Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-29-2006, 01:12 PM   #1
04works
Member#: 91493
2006 STi
P&L Tuned
Default utec stage 4 on automatic?need map!!!!
i have an 04 wrx w/ 2002/2003 ecu (automatic) which means that i can't run open loop on utec. i was wondering if anyone had a map (closed loop)that was close to my setup that they could email me. it would be greatly appricated! following mods-
-greddy cat-back
-invidia dp
-invidia up
-fmic
-vf39 turbo
-810cc injectors
-walbro fuel pump
-bov
-avo short-ram intake
-utec
thanks again,
04works is offline   Reply With Quote
Old 03-29-2006, 02:06 PM   #2
parid
Member#: 16336
2002 WRX Wagon
Thanks for doubleposting.
parid is offline   Reply With Quote
Old 03-29-2006, 05:16 PM   #3
04works
Member#: 91493
2006 STi
P&L Tuned
my bad, this is the question, i edited the other one
Old 03-29-2006, 10:11 PM   #4
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Ant help would be appreciated guys.
Anyone running an auto WRX with a UTEC?
Crazykev is offline   Reply With Quote
Old 03-30-2006, 02:42 PM   #5
AaronWRX
Member#: 7194
2011 997.2 Turbo
jorge (RiftsWRX) knows quite a bit about utecs and automatics.
AaronWRX is offline   Reply With Quote
Old 03-30-2006, 02:43 PM   #6
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Originally Posted by AaronWRX
jorge (riftswrx) knows quite a bit about utecs and automatics.
He tried that route. No help
Old 03-30-2006, 02:46 PM   #7
AaronWRX
Member#: 7194
2011 997.2 Turbo
he should try again. Cant run open loop fueling? hmmm seems like OLF was required for the 04 ecu due to some problems with the transition. Call turboxs and see what they say.
Old 03-30-2006, 09:10 PM   #8
04works
Member#: 91493
2006 STi
P&L Tuned
called turboxs, they didn't have a map?
Old 03-31-2006, 11:44 AM   #9
jabbott
Member#: 73054
2002 WRX 2.5, 4eat
With the new version 5 software you can use injector scalling with closed loop.
Turn on maf scalling and then just adjust the injector size in the olf menu.
That's what i did.
jabbott is offline   Reply With Quote
Old 04-02-2006, 09:26 PM   #10
04works
Member#: 91493
2006 STi
P&L Tuned
seems like everyone is saying you can't run utec on 04 wrx that has an automatic????
i wish they said that on the website before i started the installs!!!!!!!!!!!!!!!!!
Old 04-03-2006, 10:03 AM   #11
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Ironically, they do mention it in the software upgrades page.
See... the UTEC DOES work with an automatic transmission, in closed loop fueling. But due to the fact that the OL/CL fuel transition can be detrimental to an engines life, you sort of HAVE to use OLF on a 04+.
Which in part implies that the UTEC is unusable for a 4EAT.
I still have my UTEC sitting on the desk next to me. One day, I'd hope, they will release something for the automatic crowd. Then I can go back and check out any of the features they have at that time (speed density, etc).
Until then, I'm still using my AccessPort.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 04-09-2006, 02:39 PM   #12
04works
Member#: 91493
2006 STi
P&L Tuned
wtf, i have an 2002/2003 ecu in my car??? i found this out when i couldn't get my new accessport to work(bought one for 04, but i guess thats not going to work. so i installed the utec, just need to get a tune.
Old 04-19-2006, 02:59 PM   #13
04works
Member#: 91493
2006 STi
P&L Tuned
Bump, Bump
Old 04-19-2006, 11:03 PM   #14
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
You still can't use OLF but you may be able to use the UTEC with version 5 firmware. Use the MAF scaling option and use classic MAF mod based fueling.
The 02/03 does not have the closed to open loop delay issue that the 04's have. Not perfect but should work.
mick_the_ginge is offline   Reply With Quote
utec stage 4 on automatic?need map!!!! 04works Engine Management & Tuning 0 03-29-2006 01:09 PM
utec stage 4 on automatic?need map!!!! 04works Newbies & FAQs 0 03-29-2006 12:52 PM
UTEC stage 4 + FMIC maps needed. MJU1983 Engine Management & Tuning 42 04-20-2003 02:26 PM
utec stage 4 map and stage 4 tmi map the same? datdudedennis Engine Management & Tuning 4 03-18-2003 11:37 PM
UTEC stage 4 map with Vishnu stage 2? ChrisWRX Engine Management & Tuning 1 12-25-2002 02:26 AM
