Old 03-28-2006, 08:00 PM   #1
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Default block swap checklist...need
hey guys
I have a very limited amount of knowledge on the whole engine building subject. I have a 2002 WRX with the stock 2.0L block and I have bought a used EJ257 shortblock to replace mine with. I am running a FPgreen and cannot take the lag any longer.
I have searched around a bit and found many different views about what and how to approach a 2.0 to 2.5 block swap.
I have the following already:
2.5 Sti 2004 shortblock (all stock internals) around 15k on the motor
ARP head studs
Sti head gasket kit
installation date (last week of April)
tuning and dyno session date ( 2nd week in May -Topspeed)
What else could I benefit from to yield a complicated free install and safe install?
Are my 2.0 heads gonna do well with this block? I have seen different opinions on this subject.
Upgraded timing belt?
How about upgraded cams? need'em?
Looking to make solid power, but nothing nuts. ~375 ish
Thanks for any constructive input
kingtut12 is offline   Reply With Quote
Old 03-28-2006, 08:06 PM   #2
modaddict
Member#: 95840
sold to a good bud
awaiting next car
the pistons in the STi block arent gonna work w/ your heads. i believe the dish in the 2.0 head is large. your compression ratio wont be squat. check out www.crawfordperformance.com for pictures on STi pistons then STi pistons using wrx head. Basically, what im saying is your gonna have to get new pistons from the manufacturer of your choice, to raise the compresssion ratio.
modaddict is offline   Reply With Quote
Old 03-28-2006, 08:34 PM   #3
cubuff
Member#: 38345
2004 WRB WRX
Thats not true at all, your compression ratio will be around 8.7:1 ish I believe. The stock Sti block with stock internals will swap over fine. You can however opt for lower compression pistons, which you could benefit from if you plan on running a lot of boost. 25+psi.. You just will need a tune that accompanies the higher compression ratio.
You can get cams such as crower, dpr, or helix, I would personally go with helix just because the value, they come with upgraded valvetrain also for just under $1000.
There are lots of threads about 2.0 heads with 2.5 block and compression ratio, you should take the time to read them and decide what you feel would be best for you.
cubuff is offline   Reply With Quote
Old 03-28-2006, 08:58 PM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
sealant
torque wrench
motor stand
I think the arp stud nuts are 1/2 inch 12 point(you'll need that socket).
Set of 21-30 mm deepwell sockets(oil filter stem).
set of allen head sockets(up to 10mm)
couple cans of brake clean
towels
torque specs and pattern for the head bolts and cam cap bolts.
clutch alignment tool
large c-clamp for the belt tensioner
parmanent marker to label the buckets before they fall out
gasket scraper or razor blades are always nice
That's all I can think of right now.
Tim Sanderson is offline   Reply With Quote
Old 03-28-2006, 09:10 PM   #5
modaddict
Member#: 95840
sold to a good bud
awaiting next car
i guess i was backwards....itll raise your compression ratio. i guess its not that much. .5 point or so. Either way...your running an FP green, you'll break the stock STi piston ringlands sooner or later. if it was me, get a new set of forged pistons. if you dont and break a ringland later, youll pay more then and essentially do the job twice. i guess it depends on how much money you have in your budget. Sorry to mislead you initially.
Old 03-29-2006, 12:43 AM   #6
cubuff
Member#: 38345
2004 WRB WRX
I agree while you have the block out you might as well do it right the first time. Get forged pistons and not have to worry about those ringlands breaking, and if you feel like you need to get pistons that will match up with the 2.0 heads. I should post a picture of the piston that came out of my block almost all the way around it took a big chunk off. Maybe once I start my build ill get some pictures up here.
Old 03-29-2006, 01:27 AM   #7
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
how long does it take for ringlands to break? Buddy of mine with a big 35R puts out 448whp on stock motor, has 39k on the motor and ran an 11.6 @ 121 at the drag strip.
Sko is offline   Reply With Quote
Old 03-29-2006, 01:57 AM   #8
cubuff
Member#: 38345
2004 WRB WRX
I think the general census on ringlands is that it is the weakest part of the "stock" motor. Having said that, I have seen many people making big power numbers with stock pistons. I think its just a matter of whether your tune is spot on or not.
Old 03-29-2006, 02:08 AM   #9
banzai
Member#: 63926
Axis /RAW 2.2 Closed
deck EJ 20G stroker
I will throw my two cents in....
I am running a 2.5L block, WRX heads - ported, helix 264 cams. weisco piston and STi head gaskets with a VF22 and front mount.
the heads cc'd in around 51, so we figured a CR of about 9.1:1 ish with the STi gaskets. I wanted to use cometics, but they didn't get here in time.
I have about a thousand miles on the motor, at 320 hp, 340 ft/lbs.
IMHO, spend the money while the engine is out on the things farthest from a wrench. like the crank, rods, bearings, pistons.
i would also reccomend getting the kevlar reinforced STi timing belt. if you're goign to run cams, and there is no reason not to, protect your investment with a good timing belt.
no sense in putting a stock replacement timing belt on a motor you just spent an untold amount of money on.
like i said, spend the money on the farthest thigns from a wrench.
some of the locals here laugh at my VF22 and they are running greens or bigger on a stock bottom end. who's going to have the last laught after 20K miles of running the hell out of thier car? me or them?
spend the money in teh block. you will be glad you did later. I'd rather get laughed at for a VF22 now, and be saving up for a bigger turbo later on, than get a big turbo now and be fast for a few months then grenade my stock short block. you dig me?
i'm rambling, time for bed. hope that helped. feel free to IM/PM me if you'd like to get some pointers, tips and tricks.
banzai is offline   Reply With Quote
Old 03-29-2006, 07:52 AM   #10
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Thanks for all the great responses guys.
I think what I would like to for now is keep the block stock due to the cost. I realize forged pistons and upgraded ringlands would be better.
I guess what I really need to know is - Can I swap a 2.5 in for my 2.0 and not do anything to the heads, and drive away? Will I be dissapointed coming from my 2.0 "power"?
If it helps I have:
FPgreen
TXS FMIC
PE800 inj
Cobb AP - Protuned by Doug @ Topspeed (325whp, 293tq -93oct)
Perrin Bigmaf
Perrin 3" inlet
TXS DTEC boost controller
APS down, up, TBE
Turbonetics EXt WG 40mm
Exedy hyper clutch
ACT lightweight flywheel
Vishnu lightened pulley
Thanks
Old 03-29-2006, 04:50 PM   #11
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Here's something taken from a recent thread that might help you. The entire thread can be viewed here:
http://forums.nasioc.com/forums/show...ght=helix+cams
Originally Posted by Gruppe-S
Originally Posted by Moriarty
Copy that. I put in a stage #2 - 2.5 with stock heads. I've spent way more money trying to figure out why it wont mak whp at $250 per hour of dyno time. The solution after 1,200$ is the wrx heads don't work with a 2.5 sb. Wish I would have done the heads while I had the engine out, to begin with.
wrx heads are bad ju ju for the 2.5 anyway. Do it right now and save a lot of money.
We're of the same opinion; running the stock WRX heads with the 2.5L SB doesn't yield a whole lot more power but it does yield a much fatter midrange torque band. We've installed and tuned the Helix 264s w/ valve train in the WRX heads on a 2.5L SB more than a couple times now and have been very impressed with the results. I wouldn't say that these cams make the WRX heads equivalent to the STi heads (since the AVCS makes a lot of midrange power and torque) but from our results, it appears that these cams make the WRX heads capable of having higher peak airflow. For the price, they're an excellent option that lets you use your WRX heads and still optimize the 2.5L block. As for gasket thickness, we use the .051 for this hybrid.
Thanks,
Geoff
A few other comments. I'm fairly certain your ringlands will actually be fine running a Green on a stock 2.5L block. While we consider the ring lands and the bearings to be the weakest points of the USDM STi block, we still rate it as being able to handle 465 CHP consistantly. I don't think you'll be able to get more than 420 CHP out of a green on 91 octane (even with the STi AVCS heads) but I don't know what type of octane you'll be running and how often.
You can't really put a time period on it because it depends on your tune, how hard you drive your car and what octane fuel you use. We just tuned a stock block STi with our GT30R kit the other day and it made 404 WHP (low reading Mustang 4WD dyno) on 98 octane. That's about 485+ dynojet WHP and the motor is still OK but we don't expect it to last long.
So in short, I think you'll be fine with your stock block but I would recommend doing the cams. As someone also suggested, you might also want to do a PE or Greddy timing belt since those are about the same price as stock but are much better.
Thanks,
Geoff
Gruppe-S is offline   Reply With Quote
Old 03-29-2006, 08:29 PM   #12
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Awesome Geoff , thanks! i am now looking into a reasonable priced upgraded cams.
Old 03-30-2006, 02:05 PM   #13
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Don't mention it. I'd have to plug the Helix cams there. I won't post a price here but they're the most affordable complete cam / valvetrain solution we've come across that produces excellent results. They include cams, ti retainers, springs, and spring seat locators. Some other popular choices are Crower, Kelford, and Cosworth.
Thanks,
Geoff
Old 03-30-2006, 06:42 PM   #14
banzai
Member#: 63926
deck EJ 20G stroker
I will put in a plug for the helix cams too....
on a 2.5L, with WRX heads, they do make great mid range TQ.....
i was very pleasantly suprised with how much mid range my motor had. PM me for dyno graph.
Old 03-31-2006, 12:46 AM   #15
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Thank you - after much researching and a fair quote on the Helix cams, I believe I will be pursuing those. Thanks again guys and I will repost after the swap has started.
Old 04-05-2006, 11:09 PM   #16
devil13
Member#: 80559
2011 WRX
sorry to highjack your thread but i also will be doing a 2.5 block/2.0 heads swap shortly. which timing belt is needed? wrx or sti? and are new head studs neccessary?
devil13 is offline   Reply With Quote
Old 04-06-2006, 12:03 AM   #17
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
The belts are the same.
Guys please do some searching. I did my entire 2.5L swap without posting a single question. Everything and THEN SOME is in these forums.
TypeC is offline   Reply With Quote
Old 04-06-2006, 08:27 PM   #18
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Correct, Heads studs and timing belt are the same.
-Geoff
Old 04-17-2006, 01:12 PM   #19
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Stock head studs will work just fine from what I understand as long as you aren't boosting 25+ psi and then again some are still holding.
CoolRex is offline   Reply With Quote
Old 04-17-2006, 01:59 PM   #20
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Little update here:
knee deep into the swap - everything is going pretty well, we decided to do the tumbler deletes in the process.
Stripped a cam bolt and damaged the pulley trying to get it out. New one is ordered and will be arriving tomorrow.
EJ25 block has most all sensors back on and heads to go on soon.
Painted my intake manifold crinkle red, of course.
One question: What do/will I do with the extra crankcase vent on the new block?
Oh, and now that we have taken everything apart and have seen into the belly of other "mechanics" work with my previous bolt-ons - I can say - I will never again let someone else do my performance mods.
My up-pipe/ext.wg setup was only finger tight at the header!!
2 out of 4 PE800 injectors were not seated(one was totally crooked) - I have pictures to prove it and a messy gas/yuck mix all around them.
But all in all, I am pleased and I am learning and thats what i enjoy the most.
Old 04-17-2006, 03:34 PM   #21
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Like many JDM swaps, the driver-side port can either be capped-off or T'd to the valvecover vents. I tapped mine off and only recently hooked it up.
Old 04-17-2006, 08:34 PM   #22
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Okay - I will just t it in. Thanks.
Old 04-19-2006, 08:49 PM   #23
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Wed. update
Heads back in and torqued to spec (tricky)
Deleted tumbler valves back on and ready
Oil pan and stuff back on.
Now on to the easier stuff!!!
Should be on the road Friday. Oh and I ordered the Cobb street-tuner upgrade. Tired of driving 6 hours one way.
And I ordered a Tial WG today to replace an old turbonetics racegate wg. Its amazing how much you "extra" you decide to purchase once the car is ripped apart...
I will post some pics of the project soon and some dyno numbers too.
Old 04-23-2006, 06:01 PM   #24
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Drove the car today for the first time and MAN, the new torque is crazy. I did not get into boost at first and it felt very strong.
I got into boost a little bit (8psi) and it definitely needs a new tune. Car was very hesitant when i reached that point, kinda jerky. Tune or vacuum leak?
Thanks
Old 04-23-2006, 07:14 PM   #25
303WRX
Member#: 35097
2002 WRX Sedan
Nice! I would say that it's probably the tune. You should post some pics when you get a chance.
303WRX is offline   Reply With Quote
EJ257 swap checklist b3nj4m1n Subaru Conversions 3 04-17-2010 01:37 PM
Dash Swap Checklist sti_95imp Interior & Exterior Modification 1 07-25-2009 02:29 PM
Need Info On Sti Block Swap Into 03 Wrx!!!! wrxtacy03 General Community 2 05-21-2008 10:08 AM
Need advice on block swap Mike1967 Built Motor Discussion 0 03-31-2007 04:21 PM
UTEC map help needed for 2.5l short block swap LiquidForce Engine Management & Tuning 3 04-20-2004 10:51 PM
Message Board Statistics All times are GMT -4. The time now is 09:20 PM.
