Old 03-27-2006, 11:48 PM   #1
MYfirst00
Member#: 22928
2011 Outback Sport
Default 1998 Legacy GT OEM Suspension Options
Does anyone know or know where I can find out what other OEM Subaru suspension setups bolt right into the Legacy GT sedan from 97-99? I thought that the 98-01 RS fit right in but I browsed through Teague's Auto and found the rears to be different? I'm trying to stay cheap but will get new tophats if needed.
Thanks,
Ryan
MYfirst00 is offline   Reply With Quote
Old 03-28-2006, 01:39 AM   #2
gtwagon941
Member#: 16874
2008 Audi RS 4
01 Subaru LGT Sedan
SEARCH.
This topic has been covered a MILLION times. Whiteline, Eibach, H&R, KYB...all of these are companies to look into...
Jared
gtwagon941 is offline   Reply With Quote
Old 03-28-2006, 07:24 AM   #3
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
The only thing different about the rears is the tophats. (and the springs are different because of the weight difference)
Wiscon_Mark is offline   Reply With Quote
Old 03-28-2006, 07:24 AM   #4
MYfirst00
Member#: 22928
2011 Outback Sport
Originally Posted by gtwagon941
SEARCH.
Jared
I searched all yesterday and found nothing. On Nasioc, RS25.com, I-club, legacycentral.org, legacygt.com...and I said OEM suspension.
Old 03-28-2006, 08:51 AM   #5
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
i know you said you are looking for oem but just thought i would mention that the H&R's have a pretty nice even look to them...not too low or anything. Also it helps get rid of some of that extra lift in the front.
legacy1907 is offline   Reply With Quote
Old 03-28-2006, 10:53 AM   #6
MYfirst00
Member#: 22928
2011 Outback Sport
I'm thinking about keeping the H&R springs that are on the car, but I don't know how long they've been on at the moment. I'm hoping around 10k. The stock struts are toast as well as the mounts. I may just get new KYB GR-2 and put the H&R springs on them with new mounts. I'm checking into pricing from someone that works at a dealer for the whole SPT setup for the Impreza plus Leg mounts. Which would you think is better?
Old 03-28-2006, 11:51 AM   #7
spdracr00
Member#: 65823
1996 Impreza L
Red
Trust me on this one.. stay away from the impreza suspension and just go with legacy stuff from the get go.. you will save $100 or so with used WRX stuff but its really worth it to get legacy stuff from the start. If you wanna stay stock-ish.. just get a set of GR-2s off ebay and use your stock GT springs.. the gR-2's are about 25% stiffer than the stock oem struts and you GT springs are about 25% stiffer than stock legacy springs.. so with that combo (gr-2 + GT springs) same ride height and stiffer ride.
spdracr00 is offline   Reply With Quote
Old 03-28-2006, 12:03 PM   #8
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
i have h&r sports on the kyb gr2's and i think they work well. It is a good ride not too stiff or anything but a good stiffness level, especially for daily driver.
Old 03-28-2006, 12:05 PM   #9
MYfirst00
Member#: 22928
2011 Outback Sport
Awesome, that was exactly the info I was looking for. Thanks Spdracr00. I'll get the GR-2s and get the GT springs from the dealer along with mounts. The car already has an aftermarket rear sway so it should feel firm and I won't have to worry about scraping stuff on these crappy New England roads.
Old 03-28-2006, 12:16 PM   #10
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
the only thing is that it will sit up like stock and personally i think thats a little high but the gr2's are good
Old 03-28-2006, 12:44 PM   #11
gtwagon941
Member#: 16874
2008 Audi RS 4
01 Subaru LGT Sedan
Well, then I don't quite understand what you are looking for. OEM is OEM. Period. What more is there to look for. Go to the dealer and buy the OEM sturts/springs if you want OEM.
Oh, but now it sounds like you want aftermarket struts, that I know you had to have read about if you really did search.
The setup you now talk about getting is NOT completely OEM and HAS been covered in the past, and the company you are going to buy just happened to be on the list in my post...strange how that worked out...
Jared
Old 03-28-2006, 12:47 PM   #12
MYfirst00
Member#: 22928
2011 Outback Sport
Jared
Everyone else seemed to get what I was looking for. OEM = Original Equipment from Manufacturer. Aka Subaru.
Don't be so waa waa pissy, dude. Thanks to everyone else that had a helpful suggestion.
Old 03-28-2006, 12:54 PM   #13
gtwagon941
Member#: 16874
2008 Audi RS 4
01 Subaru LGT Sedan
Dude, the "dealer" I was in reference to that you should buy OEM from was a Subaru dealer, I though that would be clear.
I just don't see how your original request for OEM and then response to me reminding me that you want OEM is now satisfied by your purchase of aftermarket equipment.
Glad you are satisfied now, but your posts don't really make sense with each other..
Jared
waa waa
Old 03-28-2006, 01:31 PM   #14
MYfirst00
Member#: 22928
2011 Outback Sport
Jared
waa waa
OK recap:
Yeah I understand what a dealer is, but by OEM I meant the cross-reference of parts. You know, how the struts are all the same, springs are slightly different, front tophats are the same but rears are different when matched with Impreza suspension. I was looking to see if I could drop in RS suspension directly but as Wiscon_Mark noted that the rear tophats are different. So basically I could drop in RS suspension by just changing the rear tophats. Or WRX suspension by changing all tophats. Everything there is OEM.
But then spdracr00 noted that KYB GR2s are better than stock and that the LGT springs would do well with them, and that's what persuaded me to lean that way. Since I will need to buy new tophats anyway I might as well piece new stuff together instead of trying to loosen the tophat nut on suspension that's off the car.
Where's Dr. Phil when you need him...
Old 03-28-2006, 01:39 PM   #15
linsavy
Member#: 11620
1997 GF4 -STiV3
Saab 93 TX sportcombi
The tophat nut is not that bad. Worst case, go to repair shop close to home, have them loosen it with the air gun and then drive home to complete the job. Go back after you are done for tighening.
I bought a strap wrench in the bargain bin for $8 the other day. Should work as well.
linsavy is offline   Reply With Quote
Old 03-28-2006, 01:45 PM   #16
spdracr00
Member#: 65823
1996 Impreza L
Red
I need to step in again... you got the top hat issue messed up..
The rear upper-spring perch(tophat) is the same. I'm running a full WRX strut/spring setup on my 99legacy wagon. all i had to do to make this work was get some Impreza upper-spring perches(tophats) for the front. impreza springs taper at the top in the front, but do not taper in the rear. now keep in mind if you're gonna use impreza parts on your legacy (which i say NO) you need to find 02/03 wrx struts/springs/perches. which goes the same for RS stuff, but why use RS stuff when WRX is better?
Old 03-28-2006, 02:01 PM   #17
MYfirst00
Member#: 22928
2011 Outback Sport
So what you're saying (technically, not ethically) is that I could go out to Ebay and grab one of the used 02/03 assembled sets and drop it in for $150 instead of dropping $650 on a whole new setup?
Old 03-28-2006, 05:22 PM   #18
MYfirst00
Member#: 22928
2011 Outback Sport
Ok I answered my own question. Found a great post at Legacygt.com for what I want to do. http://www.legacygt.com/forums/showthread.php?t=6274
I think I'll just pick up the 02-03 WRX complete setup and call it a day. GC stuff doesn't hold the weight of the Legacy very well apparently so goot call Spdracr..
I feel like I just called Geico.
Old 03-29-2006, 02:31 PM   #19
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
05 Legacy GT 06 Armada
Search under my username:
MY99 2.5GT
Search the following keywords:
stock struts legacy
Fill your brain I've had a few different suspension setups on my 99 Leg
MY99 2.5GT is offline   Reply With Quote
Old 03-29-2006, 02:52 PM   #20
zerofighter
Member#: 93619
94 Legacy Ti
Pearl White
myfirst00: I sent you a PM, I think... My computer is acting strange, so you may not have gotten it.
I would like to buy the H&R springs you have if you would like to sell them. I'm only 20min away from you, so I can easily come get them.
zerofighter is offline   Reply With Quote
Old 03-29-2006, 03:40 PM   #21
MYfirst00
Member#: 22928
2011 Outback Sport
MY99, thanks for the leads. Great info, especially about mounts.
Old 03-29-2006, 07:28 PM   #22
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
ive read that you CAN use WRX suspension, but its not wise to do so, mainly because of the 300-400 lbs of "car weight" difference. i know i wont do it.
~Josh~
Old 03-29-2006, 07:54 PM   #23
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
Dr. Phil sucks...
Old 03-29-2006, 07:54 PM   #24
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
~Josh~
WRXs are heavier than BDs...at around 3200 lbs.
Old 03-29-2006, 08:27 PM   #25
MYfirst00
Member#: 22928
2011 Outback Sport
According to Edmunds, the GD weighs 3085lbs and the BD weighs 3090lbs. Albeit Edmunds is not the end-all-be-all of car specs but I would guess that it's pretty close.
According to the spring rates of the WRX matched against the 90-94 Legacy spring rates (link below), the WRX has stiffer fronts with slightly softer rears. Does anyone know the spring rates of the 97-99 GT springs to see how they match up against the WRX?
http://bbs.legacycentral.org/viewtop...ht=spring+rate
Either way my set of WRX suspension will be here next week and I'll post how it feels. Granted I have nothing to compare it to it will just be a general description.
-Ryan
FS MD: 08 legacy gt oem suspension **new** specchuck MAIC Private Classifieds 0 03-07-2008 01:17 PM
1998 Legacy GT OEM Suspension Options MYfirst00 Brakes, Steering & Suspension 0 03-27-2006 04:46 PM
will 1998 legacy gt hood (with scoop) fit as a replacement for 1998 legacy L hood? thebreathing Legacy Forum 9 01-16-2006 04:50 PM
FREE 1998 Legacy GT Limited OEM exhaust cyyeo430 Bay Area Impreza Club Forum -- BAIC 1 04-24-2005 10:19 PM
1998 Legacy GT - Chassis and Suspension Geometry and Dimensions UTCiv Subaru Conversions 3 07-13-2004 12:00 AM
Message Board Statistics All times are GMT -4. The time now is 10:56 AM.
