Old 03-30-2006, 07:38 PM   #1
Norcalrallyist
Member#: 15510
1993 MY94 WRX
Default Swaping ver1 sti drivetrain into 93
Im going to start this project by doing the "easy stuff" first until I pass smog for registration purposes in July and I figured swapping the rear diff, hubs and 5MT would be a nice start. My 93 is an A/T. I have the jdm pedals is but is there any special considerations I need to take when doing this swap from A/T? Like do I have to cut holes in the firewall for the clutch master cylinder? Will these pedals bolt up under the dash? Are the axles the same?
Norcalrallyist is offline   Reply With Quote
Old 03-30-2006, 08:13 PM   #2
kheff46
Member#: 66739
2002 WRX wagon
hole in firewall already exists for brake MC. just pop the rubber plug out of the firewall, and install MC. you have to take care of the neutral switch issue. the pedals will bolt in, despite what some have said on here. i just did it, but can't put any pics up yet to disprove the masses(getting DSL)! axles im not 100%sure. i think the auto driveshaft is a different length, but i think axles are same. please verify before oredring anything. hope this helps some. good luck! keep us posted -keith
kheff46 is offline   Reply With Quote
Old 03-30-2006, 09:45 PM   #3
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
How are you going to pass CA emissions with a JDM motor???
Old 03-31-2006, 11:48 AM   #4
Norcalrallyist
Member#: 15510
1993 MY94 WRX
I have no idea.... Most likely I am not going to pass here because im moving to either Austin or Seattle.
Old 03-31-2006, 12:02 PM   #5
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
the JDM pedals won't work unless you're converting to Right Hand Drive.
With the JDM pedals, the clutch master cylinder bolts on right inline with the clutch pedal.
with the USDM pedals, the clutch master cylinder bolts right inline with the gas pedal, and then there is an intermediate rod that goes between the clutch pedal and the master cylinder to actuate it.
If you want pictures of the USDM pedal set, let me know. You can see the differences.
wrx_driver_2002 is offline   Reply With Quote
Old 04-01-2006, 09:49 PM   #6
spulinup
Member#: 63880
1998 Doom Wagon
swapped GF8 with jdm ish
You'll need a USDM pedal assembly. Preferably a WRX pedal assembly. Then check the forums to get the info on dealing with the auto lockout and how to re-wire it for manual.
spulinup is offline   Reply With Quote
Full V7 STi drivetrain into 04 WRX wagon! big_adventure Subaru Conversions 113 12-08-2012 04:53 AM
STi drivetrain into 07 WRX St3fan Newbies & FAQs 10 02-13-2007 12:58 AM
STi drivetrain into a wagon, couple of fitment questions. Einherjar Subaru Conversions 1 10-13-2006 04:32 PM
Swaping 05 Sti parts into GC8 body HELP! KY Archetype Southern California Impreza Club Forum -- SCIC 20 01-01-2006 04:44 PM
2.5rs (gc8) drivetrain into 93 impreza l fwd duratec Subaru Conversions 7 03-04-2005 12:33 AM
