Old 03-29-2006, 01:19 PM   #1
Bigitaly4life
Member#: 107705
2004 WRX
Default Removing AC
this has to be a thread on the site..i'm having a Heck of a time trying to find it. Anyone know how to remove the AC Completely?
Bigitaly4life is offline   Reply With Quote
Old 03-29-2006, 01:28 PM   #2
jamesfacts
Member#: 51282
98 RS
black & blue from parking
yeah, just find all the AC stuff (condensor, compressor, evap, etc) and unbolt it.
jamesfacts is offline   Reply With Quote
Old 03-29-2006, 01:40 PM   #3
Lachlan
Member#: 19470
1981 Brat GL
You'll need to discharge it first (either stick a crewdriver in the "L" hole or take it to a shop that will be more environmentally friendly). I would say once that's done disconnect the lines at the compressor. The compressor is pretty easy to take off, you just need to loosen the belt and then unbolt it. The condenser is in front of your radiator. Just mess around in the unil you can get to its bolts (I don't remember if you have to take the radiator off, but that would probably make it easier). Unbolt the metal cylinder from the strut tower area, and unplug it from the harness. There are two lines headed for the firewall; find where they connect and disconnect them. Then you have to get under your dash (actually you might have to take off the dash to get to it). In the glove compartment area theres some mysterious black or possibly white boxes under there. The one in the middle of the dash is the heater--leave that one. The ones to the right (or to the left if it's RHD) are A/C components (where the lines at the firewall went). Unbolt those and you're done.
Lachlan is offline   Reply With Quote
Old 03-29-2006, 01:59 PM   #4
Bigitaly4life
Member#: 107705
2004 WRX
awesome man..thanks for the quick reply's...i have the entire inside of my car ripped out..its getting fun!
Old 03-29-2006, 08:13 PM   #5
egytian2.5rs
Member#: 96664
V5 STI RA
im pretty sure you do have to take the radiator off to get the condensor out!!
egytian2.5rs is offline   Reply With Quote
removing AC, pulley question Blase M Normally Aspirated Powertrain 2 04-03-2006 11:03 PM
removing ac compressor TurboCharged97L Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-11-2005 10:49 AM
Removing AC... help me... Oo DaRk StAr oO Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-25-2003 09:27 PM
Suggestions for removing AC SpeedRacer-X Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-01-2002 01:49 PM
removing AC???? spunky General Forum Archive 2 11-16-2000 08:26 AM
