Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Old 03-28-2006, 02:42 PM   #1
Geoff
Warden of NASIOC Timeout
Super Moderator
Member#: 592
'11 X5 xDrive35i
'09 135i 6MT/'15 GTI 6MT
Default Put 'em here: Any Questions for PDX Tuning Dyno Day
If you made the list on the first thread and have specific questions for Jarrad, please post them HERE. Jarrad will field them directly.
-Geoff
Tuning Starts at 7AM on Friday and ends at 7. I need to know specific times that you guys want - I'll do my best to work a schedule out over the two days. As far as tune-specific questions, make sure you ask Jarrad.
SCHEDULE
FRIDAY, MAY 5th 2006:
7AM - Just_A_4 - EcuTek/UTEC
8:30AM - KGreb - Ecutek/UTEC
10:00AM - Chuck33079 - AP
11:30AM - Distorto - AP
1:00PM - eheddles - AP
2:30PM - YourMother'sLover - UTEC - MAYBE
4:00PM - drifterATheart - AP
5:30PM - 05redrex - Alc injection / UTEC
SATURDAY MAY 6, 2006
7AM - HP12c - AP
8:30AM - Inprogress - EcuTek
10:00AM - TypeC - UTEC
11:30AM - FatStraws - ??
1:00PM - Bad Dogg - AP/DTEC
2:30PM - wrxout - Ecutek
4:00PM - HK Phooey - UTEC
5:30PM - Pingpong - AP
7:00PM - Salaki - AP
Standby:
CoolCougar - EcuTek - MAYBE
anthony_delprete84
AtomicRacer
NathanSVT
Antny
If you are a MAYBE, you must validate with me before Friday, March 31st or you forfeit your spot
I will be contacting you all regarding a deposit to hold your position once the schedule is finalized.
Geoff is offline   Reply With Quote
Old 03-28-2006, 03:07 PM   #2
The Head
Member#: 98143
04 Cayenne TT
05 SL65, 03 GSXR1000
I can go any time after 8:30am on Friday.
A few questions:
Before I ask them, I have an 06 FXT with a Cobb TBE, AP, Perrin pulley, APS top mount, and Walbro 255 pump. (update) I will have a VF39 mounted up for the tuning.
I have a Borla header. I was going to get it thermally coated (moreso than that paper thin paint they use) but before I do that, I was wondering if it would be worthwhile to install with only a VF39 turbo? I've read that the 2.5L benefits from this header up top and that with good tuning it can become about as laggy as the stock manifolds and not a slug when just bolting them on. Should I get it installed or sell it off for something better for my combination?
I also have one of the Perrin EBCS things and it has two ways to install it. The way they recommend is supposedly faster reacting than the usual bleed method. Should I install this thing or should I sell it off as well for something better suited for my combination?
My first map will be for 93 pump gas. I was going to bring in 5 gallons of 104 octane to mix with it for a 50/50 mix. Will there be enough time to get two maps for my AP done in one hour's time?
I have the stock BOV mounted right now but have a TXS BOV (recirculating) that is adjustable with spacers (washers). Will the tune I'm getting require the TXS BOV or will the stock one hold it?
With the parts listed, is there any other bolt-on part I should consider prior to the tuning (CAI, TGV delete, etc) that would make a significant difference?
Thanks in advance, Jarrad. I look forward to meeting you and learning some things. Thanks for coming down to Houston.
Eric
The Head is offline   Reply With Quote
Old 03-28-2006, 03:14 PM   #3
Chuck33079
Member#: 40612
2011 370z TT
I'm available whenever. I dont have class on Fridays, and its my day off from work.
Chuck33079 is offline   Reply With Quote
Old 03-28-2006, 03:18 PM   #4
Big_Hitter
Member#: 10831
2011 Ferd Ranger 4x4
2009 FXT VF52/E85
will EL be providing hot dogs and sauce for those of us that want to watch?
Big_Hitter is offline   Reply With Quote
Old 03-28-2006, 03:25 PM   #5
YourMother'sLover
Member#: 76565
CLXX Stricta Parata
Neci!
i want to know how much it would be to upload Version 5.X firmware onto my UTEC and just transfer over maps (and make slight adjustments as needed). I'm still driving with that OL/CL fuel hesitation.
YourMother'sLover is offline   Reply With Quote
Old 03-28-2006, 03:44 PM   #6
Big_Hitter
Member#: 10831
2009 FXT VF52/E85
I think the utech reflash is pretty straight-forward
heck, I did that myself (no joking people)
Old 03-28-2006, 04:07 PM   #7
Bad Dogg
Member#: 8331
2002 WRX Wagon
Stealthified
I am available Saturday afternoon, also Friday.
Will bring my game boy...
Thx
Howard
Bad Dogg is offline   Reply With Quote
Old 03-28-2006, 04:57 PM   #8
salaki
Member#: 10572
92X N62B44, ST 1050
CGK, LAX, & DFW
I would prefer Saturday slot so I can leave on Friday after work to Houston instead of taking vacation on Fri (I'm running low). So if anyone would like to swap, please PM me.
Question to Jarad:
Cobb AP Stg 2 STi Off The Shelf Map - No Street Tuner Software.
No poossy Cusco DP, HKS Carbon Ti, Samco MAF hose, Samco Turbo Inlet hose, & APS CAI 65mm Red Wrinkle.
Purpose of use: Road Course Track Days, twisties drive, weekend drive, some traffic commute. I just need it to be fine tuned for additional parts that I have to be safe for track days use.
Do I really need one step colder plug as I just changed my plugs to OEM @ 30K miles (I have 35K miles)
Do I get the 91 octane maps and other maps just like Cobb provides?
Thanks,
David
salaki is offline   Reply With Quote
Old 03-28-2006, 05:03 PM   #9
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
I'm a definate.
TypeC is offline   Reply With Quote
Old 03-28-2006, 05:07 PM   #10
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
You do not HAVE to run one step colder plugs. I would run these for now and then next time put in the colder plug.
When you get tuned by me you will get a set of maps. I will tune you for your main fuel, and then I adapt the map to 91 octane. I also will make a valet mode, low boost and an antitheft maps. If you want to completely optimize your setup to run on 91 octane then we would need to fill the tank with 91 and spend more time on the dyno. The 91 maps are safe to run on 91, but not going to make 100% of the potential power on 91.
Jarrad
Question to Jarad:
Thanks,
David
PDXTuning is offline   Reply With Quote
Old 03-28-2006, 05:30 PM   #11
drifterATheart
Member#: 62468
Slow Stage 4
CGM STi :(
Thanks,
David
salaki you can have my time, i need my time to be on friday at 4:00 thanks. i should have been more specific in the other thread that i needed friday
drifterATheart is offline   Reply With Quote
Old 03-28-2006, 05:48 PM   #12
Chuck33079
Member#: 40612
2011 370z TT
Geoff, go ahead and put me down for 10:00 am friday. Thanks.
Old 03-28-2006, 06:01 PM   #13
distorto
Top Scoob 024
Member#: 56364
RIP stompr :(
bagged vulvva
i'll take the 1130 on friday.
Jarrad, should I get a boost controller on top of the AP for my setup. I'm not sure if I need it, I will be getting a OTS map for my vf23 with supporting mods, and have you tweak them on the tune day. Also, any word on when I should get the AP?
distorto is offline   Reply With Quote
Old 03-28-2006, 06:07 PM   #14
Inprogress
Member#: 65166
2008 EVO X
I really appreciate the time slot Geoff, thanks!...
Inprogress is offline   Reply With Quote
Old 03-28-2006, 06:14 PM   #15
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
We got in APs today. It will take us a day to get them loaded and sent out, but I think yours came in today.
I like aftermarket boost controllers, well, I like the TurboXS DTEC BC Pro. We used to use the AVC-R, but the DTEC is much better so I prefer it now although the AVC-R is a good second choice. You do not have to have one with your setup, but it will make the car a bit faster. There are no issues with it not playing well with your AP in case you were wondering that.
Jarrad
Old 03-28-2006, 06:18 PM   #16
Inprogress
Member#: 65166
2008 EVO X
Unfortunately I have the Greddy Profec Type S, will that benefit me in my situation Jarrad?
My Mods:
2005 STI
VF34, Perrin FMIC, Perrin Inlet, Perrin CAI, TBE, and Ecutek.
Old 03-28-2006, 06:20 PM   #17
Geoff
Super Moderator
Member#: 592
'11 X5 xDrive35i
Final two need to battle it out now. I did my best to accomodate everyone...I apologize if the times aren't 100% where you'd like to be. Feel free to PM eachother if you'd like to change slots. I'm not going to lock this down until the weekend.
Old 03-28-2006, 06:25 PM   #18
Geoff
Super Moderator
Member#: 592
'11 X5 xDrive35i
Barry/McRee have put up funds for EL to buy refreshments for us all. I'll likely be there doing some grilling and stuff as well. So I guess we can expect to see Jeff there now, huh?
Old 03-28-2006, 06:28 PM   #19
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
There are other boost controllers I prefer, but you do not need to change yours as long as you run that turbo. If you decide to go to a larger turbo you will get more benifits from a more advanced boost controller, but for now I suspect the price is not worth it.
Jarrad
My Mods:
2005 STI
Old 03-28-2006, 06:40 PM   #20
distorto
Top Scoob 024
Member#: 56364
RIP stompr :(
bagged vulvva
Jarrad,
if i bought the DTEC boost controller, would it also have datalogging capabilities?
Old 03-28-2006, 06:45 PM   #21
Inprogress
Member#: 65166
2008 EVO X
Jarrad
Cool thanks! Maybe later on down the line i can sell it and get another one...
Old 03-28-2006, 06:45 PM   #22
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Yes it does.
Old 03-28-2006, 06:46 PM   #23
drifterATheart
Member#: 62468
Slow Stage 4
CGM STi :(
If i'm running catless tbe and AP, anythign else i could buy bfore to aid in getting more power out of the car during the tune? ie: intake or anything else?
Old 03-28-2006, 06:49 PM   #24
The Head
Member#: 98143
04 Cayenne TT
Jarrad, please see post #2.
In addition, if you think a range colder plug would help I will get those in as well.
Old 03-28-2006, 06:49 PM   #25
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Personally I prefer the stock air box at stage 2 power levels. If you want to send me a money order for being such a pleasant person I think it would go a long way toward getting you a better tune
PDX Tuning Dyno Day at JapTrix: Sign up NOW! Nick South East Region Forum 180 04-09-2007 11:23 PM
Attn: Everyone going to the PDX Tuning Dyno Days this weekend Geoff Texas Impreza Club Forum -- TXIC 22 03-02-2007 06:26 PM
PDX Tuning Dyno Day - Jarrad's Here Geoff Texas Impreza Club Forum -- TXIC 104 05-12-2006 01:05 AM
PDX Tuning Dyno Day - Final Schedule & Payment Info - Standby folks read as well! Geoff Texas Impreza Club Forum -- TXIC 108 05-04-2006 07:26 PM
PDX Tuning Dyno Days - May 5/6 at Engine Logics in Houston Geoff Texas Impreza Club Forum -- TXIC 59 03-28-2006 05:56 PM
