Old 10-01-2001, 08:59 PM   #1
inpreza kid
Member#: 3334
Default afc work with MY00 plus turbo?
since the map sensor has to be clamped for around 5v so the ecu thinks its only reading 3 psi would a afc(air/fuel computer) be useless for tuning since by 2000rpm the turbo would be pushing more than 3psi?
inpreza kid is offline   Reply With Quote
Old 10-01-2001, 09:00 PM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
the AFC is useless on the MY00-01 anywy. the computer learns and remaps back to how it was.
Eric
Eric SS is offline   Reply With Quote
Old 10-01-2001, 09:30 PM   #3
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
Correct. You need to use something like the Split Second Voltage clamp and a RRFPR on a MY00.
kastle is offline   Reply With Quote
Old 10-01-2001, 10:16 PM   #4
inpreza kid
Member#: 3334
would a rising rate fuel pressure riser be accurate enough to control the fuel through out the powerband? assuming i have a itc to control the timing aready.
Old 10-01-2001, 10:22 PM   #5
kaos200
Member#: 2692
It works ok, kinda inaccurate. Nothing is better than engine management. But if its your only choice, get a 4:1, and modify the fuel rails to be parallel. Run the timimg controller, and BOOST ON!
kaos200 is offline   Reply With Quote
06 wrx VF39 cobb map work with 07 VF43 Turbo? Nasty25 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 12-30-2008 06:50 AM
Will the HKS DP work with a stock turbo/midpipe on a 2005 WRX? whesung Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-16-2005 04:58 AM
Will the HKS wire harness work with the Apexi turbo timer for the 04 Wagon? othon Electrical & Lighting 6 02-12-2004 12:32 AM
Which downpipes work with the SR turbo? Sordid Philosopher Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-17-2002 01:52 AM
Does S-AFC work with MY00 +? blaster88 Normally Aspirated Powertrain 14 03-13-2001 10:48 PM
