Old 03-31-2006, 11:40 AM   #1
fourstrokephysics
Member#: 92132
1997 OBS GFA
Default 03 WRX drivetrain ---> 97 OBS
Yep this here is the first subaru I have ever owned and for the past few weeks I have been working on improving it dramatically. A couple months ago, my weakened stock 2.2L drivetrain was starting to seem kind of rough after 150,000 miles. So I decided to do what any subaru owner with any sense of logic would do, I found a totalled 2003 WRX sedan. Now the entire drivetrain is in. The engine, trans, rear, all four brakes, hubs and axles that used to belong to the WRX are now completely installed into the 97 OBS. I had to switch out the pedal box, the hydraulic clutch reservior. And right now I am working on attaching the WRX dash crossbar so the WRX dash, cluster, and console will go in. I'm not running into many snags. The pedal box and the dash crossbar just needed a couple holes drilled into them. I also had to drill holes in the dash for the WRX heater box. Now I'm kind of trying to figure out what i should do about door panels, . but I might just cut them to clear the new dash until I can figure out how to install some different kind of door panel. also Im not sure if I'll have to switch out the fuel pump. Like I said, This is the very first modification I have ever even made to a subaru. And as soon as I can get this dash crossbar mounted, I can install the steering column, and then it'll be done. I don't even really have any idea how this swap is going to turn out. I've never even driven a WRX. Hopefully it will be done soon. I'll get pictures up soon. Let me know what you think of this swap.
fourstrokephysics is offline   Reply With Quote
Old 03-31-2006, 05:52 PM   #2
Natoe
Member#: 90353
Sold '95 22T Impreza
'99 EJ205 L, AE86 GVR4
sounds like your well on your way to a sucessfull swap. good job gettin after it. you will want the fuel pump, and since you have it its not too hard to put in.
have you done all the wiring? there will be some body wiring you may have to adapt to the wrx ECU. your car will be way faster than you think ride in a stock wrx, then subtract 300lb.
Natoe is online now   Reply With Quote
Old 03-31-2006, 08:13 PM   #3
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
Haha.
"Have you modded your car?"
"Yea. I've done one little thing."
"Yea? What's that?"
"Oh, just a complete WRX drivetrain swap."
That's sweet.
bl_easy is offline   Reply With Quote
Old 04-01-2006, 08:45 AM   #4
Rally_wgn
Member#: 62629
1996 OBS in Green
2.5 N/A w/ full exhaust
That's impressive... I think I'll mod my OBS hmm... lets throw in a WRX drivetrain and see if that improves the power...
I'd like to see pics to the dash swap.
Rally_wgn is offline   Reply With Quote
Old 04-01-2006, 12:38 PM   #5
euroteknic
Member#: 57446
97 OBS EJ20/ E30 M3
yeah, my OBS is in need of a drivetrain swap as well. I have the WRX suspension and brakes on but I could use a bit more power...
euroteknic is offline   Reply With Quote
Old 09-06-2012, 12:30 PM   #6
NW_OBS
Member#: 302064
1997 Impreza OBS
white
Default sounds sweet!
what year is your OBS??? I have a 97 2.2 OBS and I am wish I could find a salvagable wrx for cheap, but... I live in Seattle area and finding that is like a royal rumble, everyone is looking for it too!! how much did you pay for everything? I want to lift my OBS too though, using the forester shock/struts and throw some 215/75/15 mud terrains under it, i have seen it. That and a WRX powertrain, oh man, it would be bad ass!!
Lets see some pics!
NW_OBS is offline   Reply With Quote
93 legacy turbo -> 97 OBS fallout Subaru Conversions 1 08-23-2006 05:12 AM
WRX coilovers to 97 obs ncskier96 Subaru Conversions 3 07-13-2006 10:47 AM
03 USDM EJ20 -> 97 JDM EJ20 swap marksWRX03 Subaru Conversions 10 06-09-2004 08:13 AM
FS. Rally Car Project. -- 95 Impreza shell + 03 WRX drivetrain 6500 miles Greg555 Private 'For Sale' Classifieds 13 03-19-2004 01:18 PM
03 wrx drivetrain parts (tranny etc.) liberty2000rs Private 'For Sale' Classifieds 22 02-25-2004 03:15 PM
