Old 03-28-2006, 07:31 PM   #1
Rando
Member#: 9189
Unhappy Cel P0442
I need some help finding the cause of this code. I have searched and none of the suggestions have worked so far.
Here's a little background. I have not changed the fuel pump. I traded gas caps with a friend. I have checked the blue connector beside the intake. I have checked the lines at the canister. Nothing has worked. The only thing that I have changed recently is the turbo inlet pipe. Any help would be greatly appreciated.
Thanks
Randy
Rando is offline   Reply With Quote
Old 03-28-2006, 07:40 PM   #2
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
...find that vac hose that ya borked doing the inlet
Old 03-28-2006, 10:07 PM   #3
Rando
Member#: 9189
Any suggestions on which one it could be?
Old 03-28-2006, 10:36 PM   #4
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
...something related to the fuel system
Old 03-29-2006, 04:08 PM   #5
Rando
Member#: 9189
Well I went to the dealership today to have the car checked out and they could not locate the source of the leak. They did the diagnostic test and the smoke test. I'm lost. Does anyone know if the smoke test is reliable?
Old 03-29-2006, 10:14 PM   #6
Rando
Member#: 9189
After wasting my money with incompetent people at the local Subaru dealership I decided to look for the leak again. Guess what.... I found it after looking for two minutes. The purge control valve solenoid had a crack at the base of one of the nipples. I'm going to call and complain about the sorry diagnostic work that was done or not done on my car today. Thanks for the info Uncle Scotty.
CEL p0442 fixed- may help you WRC_Fever Factory 2.5L Turbo Powertrain 18 10-15-2011 03:03 AM
Cel P0442 PorterFNU Newbies & FAQs 1 10-06-2009 06:52 PM
CEL P0442 stand up imma_stocker Texas Impreza Club Forum -- TXIC 6 11-04-2007 10:19 PM
CEL P0442 (evap small leak) + instable boost frederik Factory 2.0L Turbo Powertrain 4 10-20-2007 11:49 AM
CEL P0442/P0457? (Help Needed) APSWRX1 Texas Impreza Club Forum -- TXIC 4 03-28-2006 02:16 PM
Message Board Statistics All times are GMT -4. The time now is 10:57 PM.
