Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Vendor Classifieds
Old 03-27-2006, 11:39 PM   #1
Ultimate Collision Center
Vendor Sales Rating: (35)
Member#: 69072
Default Crazy GB Prices on Snow Performance Kits
Run higher boost with pump gas with the Snow Performance Alcohol Injection Kit! This kit includes everything that you need to install this setup on your EVO, WRX, STi or SRT-4. This kit comes with a 2qt tank but can also be used with your stock winshield washer tank! This kit includes a 150psi shurflo pump which can spray methanol, alcohol, windshield fluid, or a mix. This kit has the several different controllers to choose from; either map, maf or 2d with maf and map (evo only at the moment). The kits can also be upgraded to include SafeInjection which is a failsafe that is used to kill boost down to wastegate pressure whenever an error in flow is detected with the system.
Boost Cooler Stage 1: PM me
Boost CoolerStage 2(map, maf or 2d): PM me
With SafeInjection upgrade: PM me
Optional Materials Needed:
Loctite or Threadlocker (needed for nozzle install)
Automotive Goop (needed if you plan to install kit using stock washer tank)
Additional Vacum Line (depends where you install controller, some cases you may need additional line)
Switch (if you donít want to have the alky kit on 24/7 you will need a switch to turn it on and off)
Gas Tank (to store or transport extra fluid)
Shrink Wrap (if you donít want to use electrical tape)
Wire (depends on where you mount the controllers)
Here are a few pics of the kit installed on my EVO
Using OEM windshiled washer tank
Controllers mounted on passanger side floor
Tank and pump installed
Power led and warning led
We will end this at 10 people.
1. SinistiR (TriStateTuners)
2. AppTB (EVO-NY) PAID
3. kb2spn (NASIOC) PAID
Ultimate Collision Center is offline   Reply With Quote
unbelievable price on ERZ performance, walbro, Cobb, TurboSX, Perrin, HKS, Greddy, ERZperformance Engine/Power/Exhaust 207 04-27-2010 06:52 PM
Special GB Pricing on ALL Kartboy Items ~ Including NEW 08+ WRX/STI Rear Endlinks! Circuit Motorsports Vendor 'Group Buy' Classifieds 67 12-11-2009 02:44 PM
Crazy Low Prices on All ACT Clutches and Flywheels!! Spun Autosports MAIC Vendor Classifieds 1 01-24-2009 06:18 AM
Best Prices on Snow Performance Alcohol Injection Kits... Ultimate Collision Center Engine/Power/Exhaust 0 08-08-2006 06:37 PM
