Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 04-29-2010, 02:46 PM   #1476
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
I just got bumped to STU from STX due to my wheel width and tune..lots of STi's. I kinda wish I could start from scratch and be stock lol.
nightcrawler60 is offline   Reply With Quote
Old 04-29-2010, 02:50 PM   #1477
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
If you got a tune that bumped you out of STX, you're not legal for STU either.
AustinTX is offline   Reply With Quote
Old 04-29-2010, 04:50 PM   #1478
SubieEngineer
Member#: 208152
2004 350Zed Base
Sold: 07 STI LTD #576
If it modifies boost levels (and some other stuff), welcome to Street Prepared.
SubieEngineer is offline   Reply With Quote
Old 04-29-2010, 05:42 PM   #1479
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
Ahh man this sucks, Im reading the rule book and getting conflicting info from different sources. Is my stage 2 tune with 16.5 peak boost pressure going to put me in SP? I know for sure my wheels arent stx legal, but I said the tune also because I was told if the boost level has been changed then it will put me in STU
My mods
Power- TBE and tune
Suspension- front and rear sways (22 front 22-24 rear), front rear strut tower bars, d-specs, swift r springs, fender braces, steering rack bushings and 17x8.5 wheels.
Old 04-29-2010, 05:59 PM   #1480
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
My mods
Power- TBE and tune
If you change the boost level, your bumped out of Street Touring, and thrown into Street Prepared. In the case of an '04 WRX, I believe the correct class would be ESP. BSP is where the STi's run. (difference between 2.0 vs. 2.5 liter motor, etc)
Acejam2k is offline   Reply With Quote
Old 04-30-2010, 01:21 AM   #1481
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
Thanks, looked it up and it sounds right. Sucks no one runs ESP in my region .
Old 04-30-2010, 08:56 AM   #1482
piknockout
Member#: 192173
2006 STU prepped STi
Sponsored by Agile Auto
Then just flash the stock tune with the AP and run in STU. ;-)
piknockout is offline   Reply With Quote
Old 04-30-2010, 09:09 AM   #1483
AustinTX
Member#: 23954
06 STU STI
'15 BRZ
The fender braces are also a no-no, but I doubt anyone will care.
Old 04-30-2010, 09:09 AM   #1484
Illini_STi
Member#: 70634
Won't the fender braces kick you out of ST also? Upon a quick perusal of the rules I didn't find anything obvious that allows these.
Illini_STi is offline   Reply With Quote
Old 04-30-2010, 11:13 AM   #1485
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
Im REALLY thinking about doing this, but right know im running ecu-tek. I actually wanted to get another tune that would give me better mpg's anyway...and now seems to be a good time to do it.
Ah yes you seem to be correct. Guess those maybe coming off as well.
Old 04-30-2010, 11:49 AM   #1486
piknockout
Member#: 192173
I don't exactly see any performance benefit to the braces, as long as you're not beating everyone then I'm sure nobody would really care...of course, better to be legal if you can.
Old 05-04-2010, 01:28 PM   #1487
ty25rst
Member#: 173058
Ok So this is off topic a little but I need advice on the difference between the TIC AST coils and the RCE T2's. I want a more track oriented set up that would take me to nats... Which are better? I think the TIC have more droop travel... but it seems many folks just get the T2s...
Thanks for the advice
ty25rst is offline   Reply With Quote
Old 05-04-2010, 01:56 PM   #1488
jc8587
Member#: 76201
1990 Spec Miata
TMPR.net
Originally Posted by ty25rst View Post
Ok So this is off topic a little but I need advise on the difference between the TIC AST coils and the RCE T2's. I want a more track oriented set up that would take me to nats... Which are better? I think the TIC have more droop travel... but it seems many folks just get the T2s...
IMO, I'd take the TiC AST setup or go with your own AST setup with higher spring rates.
jc8587 is offline   Reply With Quote
Old 05-04-2010, 03:04 PM   #1489
makofoto
Member#: 25243
2006 Legacy Outback
Do you want to go to a road racing nationals or the SCCA Solo Nationals!? Auto Cross isn't the same as Road Racing ...
makofoto is offline   Reply With Quote
Old 05-04-2010, 03:37 PM   #1490
ty25rst
Member#: 173058
What makes the TIC setup better than the T2s?
Im thinking like 8 front -9k rear spring rates... any reason to go higher?
Old 05-04-2010, 03:37 PM   #1491
ty25rst
Member#: 173058
AutoX nationals
Old 05-10-2010, 01:18 AM   #1492
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
I love when people give me set up advice that have never even attended a local
hilary0110 is offline   Reply With Quote
Old 05-10-2010, 08:17 AM   #1493
piknockout
Member#: 192173
It's because their setup is mad tyte yo on the streetz...better recognize!
Old 05-21-2010, 12:49 PM   #1494
UWMechEngr
Member#: 193756
2014 BRZ
#75 STX
Hello STU, I figured I'd go here since technically that's where my car would be. I've come to the decision to move to ST* after this season. While I know I won't be nationally (or probably even locally) very competitive against the evos and sti's, I'd rather get my car to a point where I'm more happy driving it at an autox than I am now in stock trim (such as it was). Plus if the ST* changes happen, maybe I'll be better classed. I'm going to be trying to strike a balance between DD comfort and Autox Performance.
Anyway, I wanted to get some advice on a build-up path. I figure 2011 will be a transition year for me, since I won't be able to do everything at once. My car right now:
- Whiteline 24mm adj Front sway bar
- Kosei 17x7 wheels
- Hawk HPS Pads & Ate Super Blue fluid
- 225/45 Star Specs, that need to be replaced after this season
(no, my car wasn't even really prepped well for Stock)
Initially I want to focus on suspension, get it feeling better before I do the engine stuff. To that end my off season changes will most likely be:
- Whiteline 22mm adj rear sway bar
- Kartboy endlinks all around
- WL Steering Rack Bushings
- Shocks/springs or coilovers
- Realignment and/or corner balancing
- Possibly new wheels (might stick to just 8" in case ST gets shaken up and all the wrxes are in STX or an STX-like class)
- New Tires (size dependent on the wheels) Star Specs, or AD08s, or Re-11s.
The last one is proving somewhat of a conundrum for me right now. Currently I'm going between the TiC Legendary Legend of Awesome (or whatever) fully build D-specs with Swift Spec-R springs and GTworx tophats. But for that price I could possibly find some used K&W v3s, or get new BC ER coilovers, or spend less and get the BC Inverted coilovers. Everything I've read leads me to believe the BC coilovers are a decent system for the price, but the TiC package is proven quality. I guess I'm wondering, of these options, what would you more experienced guys reccomend.
I'll keep looking through this thread and the multitide of STX threads there are, but frankly I'm lazy and figured I'd ask my questions too.
UWMechEngr is offline   Reply With Quote
Old 05-21-2010, 01:34 PM   #1495
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
I finally corner balanced the Hamfist Racing STi. Here are the highly-technical-space-aged-corner-balancing results print out from the super computer.
For those of you who don't have a PHD in mechanical engineering, I can decipher this for you...
Corner Weights:
FL 1009lbs FR 962lbs
RL 686lbs RR 633lbs
Cross weights:
FR & RL 1648lbs
FL & RR 1642lbs
Thanks Johnson Scale!!
S1MPSONS is offline   Reply With Quote
Old 05-21-2010, 01:57 PM   #1496
bdi
Member#: 66033
05 STi
Are those numbers with you in the car?
bdi is offline   Reply With Quote
Old 05-21-2010, 02:09 PM   #1497
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
Yeah. Car weighted 3090lbs without me (and my helmet) fyi.
Old 05-21-2010, 02:51 PM   #1498
bdi
Member#: 66033
05 STi
Ok thats what I thought. Is that also with about 1/4 tank of gas?
Old 05-21-2010, 02:52 PM   #1499
S1MPSONS
Member#: 90357
2006 Corey's EVO
& 1993 Mazda RX7
A little less. The low fuel light just came on and I added 2 gallons.
Old 05-21-2010, 03:25 PM   #1500
bdi
Member#: 66033
05 STi
Thats pretty damn good cause your prob around 3070 once you take the axle back off to! You could easily have a 3000lb car!
Air Force Guys Check-in (other branches welcome) joosrsx Off-Topic 293 05-01-2010 10:36 PM
northwest connecticut guys check in 09wrxtorrington New England Impreza Club Forum -- NESIC 6 08-12-2009 02:46 PM
New Guy Checking In mmormino Newbies & FAQs 3 02-14-2009 12:07 PM
New guy checking in amfj231 Newbies & FAQs 7 12-22-2008 09:13 PM
