Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 03-30-2010, 02:19 PM   #1426
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
After that I would get adjustable end links, get the car corner balanced, and Schroth quick fit belts. Make sure your base map has the stock boost tables and you are using stock boost while autocrossing.
silver arrow is offline   Reply With Quote
Old 03-30-2010, 02:35 PM   #1427
steveRS
Member#: 180430
2008 335i
Originally Posted by AustinTX View Post
I've had a couple questions about my setup after my awesome and unexpectedly large win at the TX Tour this weekend, so here goes:
I bought the car in December and bought the rest of the stuff as I could through Feb. I'm on KW V3's with 450F/375R springs, linear conversion, helpers F/R, Whiteline MaxC plates F, Whiteline non-adjustable plates R. I'm still on the KW recommended damper settings, as I haven't had time to mess with them and it's too easy to screw that up. I've got 29mm whiteline bars F/R and 17x9 FN01R's with 245 Star Specs. I recently got a Perrin single cat turboback to get a better sound, and that ended up forcing me to get an AP and a tune due to overboosting. -2.5F/-1.5R camber, 0 toe F/R, 13.5" F/R ride height. That's it. Everything else is stock. I drive this car daily, so many other typical mods are being looked at with much more scrutiny than just the cost. Next for me is probably a battery and removing those useless fog lights off the front.
John
Did you by chance put your hand on your tires after a run? I would expect the outside is much hotter than the inside with only 2.5 deg of camber in the front. What kind of tire pressures did you run?
steveRS is offline   Reply With Quote
Old 03-30-2010, 02:49 PM   #1428
STirish
Member#: 71515
'06 STi
John
Drive my car for a run or two at the next event and we can see what you think. We can make suggestions from there.
Rob
STirish is offline   Reply With Quote
Old 03-30-2010, 02:59 PM   #1429
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
I was running 45PSI front and 40PSI rear. It was so windy at the TX Tour that tire temps were almost non-exsistent. Generally, the tire temps are close enough that I'm not overly worried. I've got 4 events on the car now, and tire wear is looking good. I expect to need more camber to maximize front grip, though. My setup is not optimized, just based on best practice and setup for dual use. I can't wait to actually adjust the camber and shock settings to make the car better
Rob, sounds good.
AustinTX is offline   Reply With Quote
Old 04-01-2010, 09:09 PM   #1430
flu1d
Member#: 141586
07 STi
Another one!
1. Engine: stock (running STU map from PDXtuning)
2. Exhaust: Helix catted DP + Invidia n1 racing tbe
3. Suspension: 27mm/24mm fsb/rsb, waiting on my T2s to arrive 500/500 rates
4. Alignment: shooting for -2.5 front camber, -1.5 rear camber, 0 toe rear and 1/8 toe out front
5. Tires: 245/40/18 star specs on Prodrive gc-05fs
6. Brake Pads: DTC-30s
arrrgh can't wait for my coilovers to arrive and autox to start!
flu1d is offline   Reply With Quote
Old 04-02-2010, 01:57 AM   #1431
piknockout
Member#: 192173
2006 STU prepped STi
Sponsored by Agile Auto
Nice win in TX John, should be even better once you start to actually prep the car.
piknockout is offline   Reply With Quote
Old 04-02-2010, 10:16 AM   #1432
STirish
Member#: 71515
'06 STi
Originally Posted by piknockout View Post
... should be even better once you start to actually prep the car.
Don't tell him that.
Old 04-02-2010, 10:43 AM   #1433
piknockout
Member#: 192173
Okay, umm, takebacks?
Old 04-05-2010, 11:59 PM   #1434
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
I bought an STi finally, and I plan on running STU :-) currently minimal mods.. but I shall have some in the future hoping I can get the car to the point its competitive.
hilary0110 is offline   Reply With Quote
Old 04-06-2010, 07:56 AM   #1435
flu1d
Member#: 141586
07 STi
Cool! Hope to see you at some NORA/ASCC events
Old 04-06-2010, 09:46 AM   #1436
piknockout
Member#: 192173
Congrats Hillary, just don't make us boys look too bad like Annie does.
Old 04-06-2010, 08:36 PM   #1437
SubieEngineer
Member#: 208152
2007 STI LTD #576
UGM, FOR SALE!!!
I just ordered some 255/40/17 Star Specs (I know... I'm running my region's STM class and BSP/STM elsewhere this year) from Discount Tire. They offer 10% Bing cash back, too, so the total shipped for all 4 was just under $550.
SubieEngineer is online now   Reply With Quote
Old 04-06-2010, 09:56 PM   #1438
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
No worries... I cant drive
Old 04-07-2010, 09:23 AM   #1439
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
Oh and the mind games begin.....
Don't let her kid you she will be kicking your a**'s soon.
mccanixx is offline   Reply With Quote
Old 04-07-2010, 09:39 AM   #1440
piknockout
Member#: 192173
It's going to be fun telling my friends that I got beat by another girl...looking forward to seeing the car out there! What are your plans for setting it up this year?
Old 04-07-2010, 03:14 PM   #1441
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Hey guys, switching from BSP to STU this year. No more 17x10/275's for me!
Here goes:
1. Engine - Cobb APv2 - STU Protune, Stock Intake, K&N Panel Filter
2. Exhaust - Helix Catted DP, Invidia N1 Street CB
3. Suspension - RCE Tarmac 2's - 600/500 rates, WL 27-29 FSB set on 29, WL 22-24-26 RSB set on 24. Ride height is around 13.75" front, 13-13.25" rear.
4. Alignment - -3.0 camber up front, -2 camber rear, 0 toe all around
5. Tires - 245/40/17 RE-01R's on 17x8 Rota G-Forces (for now)
6. Brake Pads - Hawk HP+ all around w/ stock rotors
Running 29/24 on my bars currently with 600/500 springs. Car was pushing a bit too much this past weekend. (understeering) I need more rotation: I'm thinking about bumping down my bars to 27/22. Smart move?
I might end up putting the stock front bar back on at some point. Maybe the stock rear as well...
Acejam2k is offline   Reply With Quote
Old 04-07-2010, 03:48 PM   #1442
bdi
Member#: 66033
05 STi
What tire pressure were you running in those RE01R's?
bdi is offline   Reply With Quote
Old 04-07-2010, 04:11 PM   #1443
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
I was running around 43 psi front and 38.5 - 40 psi rear. (hot) Should I add more out back to help the rear slide around a bit more? Either way, I'm definitely going to soften up my current WL bars, before taking them off.
Old 04-07-2010, 04:24 PM   #1444
bdi
Member#: 66033
05 STi
From my experience, RE01R's are tough. When I ran them, my car had some push that I could not dial out. Collin F. might hopefully chime in here to help you out as he ran them and was very fast the year he did (won Nats.). But if I recall, I believe he ran them at pretty high pressures 45psi or so. I got tired of trying to dial them in and went to the D-lops. If you plan on sticking with that tire then yes start making changes to get the car where you want it. If you plan on switching tires, I would not start swapping parts just yet as your car will handle much different with a set of D-lops for example.
Old 04-07-2010, 06:14 PM   #1445
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
Thats when I cross the finish time with a smaller number on the time clock right?
Old 04-07-2010, 07:37 PM   #1446
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Good to know. My current plan is to kill off my RE-01R's, which have about 30-40% life left. Once they're done, I'm probably going to order some light gray 17x9 Kosei K1 TS's from TireRack, along with some 245/40 RE-11's.
Old 04-07-2010, 08:17 PM   #1447
Chiketkd
Member#: 71634
In hibernation...
Congrats. Pics?
Chiketkd is offline   Reply With Quote
Old 04-08-2010, 09:08 AM   #1448
piknockout
Member#: 192173
Agreed, pics or ban!
Old 04-16-2010, 11:31 AM   #1449
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
Originally Posted by Chiketkd View Post
Congrats. Pics?
http://forums.nasioc.com/forums/show....php?t=1966372
Old 04-17-2010, 01:15 PM   #1450
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
So, who runs 17x9.5 for an STU wheel setup? I'm thinking about trying out some 17x9.5 +38mm RPF1's. I'll need some ARP's up front, along with a 5mm spacer to clear the Brembos. The plan is to stretch out a 245/40 RE-11. Is this overkill?
I know a guy running 17x10 RPF1's with no spacers and a 245/45 Star Spec. The tire fits fine, but it's quite stretched. Since this is going to be a DD/STU setup, I want to go with a bit more compliance.
I've also thought about 18x10 RPF1's....but that might be a bit overkill. Does anyone run 18's in STU?
And before anyone say's their heavy...the 17x9.5 RPF1 weighs 16.4 lbs...
Air Force Guys Check-in (other branches welcome) joosrsx Off-Topic 293 05-01-2010 10:36 PM
northwest connecticut guys check in 09wrxtorrington New England Impreza Club Forum -- NESIC 6 08-12-2009 02:46 PM
New Guy Checking In mmormino Newbies & FAQs 3 02-14-2009 12:07 PM
New guy checking in amfj231 Newbies & FAQs 7 12-22-2008 09:13 PM
