Old 05-20-2001, 07:50 PM   #1
BlackIce
Member#: 3164
Question Another CE light question
Replaced the fuel filter in my '98 Legacy GT Wagon over the weekend, one of the few maintenance items I've had personal time for recently. Now the CE light is blinking at me. Manual says a loose gas cap can cause the light to blink, so I'm guessing that de-pressurizing the system by popping the filter has had the same effect. The manual was less helpful when it came to clearing the error indication. In the loose gas cap scenario, it says be more careful ablut tightening the cap and the light should go off in a couple of tankfuls. Am I going to have to watch this light blink for a month? Or is there some secret icantation I can say over my offended monitoring computer that will convince it all is well?
Thanks
Dave
BlackIce is offline   Reply With Quote
Old 05-20-2001, 08:31 PM   #2
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
Just reset the ECU.
Might want to double check the connections on your fuel filter. I didn't have this problem when I replaced mine.
gavin is offline   Reply With Quote
Old 05-21-2001, 04:00 AM   #3
BlackIce
Member#: 3164
Talking
Well, Gavin,
THAT was interesting. Based on your reply, I went back and searched on ECU Reset and found a message that mentioned mating up a pair of connectors under the dash and going through a specific sequence to clear the ECU.
The <other> task I undertook this weekend was trying to track down why my electric radio antenna has stopped working - I was all over under the dash trying to find its fuse (which I didn't) AND connected this one loose pair of wires (green with a matched set of green connectors). Went out just now and pulled 'em apart ... Whaddaya know, the light didn't come on when I restarted.
Will wait to see if the performance changes on the drive home.
Still haven't found the fuses for the antenna.
Dave
Old 05-21-2001, 11:40 AM   #4
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
Wow, I'm surprised that the only problem you had was the flashing light. I would have thought your engine would have been running funky, too.
Yet another, another, fog light question. 97OBLimited Electrical & Lighting 0 04-13-2010 10:40 PM
yet another 9007 lighting question ent2b Electrical & Lighting 2 07-23-2003 08:45 AM
another CE light question, please dont flame me hondaconvert Normally Aspirated Powertrain 6 05-09-2001 07:55 AM
another CE light. Help! BongMan Normally Aspirated Powertrain 8 04-09-2001 01:29 PM
Another CE light mystery phantomdrain Technical Forum Archive 4 09-24-2000 02:10 PM
