Old 03-29-2006, 09:12 PM   #1
subasteak
Member#: 102485
97 legacy outback
white
Default tranny swap question?
Ive got a 93 impreza with some tranny problems and i just got a paarts car thats a 96 or 97 and i was planning on swappin the tranny from that into my car along with the rear disc brakes and and struts(my rears are blown) and i just wanted to make sure that this will all work! any comments and feedback will be awesome! thanks!
Mike
subasteak is offline   Reply With Quote
Old 03-29-2006, 09:36 PM   #2
adhowe70
Member#: 3363
1982 Reynard
Blue, Red, and White
Piece of cake!
Swap all of the drivetrain from the newer car... transmission and rear diff. You'll swap the whole rear hub assemblies for the brakes AND the parking brake cables (so don't cut those!) Struts are an hour job, but do those when you do the diff and brakes.
Edit: You swap the rear diff because you want to make sure that the transmission / diff are the same final drive ratio. You could verify what you have and verify the transmission's FD ratio and not bother with rear diff swapping.
adhowe70 is offline   Reply With Quote
Old 03-29-2006, 11:02 PM   #3
subasteak
Member#: 102485
97 legacy outback
white
thanks alot adhowe70 thats what i thought i had to do but i just wanted to make sure. Thanks again
Mike
Old 03-30-2006, 12:12 AM   #4
adhowe70
Member#: 3363
1982 Reynard
Subarus are very swap friendly. Just about everything bolts straight up.
My current project is a '96 Impreza with an H6 engine, a WRX transmission case with RA gears and a Legacy 4.44 viscous limited slip rear end. The rear brakes are off of an early Legacy turbo and the front brakes are off of a WRX. So far, I've haven't even needed to swap a subframe.
Old 03-30-2006, 12:50 AM   #5
suberdave
Member#: 101865
88 GL-10 STi
for that mater. i put a 96 WRX engine trans and diff in my 88 GL wagon, and it was all bolt up, with some major wiring work. but thats a different story.
"just think LAGO's"
-=Suberdave=-
suberdave is offline   Reply With Quote
Tranny swap question? 95 leg greenscoobie86 Transmission (AT/MT) & Driveline 3 11-10-2004 10:53 AM
Legacy Tranny Swap Questions WagonDave Subaru Conversions 5 06-09-2003 05:06 PM
Tranny swap question shipjumper Transmission (AT/MT) & Driveline 0 01-18-2003 11:57 AM
Tranny swap question. dbrown Mid West Subaru Owners Club Forum -- MWSOC 1 10-26-2002 12:08 PM
Tranny swap questions wolkomir Technical Forum Archive 4 06-28-2000 09:01 AM
