Old 03-28-2006, 05:17 AM   #1
sick1.8t
Member#: 22345
2003 RSX
black
Default 2.5 DOHC heads to 2.2 SOHC heads swap questions.
so i've got a '98 legacy GT with the dohc 2.5 in it. i'd like to use the heads to build up a budget sti engine for another car, and at the same time swap in sohc 2.2 heads to the GT so that i'm left with a high compression motor. i'll probably end up getting the heads and intake manifold from a early-mid 90's impreza or legacy to do this.
what will i need to do in the way or wiring or other parts? i'd like to have it be as simple as possible since this is my daily driver and i cant have it out of commission for long at all.
sick1.8t is offline   Reply With Quote
Old 03-28-2006, 11:15 AM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
You'll just need to make sure that you get an Ej22 manifold that has the IAC on the manifold like the GT does. Then, used the GT manifold wiring harness, TB, and coil and you should be good to go. If at all possible, get an early Ej22 manifold and avoid the EGR. I have a spare manifold sitting around if you need one as this goes forward. I may also have a set of EJ22 dual port heads in fairly short order...
Old 03-28-2006, 12:00 PM   #3
sick1.8t
Member#: 22345
2003 RSX
black
my dohc heads have the EGR, why should i get one that doesnt have that? i thought removing the egr would introdice some knock into the system , not to mention throw a cel.
Old 03-28-2006, 01:27 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
EGR is a BS emissions thing, deleting it impacts nothing...
Old 03-29-2006, 05:27 AM   #5
sick1.8t
Member#: 22345
2003 RSX
black
thats good to know
Old 04-01-2006, 02:40 AM   #6
hotshot2109
Member#: 94785
04 WRX STi
just get a 98 ej22 ecu and injectors and use phase II ej22 heads (worse flow then phase I dual port heads, but have better cam) I did the exact oposite of you, swapped out my 98 ej22 for an ej25, just required a 98 2.5 ecu to use the ej25. ej22/ej25 hybrid is like 13.5:1 compression iirc. You should use your stock ej25 phaseII block to make an "open deck ej257" shortblock (ej257 crank, rods, pistons) i believe, its a subaru so you have a million options
hotshot2109 is offline   Reply With Quote
Old 05-01-2006, 10:11 PM   #7
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
TTT
I'm doing a phase I 2.5L shortblock swap into my '99 EJ22 using the phase II 1 layer headgaskets. What am I to look out for?
FuJi K is offline   Reply With Quote
Old 05-01-2006, 11:30 PM   #8
Storm
Member#: 5218
96L Most Over-
Developed Beater
Originally Posted by FuJi K
TTT
Slower cars and brake fade!
Jay
Old 05-02-2006, 03:25 AM   #9
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
nyah! ...well besides the slower cars....
what's this I hear about the piston coming out of the sleeve on the phase I 2.5L shortblock? I don't want piston slap now....
Old 05-02-2006, 03:44 AM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
except your cruising speed EGT's
EGR Valves reduce the NOx emissions by allowing inert gas into the combustion chamber under light engine loads when cruising.
Old 05-02-2006, 03:45 AM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
btw: i have a set of 98 Impreza RS DOHC that need head work(2-4 bent valves), you interested in them at all? I was planning on using them on the L but the more i think about it the less i want to actually put any money into the L
Please help me!! 2.2 sohc to 2.5 dohc swap problems! lomaxmotorsports Normally Aspirated Powertrain 7 07-19-2008 12:29 PM
2.5 DOHC swap to 2.2 SOHC compatibility? suby53 Normally Aspirated Powertrain 9 01-30-2008 06:28 PM
2.5 DOHC --> 2.5 SOHC swap. Please Help! spdracr00 Subaru Conversions 13 03-02-2006 04:49 PM
2.5 phase 1 to phase 2 swap limeylight Subaru Conversions 12 12-29-2004 06:31 PM
Borla 2.5 in catback to STi 2.5 catback? jroberts Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-21-2004 04:43 PM
