Old 10-01-2001, 12:49 AM   #1
kaos200
Member#: 2692
Question Who has built their block?
I wondering who has built up their Subaru block?
what kind of pistons/rods did you use?
and what work was done to it?
kaos200 is offline   Reply With Quote
Old 10-01-2001, 04:47 AM   #2
8Complex
Member#: 922
04 FXT
Red
Rebuilt to stock, but thats about it. Haven't gotten to build the motor yet as I haven't been able to even get the car running for long enough to warrant it yet. :-/
Old 10-01-2001, 09:32 AM   #3
AaronB
Worst Mod Ever
Member#: 369
Wiesco Pistons (8.5:1) required slight overbore.
Pauter Rods
Total Seal rings
All new stock valves.
Stock crank.
Nothing was really done to the head.
Most of the work that was done was to repair the damage the stock piston fragments created.
Aaron
http://www.azscooby.com
http://www.scoobymods.com
AaronB is offline   Reply With Quote
Old 10-01-2001, 02:09 PM   #4
outback motorsports
Member#: 4084
Default motor building
we've built 2.5 turbo w/pauter and outback motorsports rods ,6 diff. piston config. for 2.5 turbo. 2.0 turbo 20 psi, spearco intercoolers,garret turbos, you name it .see ya steve,
outback motorsports is offline   Reply With Quote
Old 10-01-2001, 02:19 PM   #5
Kcz
Member#: 2038
2000 RS-T
Silverthorn Metallic
Mine has Pauter rods, Cobb spec JE forged pistons 9:1, 100mm bore and cams.
Kcz is offline   Reply With Quote
Old 10-01-2001, 08:05 PM   #6
kaos200
Member#: 2692
What noises do they make if any?
Old 10-01-2001, 09:34 PM   #7
tom@kartboy
Member#: 67
1999 Outlasting
the competition.
kaos200 What noises do they make if any?
it shouldnt make any abnormal noises
what are you hearing?
tom@kartboy
Old 10-01-2001, 09:37 PM   #8
kaos200
Member#: 2692
what do you have Tom?
how about noises when breaking in?
Im still going through that
Old 10-01-2001, 09:52 PM   #9
tom@kartboy
Member#: 67
1999 Outlasting
the competition.
kian
i still have a stock motor
but i 've built countless racing motors from topfuel drag cars to 125 shifterkart ones. no noise is good noise IMHO
again whatcha hearing?
tom@kartboy.com
Old 10-02-2001, 12:01 AM   #10
Kcz
Member#: 2038
2000 RS-T
My engine sounds like a deisel, and Cobb says it's one of the most quite 2.5 they have heard after forged pistons.
Old 10-02-2001, 08:55 AM   #11
Jay_UK
Member#: 296
The noise could be several things...
Piston slap (to large clearance)
Valve train noise (need regapping/shimming)
Main/big/small end clearances too large
Most likely piston slap..... most forgies have to run more clearance due to their expansion characteristics.. when they are cold, they can tend to slap.. but the noise should go away.
Again.. the clearance varies from make/type of piston to another.
Like Tom says... no noise is good noise
J.
Jay_UK is offline   Reply With Quote
Old 10-02-2001, 09:31 AM   #12
AaronB
Worst Mod Ever
Member#: 369
On cold starts it sounds like a poorly tuned diesel. Once the pistons warm up, then it just sounds like a normal diesel, but I am 90% sure almost all my post-warmup noise is just valve-train noise.
Aaron
http://www.AzScooby.com
http://www.ScoobyMods.com
Old 10-03-2001, 09:30 PM   #13
kaos200
Member#: 2692
cool, sounds about right
thanks again
Who has tuned their AVCS system, Who Wants To? TurboSetch Alaskan Impreza Club Forum -- AKIC 10 09-18-2009 06:40 PM
SO who has built 05 turbo upgrade kits? HighWayDrifter Legacy Forum 4 09-27-2004 03:39 AM
Who has had their radiator replaced or has one that leaks corallo99 Factory 2.0L Turbo Powertrain 25 03-31-2003 11:43 AM
Who has blown their motor or built a motor in their 02 + wrx STEALTH-WRX Factory 2.0L Turbo Powertrain 4 08-20-2002 10:05 AM
Who has built a performance Justy? RoyBoy General Forum Archive 14 12-13-2000 12:12 AM
Message Board Statistics All times are GMT -4. The time now is 06:52 PM.
