Old 05-17-2000, 08:58 AM   #1
94Leg
Member#: 1475
Post Legacy-Impreza Compatibility
There has been some chat within the suspension threads recently about Legacy and Impreza compatibility of struts...at least for later model Legacy's
I noticed when I purchased my KYB GR-2's a couple months back, the struts (for 93-94 Leg.) shared the same part number with the Impreza units. Anybody want to confirm if current suspension packages (KYB, Tein, Bilstein, LEDA struts with Eibach, Groundcontrol, H&R springs) designed for the Impreza will work for an earlier model Legacy (granted I chose an appropriate spring rate)?
Also, I'm assuming an RS tranny would drop right in should and when my current transmission goes...correct? Or should I then consider a new car....(RS)?
-Jason
94Leg is offline   Reply With Quote
Old 05-17-2000, 09:25 AM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
we've touched on the suspension topic before...
for sure.. the KYB/AGX part #s for the impreza/legacy are the same... same... same... so i imagine MOST (key word) of the suspension parts are compatible. you will find a lot of the part numbers are the same.
both of the later model cars have the same 2.5 engine...
Old 05-17-2000, 03:16 PM   #3
94Leg
Member#: 1475
Post
I guess I am going nuts...I interpreted the last compatibility conversation between the Impreza and the 95-99 Legacy...I unfortunately have a 94 Legacy and the struts from later model Leg's are not compatible. Right? Or are the different part numbers claimed by KYB actually referring to the same part?
Regardless of the 2.5L shared between the Impreza and the later model Legacy's, I am going to assume from your statement that any Impreza tranny will bolt right into a 94 Legacy...
(I'm playing dumb here because it has been a pain in the butt to find anything for this MY let alone anyone who knows the right info...)
-JV
Old 05-17-2000, 03:19 PM   #4
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
ok... well...
if you want KYB's.. i can get you the part #'s... the #'s for the Impreza should be the ones you want... i called KYB myself and talked to their techs and have them installed on my car right now so i know they work!!!
as for the engine... i am not for certain that it WILL indeed fit in a 94 - but 97-00 are swappable... someone will have the answer for you though... i don't want to mis lead you...
Old 05-17-2000, 03:32 PM   #5
94Leg
Member#: 1475
Post
Thanks...all's good.
BTW, I know the engine will match up without a problem, but I'm wondering about the tranny mounts...
Somebody...anybody...(sigh)
Old 01-16-2005, 05:10 PM   #6
jamesohoh7
Member#: 39070
GTF off my lawn!
NM.. wrong thread.
jamesohoh7 is offline   Reply With Quote
Legacy/Impreza Suspension compatibility Pwise2326 Brakes, Steering & Suspension 5 05-02-2012 06:23 AM
Legacy engine compatibility EricScott Legacy Forum 3 11-07-2009 11:46 AM
Turbo legacy ECU compatability? serious Pre-2002 Factory Turbo Powertrain 13 11-14-2005 07:32 PM
Legacy Tuned by STI; Legacy/Impreza WR-Limited; Impreza Type RA flyinpig News & Rumors 92 08-25-2005 12:35 AM
Legacy...Impreza...Legacy...Impreza...Integra... SubieKidTK Legacy Forum 13 07-09-2001 05:57 AM
