Old 03-29-2006, 11:24 PM   #1
JDMSUBAROO
Member#: 106823
2000 v8 rsti
Default 05 Sti Swap In 00' Rs ?
I am probaly about to purchase an sti swap out of a 05 sti and put into my 00 GC8 body impreza. I have a few questions before i commit myself to buying anything.
Can i retain the stock transmission from the car(RA Gearset) and just put the sti engine and wireing in?
can you swap this engine in and have it work with all the gauges and instruments?
How difficult is the harness swap, and would this be somehting i can do myself with the right schematics and some pacince?
Is it a myth that you need the sti gas petal assembly for the swap to work?
Also, if anyone has anymore information about this swap i would appreciate the help
JDMSUBAROO is offline   Reply With Quote
Old 03-30-2006, 01:41 AM   #2
Kaymin
Member#: 96076
RIP 96 SBM GC8
05 Burnt Orange Evo
I think the engine and wireing have something to do with the transmission so it might not work using the old tranny but anything can be done with enough time and what not. I also might be thinking of something else, just wait till someone who knows what they're talking about comes on here. I'm just going off what i've heard before.
The Harness if you have enough patience and time and probably some help its possible.
i think the gas pedal assembly thing is right.
but how do you have a stock transmission with RA gearset? or did you mean you added the RA gearset?
Kaymin is offline   Reply With Quote
Old 03-30-2006, 03:58 AM   #3
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
all this information is a "search" button away...
in short.... you can retain your tranny, all gauges will work if wired correctly, you need ECU, wiring harness AND pedal assembly to retain DBW, otherwise you have to convert the intake mani to the traditional cable setup
Hyper is online now   Reply With Quote
Old 03-30-2006, 06:55 AM   #4
Kraziken
Member#: 38629
1999 Legacy GT (STI)
Because of the conversion and some of the things that may differ with the cars, you may not completely get everything to work correctly.
Gauges will work fine. Some of the idiot lights may not work. My cruise control button does not light up when engaged. It just works differently in the STI versus my Legacy.
Also, I've lost the "low fuel" warning light. I almost got stuck once since the engine swap.
I'm not sure I understand what you mean by RA gearset as well. In my case, my mechanic used a WRX case, so we could use a PULL type clutch, and he rebuilt the transmission using my Legacy gears and 4.11 final drive. I was then able to use a WRX Exedy Heavy duty clutch. A lot of people have been afraid of me breaking gears, but so far so good.
Kraziken is offline   Reply With Quote
Old 03-30-2006, 07:58 AM   #5
JeremyRS
Member#: 65126
00 Leggy Wagon
99 Silverado, 06 HD
IMOBILIZER in 05
JeremyRS is offline   Reply With Quote
Old 03-30-2006, 03:49 PM   #6
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
I just started this swap last weekend 04Sti into 02rs...near completion
It rilly aint hard at all just some time to rewire a few things:
Pulling out the harness and transplanting the other in is fairly simple ( remove dash down to the firewall ) If the harness is run the same way in the 2000 as my 02 you wil need to pull both front fender wells. I have yet to find any plugs that dont mate rite back up to their other in the dash and engine. Except for tranz plug and HVAC. My power stearing pump line was different so I just put the RS pump on to the STi motor. Now is a good time to ditch your AC if you never use it like me.
To answer your question like the others above did. You wil need a STi petal or convert the TB to cable. The trans will bolt rite up, you wil have to pin out and splice the plugs for reverse lite and a few other items. If you get a new clutch and or fly wheel make sure you get it for the tranz type ( not the motor ) All gauges will work, I would recomend an STI cluster though just to get as much to work perfict as possible. Also get an EGT,H20 temp( if your using water cooled turbo ) ,oil temp,oil presure gauges sooner than later. Better to know what is goin on than find out after your motor is blown. Think about getting your tranz rebuilt in the future too
dangerousatom is offline   Reply With Quote
Old 03-30-2006, 11:13 PM   #7
Kaymin
Member#: 96076
RIP 96 SBM GC8
05 Burnt Orange Evo
isn't the 02 harness Way different from the 00?
Old 03-31-2006, 09:30 AM   #8
dangerousatom
Member#: 70710
I am unsure, that would be why I said..... "If the harness is run the same way in the 2000 as my 02". If its anything like the differences between the 02rs and the 04STi, they go to the same places but the RS is routed a lil different when it comes to the front end of the car.
Complete 05 sti swap in a 02 ts touz Member's Car Gallery 74 06-06-2010 07:53 PM
1998 rs br red 05 wrx swap in pa Rdwrc Private Vehicle 'For Sale' Classifieds 89 01-25-2010 09:54 PM
looking to start a 04/05 sti swap in an 02/03 bugeye need shopping list 02MidnightPearlRS Subaru Conversions 2 03-09-2008 04:08 AM
FS: 1998 2.5 RS with Full USDM 05 STi Swap bdr2488 Tri-State Area Private Classifieds 10 05-07-2007 02:36 PM
05 sti swap in my 2000 RS crazyGC8 Normally Aspirated Powertrain 3 02-24-2006 02:41 PM
