 bucks on a part I can't use?
"The air intake system up to, but not including, the engine inlet may be modified or replaced. The engine inlet is the throttle body, carburetor, compressor inlet, or intake manifold, whichever comes first."
Am I correct in assuming the "turbo inlet" is in this case the "compressor inlet" as described by the above rules? I know this may seem like a dumb question, but I want to be sure about it.
Be careful. Many turbo inlets are themselves legal, but the install requires making an illegal modification. I'm pretty sure that the APS does this IIRC.
Illini_STi is offline   Reply With Quote
Old 01-08-2013, 08:44 PM   #2580
bdi
Member#: 66033
05 STi
^^True indeed. I believe all hoses must still connect to the turbo inlet and cannot be combined. Basically meaning you must use a turbo inlet that has the same amount of spigots that are on the stock one. I believe the only turbo inlets that do this are the Samco and new Perrin design.
bdi is offline   Reply With Quote
Old 01-08-2013, 08:59 PM   #2581
Luke31
Member#: 274111
2013 WRX STi
Dark Grey Mettallic
Please explain. I'm not sure what modification you're talking about. I'm talking about replacing the piece of pipe directly after your intake pipe that connects to the air filter/airbox.
Luke31 is offline   Reply With Quote
Old 01-08-2013, 09:00 PM   #2582
abrumlev
Member#: 197920
2005 Legacy GT
ABP
If someone wants to contest you for doing something like tee-ing up some vaccuum/pcv lines, send them to me and I'll have a word with them. That **** is ridiculous. I would never ever know to look for something like that let alone give someone **** for it.
abrumlev is offline   Reply With Quote
Old 01-08-2013, 09:23 PM   #2583
yazel
Member#: 215344
No crap. I'd have to do a little bit of But it never hurts to make sure you are completely legal to avoid a lame ass situation like that. I think most of us in STU are stand up/good guys and wouldn't intentionally cheat or do something crazy that would require a contest, at least the guys I know.
What bdi posted is what Illini meant.
Old 01-08-2013, 09:41 PM   #2584
Luke31
Member#: 274111
2013 WRX STi
Dark Grey Mettallic
Kool, I just wasn't sure.
Old 01-08-2013, 10:06 PM   #2585
yazel
Member#: 215344
It shouldn't be a big problem. The Perrin inlet is a nice piece and should be completely legal. I'd suggest it for its ease of install over other brands as well (this is only from what I have been told).
Old 01-08-2013, 10:14 PM   #2586
Luke31
Member#: 274111
2013 WRX STi
Dark Grey Mettallic
That's the one I was looking at, but still on the fence about an inlet. Has anyone seen a back to back dyno chart with an inlet vs. stock?
Old 01-08-2013, 10:33 PM   #2587
KA-T_240
Member#: 188402
05 STI
CGM
Originally Posted by Monkey31 View Post
Looking to order June/July...but now I may try to hold out for a 2014 w/a new engine to avoid these issues. It may be a gamble, but hell...it's a gamble on blowing a ringland now.
To argue your topic, there is no information if the 2014 will be a new engine, or if it will be the same. I'd imagine if there was major changes for the 2014 year, it would likely be out in the next month.
Also, if you are wanting to play in STU, you should basically plan on your warranty going right out the window, so just buy what you like the best.
KA-T_240 is offline   Reply With Quote
Old 01-08-2013, 11:42 PM   #2588
bdi
Member#: 66033
05 STi
It makes power...period! Its been dyno proven that a turbo inlet reduces spool time by 250-400rpm. I believe Perrin has dyno curves on their site. Check for Josh's build page aswell he posted some dyno curves for his car STU car.
Old 01-09-2013, 12:02 AM   #2589
yazel
Member#: 215344
That is pretty significant. Interesting.
Old 01-09-2013, 12:30 PM   #2590
Illini_STi
Member#: 70634
I totally agree that it would be a weenie protest. But reference this:
http://www.airpowersystems.com/wrx/i...01_install.pdf
In that procedure they modify the fuel lines and hoses as well. Technically not STU legal.
*Rant On*
Not to derail the thread, but I think that at the National level, yes everyone respects the rules. Locally, I have my suspicions, and those suspicions are shared by a number of people. But if somebody needs to cheat to get a $5 chit or ugly regional championship jacket, I can only pity that person. The problem is that it is basically impossible to police that stuff at a local level. Who is going to pay to tear down a motor? We can't check for electronically altered boost at nats, how can a region do it? Sorry. *Rant Off*
Old 01-09-2013, 01:10 PM   #2591
yazel
Member#: 215344
I worry about it least at the local level due to the fact that even if someone is cheating they are most likely a n00b or simply not competitive in the first place. But I see where you are coming from. I maybe don't take it as seriously as some other people even though I do enjoy to win and be competitive in a fairly humble manner.
Old 01-15-2013, 12:26 AM   #2592
penderperson
Member#: 172370
2006 STI
Why doesn't anyone have an 07 STI? I remember seeing the 06 was the ticket, but don't remember why...
Edit: Found it randomly, Torsen LSD...
penderperson is offline   Reply With Quote
Old 01-18-2013, 01:34 AM   #2593
Thorium06
Member#: 254372
And weight
Thorium06 is offline   Reply With Quote
Old 01-18-2013, 02:46 PM   #2594
Atomic Rooster
Member#: 204224
2010 STI
Obsidian Black Pearl
Has anyone tried out the Dunlop ZII on their STU car yet?
Tire Rack claims "one potential weakness of the Z1 Star Spec, where the rear can get out of phase with the front, resulting in some transitional oversteer if not driven smoothly". TR says the ZII is better.
I've noticed my car gets super twitchy on decreasing length slaloms. Can anyone confirm if the ZII improves this on an STU car?
Atomic Rooster is offline   Reply With Quote
Old 01-18-2013, 09:49 PM   #2595
abrumlev
Member#: 197920
2005 Legacy GT
ABP
I don't think they've even shipped the first batch yet.
Old 01-18-2013, 09:51 PM   #2596
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
As abrumlev says, the 245's aren't out yet.
But a car being twitchy in decreasing length slaloms sounds pretty normal to me. I don't think that's a tire problem.
Old 01-18-2013, 10:48 PM   #2597
bdi
Member#: 66033
05 STi
Rumor has it that the 245 size wont be available until march. 255's are out now...
Old 01-19-2013, 03:13 AM   #2598
yazel
Member#: 215344
They definitely won't be in until March, TireRack has it posted on their website.
Old 01-19-2013, 01:33 PM   #2599
Boxologist
Member#: 21118
I wouldn't even worry about it at the National level if all the vacuum lines, even after being tee'd together ended back into the intake system.
1. Pay $50 bucks
2. Protest uphead
3. No performance benefit found, 0.0 second penalty given.
Boxologist is online now   Reply With Quote
Old 01-22-2013, 08:44 AM   #2600
bassicfun
Member#: 234424
2006 Evolution RS
Red
Had my zIIs preordered last month, agreed don't expect to see any til mid march.
Twitchy in decreasing length slalom = can be tamed with driving style and/or left foot braking. IMHO.
bassicfun is offline   Reply With Quote
Air Force Guys Check-in (other branches welcome) joosrsx Off-Topic 293 05-01-2010 10:36 PM
northwest connecticut guys check in 09wrxtorrington New England Impreza Club Forum -- NESIC 6 08-12-2009 02:46 PM
New Guy Checking In mmormino Newbies & FAQs 3 02-14-2009 12:07 PM
New guy checking in amfj231 Newbies & FAQs 7 12-22-2008 09:13 PM
