Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-31-2006, 02:50 AM   #1
evoh8ter
Member#: 83071
2002 wagon
who knows
Default reflashed 4.2v to 5.0v now losing boost and other problems
i just reflashed my utec to version5.0 i did everything that it says to do when reflashing. I now an loosing boost as soon as it hits 45k. I just downloaded the base map thay they had on their site and did the new parameters. The car does not feel like it has as much pull to it. I have now noticed that i have a backfire while driving around with low rpms and i also have a hesititaion going into the higher rpms. I amgoing to call turboxs tomorrow and see if they can help, but any help on here would be great. I was thinking of getting on wrxhackers and checking if they had another base map with an up-pipe. If anyone knows what is causing the backfiring please let me know.
evoh8ter is offline   Reply With Quote
Old 03-31-2006, 09:52 AM   #2
WRX-Blue-Mica
Member#: 37938
02 WRX
Blue Mica
I just upgrade from 4.2 to 5.0 too .... but I got no problem with it at all .. the car run smoother & same A/F. .. better to double check all the parameter and maps .. check if ur car has new leak.
WRX-Blue-Mica is offline   Reply With Quote
Morette to HID and other problems SportyMark Electrical & Lighting 5 01-16-2009 06:58 PM
Loud clunk after launch and now its harder to switch gears and other problem elitescouter Newbies & FAQs 9 10-10-2007 11:17 PM
03 WRX no boost pressure and other problems Hatemachine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-24-2006 11:24 AM
New BOV now losing boost????? Stover954rr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-04-2005 07:57 PM
Unable to boost? And other issues eingram Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-27-2003 09:48 PM
