Old 03-29-2006, 04:24 PM   #1
super laubo
Member#: 108314
2005 Silverstreak
Default Economy Maps????
Hi All,
I've been reading alot about increasing the stages, but there isn't alot of information on the Cobb website and this forum about the economy maps. Got a few questions:
1.) once stepping up to Stage I or II, does the economy map work? In other words, is it backwards compatible?
2.) how is your gas milage when using the economy map?
3.) in your opinion, is the gain worth switching maps?
I drive alot during the week for work, and would like to use the econ mode to save gas.
Thanks!!!
super laubo is offline   Reply With Quote
Old 03-29-2006, 05:02 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
1 yes it works. 2 About 2MPG better. 3 Not when you decide to step on it and it's a dog, Cobb should have allowed it to reach stock boost levels for when you are at 100% throttle... this 8PSi sucks. Other than that it does everything claimed.
wrxdrvr is offline   Reply With Quote
Old 04-02-2006, 08:52 PM   #3
yakkosmurf
Member#: 81931
2008 STI (Stage 1)
WR Blue Mica w/ Gold BBS
I simply load the economy real time map over my Stage 1 map. Works great. I get about 2 to 3 mpg better. Given that the real time map takes 20 seconds to change, it's worth it. I also didn't find the power as bad as you might think. It was more than enough for a road trip. I wouldn't use the econo map in the city, however...
yakkosmurf is offline   Reply With Quote
Old 04-12-2006, 11:05 PM   #4
super laubo
Member#: 108314
2005 Silverstreak
so i'm guessing the econ. maps are worth it?
anyone else?
Old 04-13-2006, 01:38 AM   #5
Payback
Member#: 41328
2003 WRX Sedan
SOLD - 2/07
The econo map is designed for the city, not the highway. On the highway at cruising speed, you aren't even on boost. Stop and go is where the econo was meant to be used.
Payback is offline   Reply With Quote
Old 04-13-2006, 06:33 PM   #6
k mier
Member#: 98000
05 sti [email protected]
Made an almost 400 mile roundtrip combined hwy/city. In econo mode I averaged 25.6, with stage 2 almost exactly the same trip two months earlier I averaged 25.3. The drop in power can make things more exciting city driving. Let me mention, for the most part I drive with a very light foot and seldom hit boost. For me the econo map was a waste of time, even if it only takes 30 seconds to load. Now if you are a person that likes to hear the whine at every stop light it might make a big difference.
I can't find the paper I wrote the #'s down on so the mpg's could be 23.6 and 23.3, still it was only .3 mpg's difference.
k mier is offline   Reply With Quote
Old 04-13-2006, 08:59 PM   #7
trbo-4
Member#: 105455
2004 WRX Wagon
Cobb Stg. 2
Sounds like its not worth the drop in power for such low mileage gains. I didn't even load those maps on my AP.
trbo-4 is offline   Reply With Quote
Old 04-13-2006, 09:06 PM   #8
fantomas
Member#: 87500
2012 Outback 2.5i P
Graphite Gray
i've found the economy map makes too little of a difference to be useful. in order to get better gas milage, keep off boost. not quite a hard concept, but i've seen stage 2 STi's getting 25 mpg.. because they don't race around with their car. sometimes on economy map while driving through the city, i really regret it. its slow as sin. use it if you need that extra "kick in the ass" to make you drive slower.
fantomas is offline   Reply With Quote
Old 04-14-2006, 12:20 AM   #9
Payback
Member#: 41328
2003 WRX Sedan
SOLD - 2/07
I agree that it's not worth the 30 seconds to load. If you want to save gas, drive gently. With average driving on my last tank, I got 26 mpg on the OTS Cobb VF34 map. Living in the flat desert helps too. Some people refer to things called "hills" and "mountains" that seem to lower the milage. Not too sure what they are refering to though.
Old 04-14-2006, 08:22 PM   #10
MdWRX
Member#: 69636
2002 Wrx
Sedona Red
I used the econ map for the last 2 tanks, I do mostly 'highway' driving but there are alot of hills and curves and you always have to stop for a tractor or something with the econ map I got about 26 mpg, when I leave it on stage 1 I usually get about 28mpg.
MdWRX is offline   Reply With Quote
Cobb AP - economy map txl146 Engine Management & Tuning 12 04-20-2005 10:26 AM
Anyone have a good fuel economy map? cartervt2k Engine Management & Tuning 6 03-30-2005 06:15 PM
Cobb Accessport Economy Map...Anyone? Oldalfaguy Engine Management & Tuning 9 03-04-2005 10:59 AM
Cobbs economy map boost? engr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-08-2004 11:55 AM
Cobb economy map grozgon Engine Management & Tuning 2 06-21-2004 10:54 PM
