Old 03-30-2006, 02:21 PM   #1
Chiketkd
Member#: 71634
In hibernation...
Default Highest whp & best 1/4 mile w/ a VF39 on a 2.5L block on only pump gas?
Looking for dyno numbers or 1/4 mile times on tuned 2.5L VF39 set-ups on just pump gas (no race gas or alky injection).
I'm thinking about doing a VF39 install w/ STI intercooler, Cobb AP and a protune later this year....
Chiketkd is offline   Reply With Quote
Old 03-30-2006, 02:26 PM   #2
Chiketkd
Member#: 71634
In hibernation...
FYI, I've seen these numbers Cobb posted for a VF39 w/ STI TMIC and their ots MAP for the '06 WRX:
And I've also seen the ots dyno plot for their Stage 2 STI:
Old 03-30-2006, 10:02 PM   #3
brranger
Member#: 99197
2006 WRX 6 speed
dyoned at 281 on a dyno pack at PDXtuning and ran a 13.2 with a 1.9 60 ft
was my first time to drag strip, first few runs were 2.1 and 2.0 60 fts and slowest time was a 13.4. thats with a vf39, sti tmic and protune, everything else is stock even still running the 215 stock tires.
brranger is offline   Reply With Quote
Old 03-30-2006, 10:38 PM   #4
edmundu
Member#: 54672
What were your trap speeds?
edmundu is offline   Reply With Quote
Old 03-30-2006, 10:59 PM   #5
brranger
Member#: 99197
2006 WRX 6 speed
r/t .485 .792
60' 1.901 2.063
1/8 8.456/ 83 mph 8.645/84 mph
1/4 13.216/ 103.5mph 13.358/ 104mph
these were my better runs the other two were a 13.4/102.45mph and a 13.7/103mph
Old 03-30-2006, 11:15 PM   #6
Chiketkd
Member#: 71634
In hibernation...
Nice times and set-up! With those trap speeds and a 1.7-1.860ft, you could be in the 12's!!!
Are you using 91, 92 or 93 octane out in WA?
Old 03-30-2006, 11:22 PM   #7
brranger
Member#: 99197
2006 WRX 6 speed
using 92 here
Old 03-31-2006, 12:24 AM   #8
Trevor723
Member#: 57989
2013 Golf TDI
united gray
Don't remember the dyno numbers but..
Cobb downpipe (cat), borla hush, perrin short ram, UTEC tuned by F1Dyno, pure 93 octane:
12.891 @105
Trevor723 is offline   Reply With Quote
Old 03-31-2006, 12:32 AM   #9
Drews_WRX
Member#: 20354
2005 SRT-4
POS Mopar stage 2
im guessing COBBs OTS VF39 map for the 06 WRXs will be good for 106-108mph trap speeds......you heard it here first.
From what Ive seen, COBBs mustand read about the same as dynojets, and with about 260-270whp on a dynojet, you should be able to run the above times.
Drews_WRX is offline   Reply With Quote
Old 03-31-2006, 12:53 AM   #10
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
Mods:
Full Invidia TBE
Cobb AP Stage 2 93 Oct v1.02 base map, Stage 2 LWG 93 oct v1.03 realtime map
R/T: .591
60': 2.116(i'm a n00b)
330: 5.750
1/8: 8.717
MPH: 82.96
1000: 11.286
1/4: 13.444
MPH: 104.8
dsmperformance is offline   Reply With Quote
Old 03-31-2006, 01:41 AM   #11
STimo
Member#: 110273
450 whp 30R STI
[email protected]
MODS: Stromung TBE, CAI, Ecutek, 255lph fuel pump, turbo inlet hose.
Tuned on 91 but at the track i was runnin 101 even though it probably didnt do that much.
Best run: 12.56 @ 109.8 with 1.6x '60
STimo is offline   Reply With Quote
Old 03-31-2006, 11:21 PM   #12
Chiketkd
Member#: 71634
In hibernation...
Tuned on 91 but at the track i was runnin 101 even though it probably did nothing.
Even though your car was tuned on 91, understand that the factory ecu always tries to advance timing as much as possible until knock is detected. Running 101 would therefore have raised the threshold before your ecu started to pull some timing. Your 109.8mph trap speed indicates that your car was responding very well to the higher octane!
Old 04-01-2006, 06:36 PM   #13
STimo
Member#: 110273
450 whp 30R STI
[email protected]
yeah it made a diff. for sure. What i ment was it didn't do that much compared to being tuned on race gas. My best mph with 91 is 107.1 so almost 3mph between crap 91 and 101 untuned is pretty good for just gas.
Old 04-01-2006, 08:20 PM   #14
SolidSnake
Member#: 74034
2004 426whp 403wtq
Top Speed Tuned STi!
Back when I was pretty much stock with a TBE (catless), intake, and off the self AP stage 2 93oct map I ran a 1.69 -60ft 12.7 @ 107, never dynoed back then, so not sure on whp.
SolidSnake is offline   Reply With Quote
Old 04-02-2006, 08:05 PM   #15
RChampion
Member#: 21481
99 2.5RS
14 Impreza STI
A friend of mine made 280ish (maybe 290) whp and 330ft/lbs on a dynodynamics dyno with his stock turbo. I wonder what he'd make on a dynojet.
Maddad exhaust, W/I, ecutek
RChampion is offline   Reply With Quote
Old 04-02-2006, 09:42 PM   #16
Imprezzive STi
Member#: 68706
2004 STi
i made 290whp/350wtq on 93 octane on a dynojet stock turbo + headers
Imprezzive STi is offline   Reply With Quote
Picture Thread:::Official Ocean City AWD Meetup June 4-6 2010:::Picture Thread mator Mid Atlantic Impreza Club -- MAIC 277 07-06-2010 12:49 AM
NEED help! 2.5RS in Central Jersey pMak26 Tri-State Area Forum 9 06-04-2010 08:50 PM
maybe im on my period, but this made me tear up Indocti Discant Off-Topic 31 06-03-2010 09:44 PM
Head info needed,2.5 2003-2004 JDM DOHC w/AVCS PoZeR Normally Aspirated Powertrain 1 06-03-2010 12:09 PM
Hydra install on oldschool? tenchu Other Engine Management 0 06-03-2010 04:37 AM
