Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 01-29-2013, 08:14 PM   #2626
rapid butterfly
Member#: 342951
2004 WRX STi (STUL3)
Java Black
Thanks. I'd been thinking maybe 42 36.....wasn't able to get as much negative camber as I'd hoped.
I will search, but anyone know off the top of their heads whether there are camber plates for cars using stock strut housings (considering feal revalves).
rapid butterfly is offline   Reply With Quote
Old 01-29-2013, 09:51 PM   #2627
yazel
Member#: 215344
There are lots of plates that work with stock strut housings. I personally used to run the RCE plates on my D-Specs struts and never had any problems. There are quite a few others that can work as well.
yazel is offline   Reply With Quote
Old 01-31-2013, 02:16 PM   #2628
rapid butterfly
Member#: 342951
Java Black
I see the vorshlags are out for oem strut housings (per vorshlag). But looks like TIC might have something...
Old 02-13-2013, 12:34 PM   #2629
yazel
Member#: 215344
I am sure TiC has something if you haven't found anything yet. Give them a call/e-mail. I'd honestly try to find a used set of RCE non-lowering or lowering camber plates. They don't raise the car any.
Old 02-20-2013, 11:43 PM   #2630
CircuitRacer
Member#: 308527
2004 WRX STI
I was reading the rule book and I havent seen anybody talking about this here but am I the only one that noticed that we went from a 9 in wide rim to unlimited? If so anybody changing their wheel setups now?
CircuitRacer is offline   Reply With Quote
Old 02-21-2013, 12:45 AM   #2631
yazel
Member#: 215344
We have had unlimited for a long time. I believe lots of guys have ranged anywhere from 9" up to 10" wide for many years now. My 17x9.5" have already been ordered to take advantage of this allowance for this year
Old 02-21-2013, 06:14 AM   #2632
CircuitRacer
Member#: 308527
2004 WRX STI
Wow my mistake, could of sworn that we were limited to a 9" wheel lol. yazel, what rims are you running. Trying to decide between Enkei RPF1 in 17x8.5 or see if it's worth it to do 17x9.5.
Old 02-21-2013, 07:09 AM   #2633
em99sport
Member#: 172670
2011 STI 5-door
Go with the 9.5s. They're worth it.
em99sport is offline   Reply With Quote
Old 02-21-2013, 07:23 AM   #2634
CircuitRacer
Member#: 308527
2004 WRX STI
Stumbled upon yazel's group buy. From what I've seen aside from rolliing the fenders and 5mm spacers up front and recommending extended wheel studs, it should fit rather nicely under an '04 STi's wheel wells.
Old 02-21-2013, 08:32 AM   #2635
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
don't forget stiff suspension and camber as well.
T3hClap.com how to fit 9.5s on a GD
WRX8XB is offline   Reply With Quote
Old 02-21-2013, 08:40 AM   #2636
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
9.5's in the rear will require extra effort on alignment and coilover clearance to be right and avoid rubbing/sidewall damage. I've tried 9.5 +45's, and I just couldn't get them to fit the way I wanted
AustinTX is offline   Reply With Quote
Old 02-21-2013, 08:48 AM   #2637
abrumlev
Member#: 197920
2005 Legacy GT
ABP
Yazel and myself are registered for the Wilimington Match Tour in early April....anyone else going? The class is a whopping 4 of us right now.
abrumlev is offline   Reply With Quote
Old 02-21-2013, 08:50 AM   #2638
WRX8XB
Member#: 45323
Generally on the 04 you need a 38 or lower rear offset to avoid coilover clearance issues.
on the 05-07 I've seen people get away with a +45mm 9.5" wheel with 265s with the camber bolt/plate trick (which is against STU rules IIRC).
Old 02-21-2013, 09:24 AM   #2639
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
+45 seemed like the best balance of offset, but I had major rubbing on the outside and minor on the coilover spring/perch. 9's work fine for me.
Old 02-21-2013, 09:25 AM   #2640
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
If I had to try again, I'd go with shorter rear springs to move the perches up and try to find a +50 or so 9.5 wheel. I'm glad we are limited to 245's, or I'd have to switch to another class
Old 02-21-2013, 09:40 AM   #2641
piknockout
Member#: 192173
2006 STU prepped STi
Sponsored by Agile Auto
My Enkei RPF1's are 9.5" et45 with roughly -1.8 to -2.0 rear camber using camber plates up top and the T2's are slotted. I do have some slight rubbing in the rear, but it's very minimal and not an issue.
piknockout is offline   Reply With Quote
Old 02-21-2013, 09:56 AM   #2642
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
That may be my concern. I like less camber in the rear. I'm around -1.2.
Old 02-21-2013, 10:09 AM   #2643
piknockout
Member#: 192173
I can see where that could be an issue for you then. Are you running a softer bar in the rear then to keep oversteer under control? I'm running a Whiteline 22mm bar on full soft. Rotation is very controllable. Just curious why such low rear camber.
Old 02-21-2013, 10:18 AM   #2644
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
I'm running the huge 29mm rear bar. I like less rear camber to avoid diffing out as much on corner exit. I do not recognize oversteer as a problem on these cars.
Old 02-21-2013, 10:56 AM   #2645
piknockout
Member#: 192173
So essentially more rear grip for acceleration purposes when on throttle at corner exit, if I'm reading that right? I've thought about doing something like that, but I kind of enjoy the rear coming out the way it does, helps me point the car better in a lot of situations...but maybe that's why I'm always ending up behind you at Nats? Well, one of the many reasons at least.
Old 02-21-2013, 11:15 AM   #2646
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
I don't know if what I'm doing is best, but it drives well enough and my tire wear is very good. I've tried Rob's car once, and it was better in some ways and worse in others. In general, I don't really pay much attention to handling issues as long as I can drive around them. My shocks are still set full soft on all 8 knobs...
Old 02-21-2013, 11:35 AM   #2647
piknockout
Member#: 192173
Just imagine what you could do if you actually tried.
I don't really tweak my alignment settings at all, usually just play with shocks/tire pressures to suit conditions. And even then, I don't entirely know what I'm doing.
Old 02-21-2013, 03:50 PM   #2648
WRX8XB
Member#: 45323
The RPF1 isn't available in a 9.5 +45mm
they have a 9" +45mm (doesn't clear the front brembos without an 18mm spacer) and a 9.5" +38mm (needs a 5mm to clear the front brembos).
The T2s are very generous on the inboard clearance, plus with the full slotted bolt you slap the plates negative, run the bolts full positive and you end up with a nice -2.0 or so rear camber.
Old 02-21-2013, 04:25 PM   #2649
piknockout
Member#: 192173
They do in an 18" diameter...currently running 18x9.5" et45 Enkei RPF1's with a 15mm spacer up front to clear the Brembos.
If you're going to run the 17's, I would get the +38's. I believe Dan (IlliniSTi) is running those on his car without any fender clearance issues. The rubbing is only happening on mine due to the taller 18's.
Old 02-21-2013, 04:42 PM   #2650
WRX8XB
Member#: 45323
That's right, I forgot you were on 18s for some reason.
Air Force Guys Check-in (other branches welcome) joosrsx Off-Topic 293 05-01-2010 10:36 PM
northwest connecticut guys check in 09wrxtorrington New England Impreza Club Forum -- NESIC 6 08-12-2009 02:46 PM
New Guy Checking In mmormino Newbies & FAQs 3 02-14-2009 12:07 PM
New guy checking in amfj231 Newbies & FAQs 7 12-22-2008 09:13 PM
