Old 03-30-2006, 02:35 PM   #1
WallyKincaid
Member#: 90566
1999 Legacy 2.5 GT
I want JDM WRX!
Default For those who went JDM.
Im looking at buying a complete JDM WRX. However I have another thread about all that and its not my issue for this one (newbies forum if youd like to offer more help).
I want to know the downsides of the JDM parts.
Do you find it hard to maintain these cars/parts?
How is wear and tear on them?
If something breaks, do you have to order from Japan for a replacement?
What sort of parts are compatible with US?
Can US mechanics generally work on these fine?
I do search, I do lurk, and Ive been reading these boards for a while. Im just trying to pull all the info together I can to see if I should try to go through with this deal.
WallyKincaid is offline   Reply With Quote
Old 03-30-2006, 03:52 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
There is a lot of parts compatibility across the model ranges regardless of which generation WRX you get. If you are getting a newer (MY00+) JDM swap, a lot of USDM WRX parts will work. For earlier cars, it's a mishmash of Ej18 and Ej22T parts that fix most issues that arise.
Some things either need to come out of Japan or the UK. One item in particular that comes to mind is head gaskets. There are also some North America vendors like LaChutes, Rallispec, Gruppe-S, Fineline, and a number of other who keep some stock of JDM parts on hand.
As far as mechanics? most dealership mechanics are too book trained to be willing to touch such a "strange" car. But there are lots of independents who know that these cars are just like legos and will be more than happy to work on your car. Post a thread in your regional forum to find out who in your area will do that kind of work. Eastcoastswappers is one group of people that comes to mind of the top of my head. And Rallispec is in NJ...
Old 04-02-2006, 07:47 PM   #3
tweakling
Member#: 33072
'95 EJ20g v1 STI RA
BRP, 2001 GC8 chassis
Like Matt said, there are a lot of basic, integral parts that are interchangeable between the different models. For example, the power steering pump on my EJ20g was busted, and I was able to use the one from my old EJ25. The pump itself was exactly the same, although I did have to take them both completely apart and swap over the resevoir and a couple other components in order for it to fit right. I haven't encountered any other problems so far that required OEM replacement parts.
Also as Matt said, don't expect very much help from dealerships. Your best bet would be to find a performance shop that has a lot of Subaru experience. Chances are, they'll take interest in your car since it's relatively rare, which means they'll be more willing to help you out. If they're any good, they'll be able to use a little improvisation and ingenuity to figure out a solution for almost any problem that comes up.
-Rob
tweakling is offline   Reply With Quote
Old 04-02-2006, 08:30 PM   #4
spulinup
Member#: 63880
1998 Doom Wagon
swapped GF8 with jdm ish
Talking Jdm motors
I have an ej20g and have only had trouble with the power steering pump so far (knock on wood). I beat on the car everywhere I go and I feel like the motor is just made better the my 02 wrx. The smoothness and sound is more consistent and extra power doesn't hurt either.
As for parts, luckily there is a local shop called outback motorsports that has really helped me out. They have at least twenty JDM long blocks at their shop ranging from single to twin turbo motors most of which are all older. They use the motors for sandrails so they don't need most of small parts on the motor because they do custom set-ups. They are more than fair with their pricing so if you go with an early version motor look them up. My JDM up pipe cracked and they sold me a new powdercoated one for 60 bucks.
As for replacement parts that need to be brand new (belts, pumps, gaskets) most of the parts are the same as one of the usdm parts you just need to take them with you and find the corresponding motor. ( I took a blown radiator hose to the dealership and ended up with an early legacy turbo hose.)
My only suggestion is that if you go with an older model replace all of the hoses, water pump, oil pump, timing belt and cam seals before you drop the motor in that way you get a fresh start with the motor. My motor was off one tooth on each of the cam gears on the right side so I'm glad I freshened up the front of the motor.
Good luck
spulinup is offline   Reply With Quote
Old 04-05-2006, 10:53 PM   #5
nickjl
Member#: 106313
2002 Impreza
Is there a USDM crossover radiator for a JDM 1994 EJ20G?
nickjl is offline   Reply With Quote
Old 07-13-2006, 09:36 PM   #6
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
early 90's legacy turbo i beleive
John2.5RS is offline   Reply With Quote
Old 07-14-2006, 09:34 AM   #7
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Some downsides:
The motor is old so expect some issues.
The headgasket will probably give up sooner or later.
The original rad will be at or near its end.
The coils on the Gs often fail and are fairly hard to source.
The seals should all be replaced.
The A/C system is difficult to get working correctly.
Cruise control is also a problem.
It's a really good idea to have access to a shop that knows what they are doing. You should also have $3k on standby when something major breaks.
linsavy is offline   Reply With Quote
Old 07-14-2006, 10:06 AM   #8
subenick
Member#: 48968
1999 impreza 2.5RS
Go version 7 and newer and you find parts are almost 100% interchangeable with our usdm wrx counterpart of the same MY!
Not to mention the engines are in pretty much new condition and will offer great reliability, especially for the high power output!
subenick is offline   Reply With Quote
Old 07-14-2006, 11:54 AM   #9
Osgood30
Member#: 20437
1999 Impreza RS
STI Ver7
I went with version 7 motor and tranny. I was able to get tons of small little parts for WRX for the motor, and all the transmission parts are the same as USDM STI.
Alex
Osgood30 is offline   Reply With Quote
Old 07-15-2006, 10:54 AM   #10
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
Can't you use the steering pump and AC from the USDM body?
I'm just in the middle planning stage for a JDM swap and was planning on using the PS pump, AC, and alternator original to the body.
Is that a no-go?
cjfike is offline   Reply With Quote
Old 07-15-2006, 01:02 PM   #11
Osgood30
Member#: 20437
1999 Impreza RS
STI Ver7
cjfike, you can use USDM STI power steering pump. I have it on my V7 motor. AC compressor you need to use from your RS motor. It fits, and its the only one that would connect to you hoses.
Alex
Old 07-16-2006, 12:33 AM   #12
cjfike
Member#: 60116
1999 RS Coupe
Silver Thorn
Cool. Thanks!
Old 07-16-2006, 12:52 AM   #13
kheff46
Member#: 66739
2002 WRX wagon
only US parts i have left are: wiper motors, a/c condensor, PS rack, horn, wiper jug, and interior bits. and my 98 V4 isn't that old considering the mileage on it. finding parts hasn't been bad...yet.
--keith
kheff46 is offline   Reply With Quote
for those who went wingless... chicago06sti Interior & Exterior Modification 43 09-02-2009 04:05 PM
For those who went to Stage 2 with your WRX & STI AuburnWRX Newbies & FAQs 47 02-21-2008 03:55 AM
for those who went RHD Jaxx Subaru Conversions 12 03-06-2007 10:38 PM
How was the sno drift event for those who went? awdguy Mid West Subaru Owners Club Forum -- MWSOC 11 02-02-2005 10:12 PM
For those who went from RS->WRX, and those who didn't danc General Community 32 03-12-2002 11:16 PM
