Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 03-28-2006, 11:23 AM   #1
APSWRX1
Member#: 63630
2009 CWP Mazdaspeed3
TXIC Groupie Member #1
Default CEL P0442/P0457? (Help Needed)
I have been riding with my CEL on for a while and I finally got a chance to check it with Dave's scanner. I pulled these codes...
CEL P0442: Evap Emission Control Leak (Small) x 2
CEL P0457: Evap Emission Control Leak/Cap Loose
I have tightened my gas cap so hopefully that will be going away soon. As far as P0442 I found that it is connected to the loose gas cap issue, but is also triggered when you replace/upgrade the fuel pump, which I did recently. Is there any way to remedy this situation? Replace any seals? Or will I be ok?
Any help is appreciated! Thanks!
APSWRX1 is offline   Reply With Quote
Old 03-28-2006, 11:39 AM   #2
RickInLittleElm
Member#: 58353
99 Mercedes-Benz
E430
A code should not be triggered when you replace the pump unless the pump retainer seal was not installed correctly( and you would smell fuel in the cabin if it was not )...only if the evap pressure sensor detects a leak. If tightening the cap did not fix it, check all the evap lines that run under/around the intake and also the line going to the evap canister under the rt rear bumper cover. Make sure the canister itself is not cracked. If all the lines pass inspection, I would replace the gas cap.
_R
RickInLittleElm is offline   Reply With Quote
Old 03-28-2006, 12:10 PM   #3
APSWRX1
Member#: 63630
Thanks for the help Rick!
I do smell fuel a lot more since I installed the pump and injectors, but I thought that it was a by product of running more fuel. If the seal was not installed correctly, then is it just a matter of me removing the FP and readjusting the seal?
All the evap lines look ok and there doesn't seem to be any loose connections. The canister doesn't look cracked, but I will check again. Would fuel be collecting in this area if it was? I see no leaks there.
Could all this stem from a faulty gas cap?
Old 03-28-2006, 02:08 PM   #4
RickInLittleElm
Member#: 58353
99 Mercedes-Benz
E430
You should not be smelling fuel....unless your tune is waaaay rich. It's not hard to pinch the gasket when installing the pump. I have seen this many times associated w/ your concern. There are 3 rubber titties(for lack of a better word) that need to be pulled through the oval plate that seals against the top of the tank. They are situated in between the 8mm bolts that hold the plate down and are attached to the gasket to locate it correctly. If these are not in place, or the bolts were over-tightened and stripped, you will get a smell of fuel and a p0455 and/or p0457, p0442. There is also a metal bracket that goes over the plate and I have seen it installed under the plate, sandwiched between the gasket and tank, causing a nasty leak.
A faulty gas cap will not usually cause a fuel smell....I would check the tank plate...pull the back seat out, remove the cover and put your nose near the tank plate...you should smell NO fuel at all...if you do, there is your problem.
_R
Old 03-28-2006, 02:16 PM   #5
APSWRX1
Member#: 63630
Thanks again Rick. I will check up on this.
CEL p0442 fixed- may help you WRC_Fever Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 01-17-2014 12:30 PM
Evaporative Emissions help needed: P0442, P0457 sfjohnson Service & Maintenance 9 09-14-2010 09:17 AM
CEL issue P0457 - Help Rally_WRX1 Service & Maintenance 3 06-08-2008 07:24 PM
CEL P0442 stand up imma_stocker Texas Impreza Club Forum -- TXIC 6 11-04-2007 10:19 PM
Cel P0442 Rando Engine Management & Tuning 5 03-29-2006 10:14 PM
