Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 03-29-2006, 04:42 AM   #1
mistaboosta
Member#: 68722
Default 2.5L crawford shortblock on 2.0L 2004 WRX heads
Hi,
I thought about this combo but the bore of the shortblock is much bigger than the bore of the heads. So wouldn't that damage the heads after some time? Everytime some of the explosion in the cylinder will end up on the surface of the heads.
mistaboosta is offline   Reply With Quote
Old 03-29-2006, 03:55 PM   #2
kcscoob
Member#: 31222
2005 Legacy GT wagon
6 speed, BNR 18G, E85
I think it is the stroke that is the difference on the 2.5 litre. Anyone?
kcscoob is offline   Reply With Quote
Old 03-29-2006, 04:10 PM   #3
02Toyowrx
Member#: 56520
A larger bore will not be a problem. Now if you used 2.5L heads on a 2.0L engine(smaller bore engine) this would not be so good.
02Toyowrx is offline   Reply With Quote
Old 03-29-2006, 07:26 PM   #4
mistaboosta
Member#: 68722
my mechanic insists on it would hurt the heads. how can i persuade him about it wont hurt?
Old 03-29-2006, 11:20 PM   #5
Crawford Performance
Member#: 42075
You could have him give me a call, maybe I can help with his concerns.
760-631-2927
Quirt Crawford
www.crawfordperformance.com
Crawford Performance is offline   Reply With Quote
Old 03-30-2006, 01:09 AM   #6
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
listen to quirt... he is the man...
JonofScio is offline   Reply With Quote
Old 03-31-2006, 08:11 AM   #7
mistaboosta
Member#: 68722
i wish i could.. I'm from europe and my mech. cant speak english
could u explain me shortly so i can tell that to him?
Old 03-31-2006, 01:39 PM   #8
keaniegenie
Member#: 94494
2005 Element 92x
Hi,
If your budget allows for a built shortblock, why not just get 2.5l sti heads too? Your mechanic obviously won't have a problem, the cams and heads flow better, and you add avcs. If you don't get an STI ecu, get a Hydra for your ems. The hydra will control avcs on a WRX ecu.
keaniegenie is offline   Reply With Quote
Old 03-31-2006, 04:27 PM   #9
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
IF you are going to a 2.5L block, you should take advantage of the larger bore and reshape the combustion chambers to unshroud the valves and bump up combustion chamber cc's a bit.
If you don't know anything about how to do this, there are many companies that can port your heads and do some reshaping to get you what you want. Properly shaped combustion chamber will be a great advantage over the stock crap.
ImprezaRSX is offline   Reply With Quote
Old 03-31-2006, 06:23 PM   #10
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
Absolutely correct
I was one of the first to run the 2.5L/wrx head combo in my WRX. A good de-shrouding helped pick up a little more cc and yielded a way better burn.
Good luck
Chris
Crawford/I-Speed is offline   Reply With Quote
Old 04-04-2006, 08:54 PM   #11
chaingreyiv
Member#: 75834
what language does he s peak
chaingreyiv is offline   Reply With Quote
Old 04-05-2006, 07:27 PM   #12
mistaboosta
Member#: 68722
only turkish
2004 WRX heads with cams/2.0l block and crank Antyoo Engine/Power/Exhaust 8 08-13-2007 01:18 PM
2.5L Sti Shortblock with 2.0 L WRX heads - Need STi Dipstick? skimobile Built Motor Discussion 5 06-13-2007 09:53 PM
2.5L Oil Pan on 2.0L WRX theostubbs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-20-2006 10:02 AM
2.5L STI shortblock on JDM heads and ECU? powerlabs Subaru Conversions 3 03-14-2006 08:21 PM
New 2.5l STi shortblock with 2.0l WRX heads? neversatisfied Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 65 06-01-2005 01:33 PM
