Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Old 10-01-2001, 04:22 PM   #1
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Default Stock Spring Rates For 99 Legacy GT?
Does anyone know what the stock spring rates are for a 99 Legacy GT?
Brad
MY99 2.5GT is offline   Reply With Quote
Old 10-02-2001, 01:41 PM   #2
CRAZY KEN
Member#: 1176
2012 Legacy GT Ltd
Pearl Statin White
Default GREAT QUESTION
BUMP
I would like to know too!
CRAZY KEN
CRAZY KEN is offline   Reply With Quote
Old 10-02-2001, 08:45 PM   #3
BG5
Member#: 695
wagon or sedan? IIRC the wagon is roughly 145/128 lbin F/R though don't quote me on those exact numbers... It's not that far off from the STi / Prodrive spring rates for these Legacy's. Sedan will have slightly higher rates in the rear.
BG5 is offline   Reply With Quote
Old 10-03-2001, 02:50 AM   #4
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default why....
would the sedan be HIGHER in the rear than the wagon? Isnt the wagon heavier in the rear?
subysouth is offline   Reply With Quote
Old 10-03-2001, 09:25 AM   #5
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
I have a sedan.
I bought a set of Ground Control springs where I was able to pick my rates. I told him I wanted 250/225 f/r. When I told him that he said wow that is aweful close to stock. He then recommended I go with 315/280 f/r. When I put these on my car I was very dissatified with the ride qaulity. Ever little bump jars the car and make it bounce. I got sick of it and order a set of 250/225.
Do you guys think this will solve my problem? I am also switching to a set of FHI Ver 5 struts. The KYBs just don't perform well when lowered past 1" below stock.
Hopefully this will cure my problem.
Brad
Old 10-03-2001, 10:13 PM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
The guy's on drugs. I don't know what the spring rates are exactly, but they more in the ballpark of what BG5 posted. I know my DMS Golds (225f/180r) are noticeable firmer than stock, so stock is nowhere near 250f/225r.
I have an Excel spreadsheet that I got from someone here on the board who was compiling spring data. His spreadsheet says a '99 GT wagon is actually the opposite of what BG5 posted - 128.5front/139.5rear. As I recall he actually had his springs tested.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 10-04-2001, 12:02 AM   #7
rallysquirrel
Member#: 7006
2007 SpecB
Default Ride heights (floor to wheel arch)
---------FRONT---- REAR
97 OB 730mm----720mm
97 GT 667mm-----657mm
Thanks to http://www.geocities.com/limeylight/handling.htm
rallysquirrel is offline   Reply With Quote
Old 10-04-2001, 10:56 AM   #8
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Cool Patrick.
I am encouraged that you have DMS golds with lower rates than GCs.
Do you like them?
I will get the new 8"ers 250/225 put on and see how they feel. This guy at GC kept telling me how he knew of RSs out there with rates of over 400 blah blah. I will let you know how my new set does.
Brad
Old 10-04-2001, 06:00 PM   #9
BG5
Member#: 695
Pat, that was me with the spreadsheet which I lost 3 computers ago... I rated H&R's, Prodrives, my 99GT Wagon springs, and
springs off a 95L Wagon.
In summary, you won't find 'drop-in' springs higher than about 200lbin and even in mad-mad rock-hard Japan, the majority of coilover setups over there don't tend to be more than about 225-275 lbin.
The RS is 157/149 so I still don't understand what the guy at GC was talking about with rates being too close to stock
Old 10-04-2001, 11:34 PM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
If you search for my name on the Suspension Forum, you'll find plenty of feedback about my DMS experience. They were recently rebuilt (under warranty) and I reinstalled them a week ago. All the problems I had with initially are gone, the car rides great and really does handle amazingly well. I now have a new problem (camber issues) which I still need to work out with Dave Clark.
Pat
Old 10-05-2001, 10:35 AM   #11
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Pat-Did you get the camber plate mounts when you bought the DMSs?
Do you find that you need to get an allignment every time you adjust height?
I wonder if the 250/225 setup will still be a little stiff?
I am very glad to here you guys are running great on significantly softer springs. The ride qaulity of the 315/280 sucks.
Brad
Old 10-05-2001, 10:48 AM   #12
froggert
Member#: 768
OB, legacy, 911,
ram 1500, 1098s, m620
brad, could your setup have been under or overdamped? i'm running spring rates significantly stiffer than 315/280 and the ride doesn't seem as bad as your description. if i soften the damping even 1 click, though, the car can get floaty/bouncy. it may be a matter of properly matching spring rates and damping.
roger
froggert is offline   Reply With Quote
Stock ECU for 99 Legacy GT 5 speed boxorox Private 'For Sale' Classifieds 1 08-22-2004 02:12 PM
Stock Spring Rates for 97-99 Legacy GT? MY99 2.5GT Legacy Forum 2 03-28-2002 09:17 AM
What is the Spring Rate for the Legacy H&R Sport Springs MY99 2.5GT Brakes, Steering & Suspension 5 06-19-2001 10:01 AM
Stock spring rates for a Legacy sedan, anyone? Patrick Olsen Brakes, Steering & Suspension 0 12-30-2000 08:05 AM
does the legacy L have a different spring rate then the legacy GT? iceman Legacy Forum 2 11-18-2000 07:17 PM
