Old 03-30-2006, 06:56 PM   #1
madmr2
Member#: 102334
Default How to tell if an engine is 2003 or 2004??
Hi,
I bought a swapped Impreza 93 with a WRX engine...
The guy told me it was an 03 engine/tranny but the car also has swapped interior/cluster and I realised it was from an 04.
Is there any simple way to be sure if my engine and ecu are from an 03 or 04???
I bought a TurboXS Unichip made for 02-03 thinking I had a 2003 but if I have a 2004, I guess I can't use it? I was able to plug it in and start the car... would it be possible if I have an 04 engine/ecu??
I think the ecu was modified in 2004 right?? open loop/closed loop is different and mbc is a big no... so it would not be safe to run this unichip I think??
Thanks
madmr2 is offline   Reply With Quote
Old 03-30-2006, 07:00 PM   #2
REX8
Member#: 24038
The unichip wont work with the newer ECU. Your best bet if the engine is an 04...
Sell your 04 ECU. Spent $100 on an 02-03 ECU and throw on your unichip.
Old 03-30-2006, 08:17 PM   #3
JRSCCivic98
Member#: 67080
Look at the plug on the turbo inlet hose towards the compressor side of the turbo. There is a plug there that has a harness connection on it and also a hose that goes to the the PCV valve. If there is a connection that also goes to the turbo inlet hose then it's an 04 engine. Also, the location/design of the PCV valve also changed in 04+ cars. The 04 cars have a PCV that screws into the block at about 3 o'clock position from the point described above. Good luck.
JRSCCivic98 is offline   Reply With Quote
Old 03-31-2006, 08:36 AM   #4
madmr2
Member#: 102334
Anybody know how to tell if I have a 2003 or 2004 ecu??
Old 03-31-2006, 09:52 AM   #5
JRSCCivic98
Member#: 67080
Look at the label on the front of it and post the numbers you see there. I'll tell you once I see them what it is.
Old 03-31-2006, 10:02 AM   #6
madmr2
Member#: 102334
My label is pretty much gone... is the number on the circuit board somewhere??
Old 03-31-2006, 03:51 PM   #7
JRSCCivic98
Member#: 67080
Nope... hook up a laptop with ecuExplorer on it and it'll tell you the ecu ID/map ID. That will at least tell you what revision it's flashed for. Other then that, there's no way to know AFAIK.
how to tell if sti tmic is jdm or usdm schiarelli General Community 12 11-03-2009 12:24 PM
How to tell if an EWG is working WReXd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-07-2008 11:59 PM
How to tell if an Accessport is unmarried or not? BlackDevil Newbies & FAQs 7 11-25-2007 01:32 AM
How to tell if an ecu is usdm or jdm? 2slofouru Subaru Conversions 4 08-11-2006 11:49 AM
How to tell if Helix Downpipe is V1 or V2? WheelsCSM Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-05-2003 01:34 PM
