Welcome to the North American Subaru Impreza Owners Club Saturday April 19, 2014
Old 05-20-2000, 11:58 AM   #1
richeich
Member#: 1353
2001 Impreza 2.5RS
Question Legacy GT/ Rear Sway Bar
Hello all, I'm new here so bear with me! I just got a 98 Legacy GT 5 spd (woo-hoo!), and was curious about the rear sway bar. Obviously that's one of the first upgrades to think about, but I wanted to make sure that the GT didn't already have an 18mm sway bar before I bought a new one for it. Does anybody here have any comments or opinions about this? Thanks!
Rich, Tulsa OK
98 Legacy GT
96 Outback Wagon
90 Legacy LS
(Just sold my 93 SVX)
richeich is offline   Reply With Quote
Old 05-20-2000, 02:36 PM   #2
silverSurfer
Member#: 1361
1999 Legacy GT Ltd.
2006 Rav4 Sport Silvarrr
Talking
Richeich,
the OEM Sway bar on a '98 Legacy GT is not 18mm (much to our disapointment! ). However this is easily remedied byt purchasing one: 18mm,20,21mm depending on your preference. Try Spdtuning.com , Spomotorsports.com , home.att.net/~teaguesauto/index.htm for parts that'll fit our cars. (i have a '99 Gt Ltd.) Good luck and let us how that sway bar turns out!
-ChrisC
Aka SilverSurfer
[This message has been edited by silverSurfer (edited May 20, 2000).]
silverSurfer is offline   Reply With Quote
Old 05-20-2000, 04:09 PM   #3
BG5
Member#: 695
Thumbs up
also, since you have a OB you can compare sizes and even borrow the bigger bar from there to try on your GT...
Knowing that you can just run down to your local (discount parts?) dealer and order
the OB bar and bushings...
BG5 is offline   Reply With Quote
Old 05-20-2000, 04:36 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
I measured my stock one before I ordered an 18mm just to make sure I actually needed the new bar. It looked to me that the stock one is 15mm. I have heard that the Outbacks use an 18mm bar, so you could check that.
To measure it I just wrapped a strip of paper around the bar nice and tight and marked where the paper overlapped the loose end of the strip. Then I measured that distance to get the circumference of the bar, then divided by 3.1415289 (aka pi - and I regurgitated those numbers from memory, so they could be wrong, but 3.14 is good) to get the diameter. If you have a cloth tape measure (like a tailor uses) you could use that to do the same technique.
Anyway, if you do have a 15mm bar, upgrade it to a bigger bar. You will be happy with the performance improvement, trust me.
Pat Olsen
'99 Legacy 2.5GT 5 speed sedan
Old 05-20-2000, 05:56 PM   #5
euroauto
Member#: 249
05 FXT psm
12 R350
Post
try the easy way to measure, use an open wrench! If 17 is to small and 19 is to big it must be 18! Most home sets don't come with a 18mm wrench.
euroauto is offline   Reply With Quote
Old 05-20-2000, 06:22 PM   #6
BG5
Member#: 695
Post
factory specs are:
GT : 19mm Front, 16mm Rear
OB : 19mm Front, 18mm Rear
Old 05-20-2000, 08:04 PM   #7
richeich
Member#: 1353
2001 Impreza 2.5RS
Post
Thanks everyone, that's good information.
Rich
Old 05-20-2000, 10:40 PM   #8
Boxer4Racing
Member#: 167
Post
Just to let you know I have the 18mm Rear sway bars w/ bushings in stock (Used) for $100 plus shipping.
Dale Teague (Teague's Auto)
http://www.teaguesauto.com For all your Subaru needs.
Boxer4Racing is offline   Reply With Quote
Old 05-21-2000, 01:09 PM   #9
PaulN
Member#: 566
1994 Legacy GTB
Green
Post
I don't suppose it's of any use but the GTB have 19/18 f/r anti-roll bars - think the same as the outback
Paul
PaulN is offline   Reply With Quote
BG Legacy Outback Rear Sway Bar seowitz Private 'Wanted' Classifieds 1 11-30-2005 11:13 AM
Wanted: 97-99 Legacy GT rear sway bushings Gator GT Private 'Wanted' Classifieds 7 04-16-2005 12:11 AM
FS:NY: 95-99 Legacy 18mm rear sway bar byroll01 Private 'For Sale' Classifieds 1 11-05-2004 10:47 AM
WTB: Legacy turbo rear sway bar, or any 18 mm Legacy AWD RSB annointed Tri-State Area Forum 0 05-06-2003 04:28 PM
Subaru Legacy Outback rear sway bar Fit MY01RS? RS_NW Brakes, Steering & Suspension 2 01-14-2001 07:54 PM
