Old 03-30-2006, 03:25 PM   #1
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Default pop-up pistons...
Anybody make them for a 2.5? (12:1 compression or better?)
HamFist is offline   Reply With Quote
Old 03-30-2006, 03:42 PM   #2
herewegoagain
Member#: 107778
2006 Legacy GT Sedan
Obsidian Black
I think Paeco does. But their customer service sucks.
herewegoagain is offline   Reply With Quote
Old 03-30-2006, 10:04 PM   #3
Crawford Performance
Member#: 42075
We design custom pistons for any application
Quirt Crawford
www.crawfordperformance.com
Crawford Performance is offline   Reply With Quote
Old 03-30-2006, 11:07 PM   #4
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
No offense quirt, but I wanted to see if anything was available off the shelf. That piston does look nice. I give people the benefit of the doubt, and I don't want to trudge up any crap. But, how well do they fit? I avoided that whole thread except for a parody "for rent" post .
Old 03-31-2006, 08:27 AM   #5
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
yeah actually, my first mention was going to be crawford, but he already whored out this thread with his huge, and sexy picture of a piston already. hey, if I could get that picture on a huge poster, I'd put it in my room. Think that would make my fiance jealous?
TWE also makes high CR pistons. look for them at rallitek. 11.2, I think they had 12:1. But you're looking at more than CP (crawford performance) sell his pistons at. He sells his sets for a little under $600, but I don't know if he would make you up a nice new 12:1 piston set made for the EJ25 head at that price.
I'll see if I can find any other manuf. that make high CR pistons... one sec...
whoa damn. rallitek sure changed their page. no more high CR pistons it seems... maybe they still carry them. I couldn't find (google) JE or Wiseco high CR pistons.
TWE DOES have 12.5:1 (made for DOHC head chamber) EJ25 pistons, and the other piston sets are at $700+. so who KNOWS how much they cost. But I'm sure they are pretty nice. *cough* crawford. *cough*
JonofScio is offline   Reply With Quote
Old 03-31-2006, 10:26 AM   #6
Member#: 42075
No offense taken HamFist
An off the shelf piston at 12:1+ compression might be hard to come by, but the internet is a great tool... I do not understand your question about "how well do they fit", could you please explain?
Quirt
Old 03-31-2006, 01:55 PM   #7
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Quirt
+1. Quirt will send you pistons to spec and you size (hone/bore) your bores to fit.
TypeC is offline   Reply With Quote
Old 03-31-2006, 03:21 PM   #8
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
Go to TWE. They have high compression pistons that due to their "high quench" design can run lower octanes than other piston designs.
Basically what that means is you can run more timing than other piston manufactures and get more torque with slightly leaner AFRs.
They did afterall make a 300HP N/A subaru 2.5L.
ImprezaRSX is offline   Reply With Quote
Old 03-31-2006, 03:24 PM   #9
banzai
Member#: 63926
Axis /RAW 2.2 Closed
deck EJ 20G stroker
It's not a good idea to bore/hone off what someone tells you. wait until you have the pistons in hand so the shop can match them to the individual cylinders.
banzai is offline   Reply With Quote
Old 03-31-2006, 03:51 PM   #10
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
That's what I was saying. Order 99.5 or 100mm pistons, and give the machine shop the pistons and block.
Old 03-31-2006, 03:53 PM   #11
banzai
Member#: 63926
deck EJ 20G stroker
apologies, i misunderstood.
Old 03-31-2006, 04:07 PM   #12
HamFist
Member#: 2112
2000 Impreza 2.5RS
BRP
Quirt, I was curious about the clearances for your pistons. I didn't want the piston/bore clearances to be too loose. I'm looking at taking my factory n/a 2.5L and just honing the cylinders. The block has 58k miles on it. Upgrade to Crower or Eagle rods and clevite bearings and reuse my stock crankshaft. The overall bore/stroke dimensions would stay the same for my engine. TWE would have a slight bit of bias for me because they would very likely fit their own camshaft specs, too. I don't want valve/piston contact. Redline will be a conservative 7k and I plan on using alcohol.
What's just as appealing is reusing stock pistons with better rods and new bearings and staying at 10:1 compression. Wait for my blower kit to be done and just run 5psi with E85, cams, and a retune. I should have enough there to make well in excess of 300hp.
Old 03-31-2006, 06:33 PM   #13
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
you'd be better off upgrading to the twe pistons anyway. Even if you use the same compression ratio you will get more power from the setup. You could go down to 9:1 and bump the supercharger up to 10psi easy with lots of room for more.
I'd just pay the extra 200 bucks to get the cylinders bored to 100mm and fitted custom to your pistons. It's the only way to ensure your clearances are correct. If you try to slap in 99.5mm pistons, no matter who they are from, your chances are low that you'll be noise free.
Old 03-31-2006, 11:50 PM   #14
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
I had my machine shop measure and hone my cylinders to fit 99.5mm pistons with .0026" PW clearance. The factory service limit is .002, so assuming the sleeves are straigh (Taper, round, etc) the normal bore should fit. But then again, this was on a 5K mile block.
But yeah, if they are custom pistons, you'll be SOL if they don't fit (no exchanging).
Old 04-01-2006, 02:02 PM   #15
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
yeah, 5k and 58k are a bit different.
If you were able to achieve those tolerances on each piston that's awesome. Was your block an all A or all B block? all my blocks except one have been ABAB blocks. Did they do it by a data sheet or did they actually measure each piston?
Pop up gauge pod? tailout Interior & Exterior Modification 34 08-17-2006 03:54 PM
this girl keeps popping up in every single pop-up ad... xfactor834 Off-Topic 6 10-13-2003 06:34 PM
hey if any houston guys get a CEL light pop up jmott Texas Impreza Club Forum -- TXIC 7 09-06-2001 01:50 PM
('93-'01) Select which forums pop up - like the old days? Mike Smith Impreza Forum 2 07-25-2001 11:13 AM
Pop up ads on the site? Opie General Forum Archive 7 12-04-2000 10:45 AM
