Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 03-29-2006, 03:54 PM   #1
takemetoothemoon
Member#: 96838
2002 Impreza TS Wgn
Western Subaru Club
Default Taking off fog lights to change bulb
I tried to take off one of my fog lights to change the bulb but it was striping the screw. Is there a special screw driver I should be using?
I was just using a normal Philips
takemetoothemoon is offline   Reply With Quote
Old 03-29-2006, 05:38 PM   #2
SPIDEYWrX
Member#: 36109
I changed mine a few months ago,, and as far as I can remember, it was a phillips,, just make sure its big enough to fit in, and long enough to get some good torque on it.
SPIDEYWrX is offline   Reply With Quote
Old 03-29-2006, 08:50 PM   #3
bezerk
Member#: 44809
2008 BMW M3
SATURDAY!!!!!!!!!!!!!!!
No, just a Phillips, but I do find that some (wrong size) would tend to strip mine too.
bezerk is offline   Reply With Quote
Old 03-30-2006, 01:34 AM   #4
ryeguy
Member#: 70105
WR Blue
Use a 10mm socket...or is it 12mm..use that anyway to sovle any stripping problems...
ryeguy is offline   Reply With Quote
Old 03-30-2006, 11:50 AM   #5
chris'wrx
Member#: 94359
i stripped mine so i had to drill it out.
chris'wrx is offline   Reply With Quote
Old 03-30-2006, 09:19 PM   #6
ryeguy
Member#: 70105
WR Blue
Had one where I took the head right off too....
Old 03-30-2006, 11:57 PM   #7
pinkrobe
Member#: 55447
2002 WRX wgn/'10 STI
WRB/grey
Yah, they can corrode into place. I would use a socket and an extension to get in there. It's a 10 or 12 mm, I can't recall which. I was able to put mine back with a 10" Philips that I usually use for snowboard bindings.
pinkrobe is offline   Reply With Quote
Old 03-31-2006, 06:27 AM   #8
DO
Member#: 5553
2002 impreza wagon
I already broke 2 of the bolts holding the foglight.YOu can buy the backing plate at a subaru dealership if needed. I think it was around 20$.
To help prevent breaking future bolts, I used anti seize compound.
DO is offline   Reply With Quote
Old 03-31-2006, 11:09 AM   #9
CRXguy
Member#: 25370
2003 WRX wagon
Played Out Blue
you dont need to remove the foglight to change the bulbs. pull off the plastic piece underneath the car and you can work from there.
CRXguy is offline   Reply With Quote
Old 03-31-2006, 12:41 PM   #10
thejean
Member#: 17763
WD40 & antiseize are your friends. And yes, it is a 10mm socket but even then you can twist the head off. I do this twice year when I swap out my winter/summer bumpers.
thejean is offline   Reply With Quote
Old 04-01-2006, 12:19 AM   #11
ryeguy
Member#: 70105
WR Blue
only if you are a contort that way.....
Old 04-01-2006, 12:19 AM   #12
ryeguy
Member#: 70105
WR Blue
only if you can contort that way....
Old 04-03-2006, 02:53 PM   #13
takemetoothemoon
Member#: 96838
2002 Impreza TS Wgn
Western Subaru Club
Well I used WD40 and a deep socket. I ended up breaking off two of the nuts the bottom left one on each fog light. So today my fog light covers arrived I need those 2 holes to put them on
So how do you take out the broken bit in the hole?
Old 04-03-2006, 03:17 PM   #14
Lizardeye
Member#: 109640
2006 wrx
steel grey
Drill a small hole in the middle, counter-clockwise. Then, drive a screw in, counter-clockwise until the whole bit come out
Lizardeye is offline   Reply With Quote
Old 04-03-2006, 05:00 PM   #15
thejean
Member#: 17763
Or you could drill out and tap.
Old 04-09-2006, 08:16 PM   #16
takemetoothemoon
Member#: 96838
2002 Impreza TS Wgn
Western Subaru Club
Well i tryed to drill it out but it is still in there, and i drilled out some of the theards. so how do i replace this part?
i think i am going to take it to subaru and have them fix it for me so i can put my fog light covers on or if it cost to much sell my fog light covers
any one know how much that part will be?
Old 04-10-2006, 07:13 AM   #17
DO
Member#: 5553
2002 impreza wagon
See post #8.
Its easy to replace, but if the dealership is willing to do it for cheap, then go ahead and have them replace it.
Old 04-10-2006, 03:15 PM   #18
takemetoothemoon
Member#: 96838
2002 Impreza TS Wgn
Western Subaru Club
oh thank you i did not see that
How to change bulb in 04 Driving light? Pikey Interior & Exterior Modification 14 03-04-2010 10:28 PM
how to change bulb in brake light? scooter4483 Mid West Subaru Owners Club Forum -- MWSOC 5 06-24-2008 08:34 PM
how do u take off fog light covers? STi-MAN Interior & Exterior Modification 3 11-21-2004 12:56 AM
Taking off fog light grilles...... Juustncase Legacy Forum 1 10-31-2004 01:12 AM
