Old 03-28-2006, 10:54 PM   #1
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Default STI water and oil pump swap?
Can I use STI water and oil pumps in my N/A RS?
HamFist is offline   Reply With Quote
Old 03-29-2006, 08:56 AM   #2
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
I'd bet Matt Monson would know, and he's helpful.
S.
n2xlr8n is offline   Reply With Quote
Old 03-29-2006, 07:41 PM   #3
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
yes you can, but they dont flow much more than stock regular EJ25 or EJ22 pumps, being as how they are all the SAME!!!
~Josh~
Old 03-30-2006, 12:55 AM   #4
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
I never trust an STI part to just LOOK the same as another stock counterpart. They meant for those to be run harder, and upgrading to those parts seem like a good idea. For example, are the radiators different, too?
Old 03-30-2006, 08:27 AM   #5
BensonRST
Member#: 106895
1999 RS-T
Custom Charcoal
i 've heard that the oil pump for the ej22t is the highest flowing, because it has oil squirters. never have confirmed it though. anyone know?
BensonRST is offline   Reply With Quote
Old 04-04-2006, 10:27 AM   #6
AWDrivin
Member#: 1687
99 2.5RS
bump... I'm looking for some technical info on this as well...
AWDrivin is offline   Reply With Quote
Old 04-04-2006, 11:29 AM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Oil pump yes, water pump, no. The STi oil pump is suposedly a higher pressure unit, similar to the old Ej22T pumps.
As far as the water pump, not only is the outlet to the radiator in the wrong place, but it has 2 extra return fittings, one for the overflow tank and one for the oil cooler. You could cap them, but why bother. I have never heard anything about it being a better flowing unit. If you want more cooling, get an additional heat exchanger and plumb it into the mix. It's about more volume of coolant, not more volume of flow...
Old 04-04-2006, 11:32 AM   #8
AWDrivin
Member#: 1687
99 2.5RS
Thanks Matt. What I was wondering about the water pump is if the return fittings could be used to plumb coolant lines to the turbo instead of cutting into the RS heater lines.
Old 04-04-2006, 11:37 AM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
You can plumb returns to the water pump, but not pressure fed coolant out to the turbo...
Old 04-04-2006, 11:44 AM   #10
AWDrivin
Member#: 1687
99 2.5RS
gotcha, thanks.
Old 04-04-2006, 11:09 PM   #11
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Good job Matt, 100% correct
Drac9 is offline   Reply With Quote
Wrx Stock Water and Oil pump. '02 Wrx stock Exhaust Rextion Engine/Power/Exhaust 3 05-01-2010 02:13 AM
WTB: Timing belt water pump and oil pump JasonOJordan Private 'Wanted' Classifieds 4 09-16-2009 06:37 PM
service life of water pump and oil pump? fastnoypi Service & Maintenance 9 02-18-2006 10:10 PM
FS: Water pump and oil pump jblaine Private 'For Sale' Classifieds 2 09-28-2005 12:35 PM
Which water & oil pump for V7? azulito Subaru Conversions 7 07-27-2005 06:00 PM
