Old 03-28-2006, 11:40 PM   #1
blacktalon606
Member#: 73316
Subaru Stars What pistons other than JE?
I have a set of eagles headed my way in the mail. I will soon be sticking them in an old usdm ej20 shortblock and I had planned to purchase a set of JE pistons to go along with my build. Then I read a post talking about an engine letting go because JE pistons are crap. Is this true? Would Aries be a better choice? Money is an issue, but If I have to I would rather spend a few more dollars to save in the long run.
blacktalon606 is offline   Reply With Quote
Old 03-29-2006, 01:09 AM   #2
yeahwrx
Member#: 46843
2003 WRX
I would be more concerned about there being several posts about JE pistons being crap.
yeahwrx is offline   Reply With Quote
Old 03-29-2006, 01:16 AM   #3
23b_Rex
Member#: 79394
02 gda
wrb
crawford makes good pistons... and blocks
23b_Rex is offline   Reply With Quote
Old 03-29-2006, 02:22 AM   #4
gcm05
Member#: 105948
2005 wrx w/sti block
Crystal Grey Metallic
eagle, je and cp are all junk IMHO.....mahle and oliver are the way to go but heck what do those mahle guys know.....they've only been doing it for over 82 years. Oliver of course would just be your rods but i'm sure you already knew that. I just like to make sure for people just in case
gcm05 is offline   Reply With Quote
Old 03-29-2006, 06:49 AM   #5
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
We have a forum for this and now that it's been moved, you MIGHT want to gander at the Piston FAQ I spent like 30 hours researching.
Old 03-29-2006, 10:46 AM   #6
yeahwrx
Member#: 46843
2003 WRX
I think there needs to be a sticky with all your FAQs listed. They are most helpful.
Old 03-29-2006, 10:52 AM   #7
dream
Member#: 37003
2015 WRX
Mahle FTW. I just got a set of these and they will be in the block within the next week or so. I cant wait!
dream is offline   Reply With Quote
Old 03-29-2006, 11:18 AM   #8
thehollowrift
Member#: 86788
04 STi
wiseco are pretty awesome -- they have kits ready to go... hold up too
thehollowrift is offline   Reply With Quote
Old 03-29-2006, 11:46 AM   #9
ejh25
Member#: 65267
I'm going Wiseco.
ejh25 is offline   Reply With Quote
Old 03-29-2006, 12:30 PM   #10
sonic rx
Member#: 33457
Chapter/Region: PRSIC
HAHA EVERYONE KNOWS
DYNO JET IS NOT REAL WHP
seen alot of motors with the wiseco have problems. they are just breaking into the import scene as well as automotive.that scares me a bit . i need them to be around for awhile. i am using cp pistons in my 2.5l
sonic rx is offline   Reply With Quote
Old 03-29-2006, 12:38 PM   #11
gcm05
Member#: 105948
-1 for cp pistons
Old 03-29-2006, 03:19 PM   #12
02Toyowrx
Member#: 56520
I think it depends on the installation and tuning. You can use the best of the best parts and if they are installed wrong or you are running a bad tune, or have a bad tank of gas .... your engine could fail.
02Toyowrx is offline   Reply With Quote
Old 03-29-2006, 03:37 PM   #13
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
+1 Mahle ...
Old 03-29-2006, 06:18 PM   #14
blacktalon606
Member#: 73316
ok then... Wiesco or CP? Pros/cons?
Old 03-29-2006, 10:17 PM   #15
Crawford Performance
Member#: 42075
Crawford Performance is offline   Reply With Quote
Old 03-30-2006, 12:52 AM   #16
Sko
Member#: 90396
2005 Legacy 2.5i
Brilliant Silver Metallic
Wiseco uses their own 2000Ton press to forge their pistons, I recently blew a block that had my Wiseco's in it, needless to say the Pistons were more salvageable than the rest of the block. 1 rod came off the crankshaft, bent and cracked another rod, other rods were bent. Pistons look alright up top other than them bending a few valves, although the rods did take a chunk or two out of the back of them.
If you get forged pistons, then the pistons are the least of your worries.
Sko is offline   Reply With Quote
Old 03-30-2006, 05:50 PM   #17
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
We favor the Wiseco and carry custom spec versions for Subaru motors.
-Geoff
Gruppe-S is offline   Reply With Quote
Old 04-03-2006, 01:15 AM   #18
cyrus923
Member#: 44425
2004 Impreza WRX
WR BLUE
I run wiseco's and love them. The shop I get my car worked on uses nothing but them. They have a 650+ whp wrx drag car. Nuff said
cyrus923 is offline   Reply With Quote
Old 04-03-2006, 01:57 AM   #19
gcm05
Member#: 105948
if i couldn't get the mahle then...
i would def. pic wiseco over the je, cp, or eagles
Old 04-03-2006, 10:57 PM   #20
bboy
Member#: 56468
04 Improved STI
Dirty White
Many Suby engines have successfully used CP pistons for thousands of very hard miles.
Old 04-04-2006, 01:02 AM   #21
Silverpike
Member#: 92399
Your kidding right?
Most of the high HP Hondas run Wisecos, although the newer fad tends to be CPs. Wisecos have been making import pistons for quite awhile.
Silverpike is offline   Reply With Quote
Old 04-04-2006, 01:20 AM   #22
STEALTH-WRX
Member#: 7822
Multi layer snot green
I just pm'd you. Let me know if you get a chance to read it.
STEALTH-WRX is offline   Reply With Quote
Old 04-04-2006, 02:36 AM   #23
gcm05
Member#: 105948
yeah i think cp has been making them for a while but it's hard to compete with over 82 years experience of the mahle
Old 04-06-2006, 12:31 AM   #24
Sko
Member#: 90396
2005 Legacy 2.5i
After upgrading pistons, consider doing rods too, because your pistons will be able to take a beating that will leave them in fine shape, but will bend/crack/disconnect your rods, trust me, I did only pistons and my rods went, now I'm doing it all w/ 100mm pistons forged with wisecos, eagle rods, balanced crank, etc.
Old 04-06-2006, 12:45 AM   #25
jam69007
Member#: 86968
02 WRX / 05 350Z
'11 335d
manley rods are good, just put a set with some coated weisco's in my friends 4g63
jam69007 is offline   Reply With Quote
what compression ratio on JE pistons? fosingwo Built Motor Discussion 8 02-28-2007 07:08 AM
What happened to the JE Pistons Tour Post? STEALTH-WRX Southern California Impreza Club Forum -- SCIC 1 02-14-2007 12:20 AM
What ingredients other than the alcohol do I need to make Amarreto? STR8OUT Off-Topic 6 11-17-2004 05:07 PM
Forged Pistons and Rods JE Arias Eagle dynoflo Vendor 'For Sale' Classifieds 31 11-22-2003 03:19 AM
Does anyone know what snails eat, other than all the damn plants in my fish tank? PeterJ Off-Topic 9 10-13-2003 04:57 PM
