Old 03-28-2006, 10:33 AM   #1
joltdudeuc
Member#: 6119
1999 GM6
RBP
Default Where to tap for oil pressure gauge?
I'm hearing about some bolt that's in the block/head that can be removed and in it's place you can put an oil pressure probe. Unfortunatly, I can't seem to find it, nor find pictures of it.
Any one have any idea?
-Gagan
joltdudeuc is offline   Reply With Quote
Old 03-28-2006, 11:02 AM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
You can either tee if off the idiot light one right behind the alternator/steering pump, or there is another allen head bolt under the manifold that you can use. It's got a brass colored head on it...
Old 03-28-2006, 11:11 AM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
What size threads dose your sender have? if it's 1/8 npt then here are 2 choices.
You can tee into where yuor stock sensor goes or you can remove the rear main galley plug and replace it with part number 11024aa210 $6.74 and install it there.
Your stock oil pressure sender is just to the left of the alternator, on the block. If you go straight back from it you'll see an allen head main galley plug. Replace that plug with the above mentioned plug(which is the same one used for the stock oil sending unit), and install your aftermarket unit there.
Tim Sanderson is offline   Reply With Quote
Old 03-28-2006, 11:12 AM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
beat me while I was typing Matt.
Old 03-29-2006, 10:19 AM   #5
joltdudeuc
Member#: 6119
1999 GM6
RBP
Thanks guys!
I actually do have that replacement plug already, but couldn't figure out where to put the damn thing. Ok, So this plug is at the top of the block or below it? (meaning, should I swap it during an oil change or would there be no oil coming out?)
I'll try to get this finished up soon.
Thanks again,
-Gagan
Old 03-29-2006, 05:19 PM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
top rear of the block. Look down from the pcv.
Old 03-29-2006, 05:53 PM   #7
fastco
Member#: 77972
2009 Legacy 2.5i
QSM
Use this guide just disregard the intercooler stuff....
http://www.scoobymods.com/forums/sho...ressure+sender
fastco is offline   Reply With Quote
Old 03-29-2006, 08:11 PM   #8
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
First of all i'd like to strongly suggest that you don't use teflon tape. Use a liquid thread sealant. It usually has teflon in it.
If you find that your sending unit does'nt thread in far enough then stop by a hardware store and get yourself a 1/8" pipe thread tap and tap the new fitting adapter a little deeper.
Old 04-11-2006, 07:25 PM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I've been told that Subarus use BSPT, not NPT. You can thread a 1/8" BSPT into a 1/8" NPT (or vice versa), because the difference is pretty small, but they aren't the same (the threads per inch is different, as is the angle of the threads).
Pat Olsen
'97 Legacy 2.5GT sedan
Old 04-11-2006, 09:46 PM   #10
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
JB weld works wonders . I just used the block plug with the threads and the auto meter sender and just JB welded it together . never a leak for more than a year .
imprezzakc is offline   Reply With Quote
where to tap for mech. boost gauge monzon Electrical & Lighting 6 12-17-2005 07:17 AM
Where to tap off for oil pressure gauge Tattoo Collector Normally Aspirated Powertrain 2 12-08-2005 11:20 AM
Where to buy VDO oil pressure gauge buymeasti Interior & Exterior Modification 0 03-29-2005 01:22 PM
Easiest place to tap for Oil Pressure guage. Kwyjibo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-13-2003 05:27 PM
Where to tap for oil psi gauge? STiShawn Normally Aspirated with bolt-on Forced Induction Powertrain 7 10-12-2001 02:44 PM
