Old 03-31-2006, 09:24 PM   #1
Parsons
Member#: 65688
2001 junkyard heap
Black/dirt
Default Swap problem - dash shorted.
Alright I had a shop do my swap, I don't know much about swapped cars myself, but I really don't want to drive it back to another shop, its already been 16 months in waiting.
So I got a 2004 wrx motor swapped into my 01 2.5 RS. I've probably put 300 +/- miles on it since the shop finished with it. Car runs fine, boosts fine, idles fine, basically just the way I want it.
Today I am driving around and my speedo and revs bottom out to 0. I stop my joyriding and bring it back to my house. I notice that when I use my directionals, they work on the outside of the car, but don't show in the dash. But if i turn my hazards on the lights work in dash.
I go to put my windows up and close the sunroof, they also don't work.
I also get no CEL when I first turn the car on or ever, so I am not sure if its even connected. Also that useless display on the dash (has temp, direction of travel, alititude and what not) hasn't worked since I got it back. Not that I ever use it, but that might help someone.
What shorted out on me? A fuse pop? Wires disconnect? I am not really sure where to start on this, but I really need some help. If anyone has some advise on why this is I would appreciate it.
Parsons is offline   Reply With Quote
Old 03-31-2006, 10:35 PM   #2
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
probably a fuse.
always the first thing to check.
Hurley 2.5 WRS is offline   Reply With Quote
Old 04-01-2006, 08:42 AM   #3
MysteriousXTC
Member#: 66771
93 L w/ V4 STi RA
Strange as it may sound my MY00 did the same thing, often times it would drop the speedo and tach to 0 and everything would just die inside the car... I replaced the altenator and everythign returned to normal... Dont know if this is your problem or if an altenator would fix it, I certainly didn't believe it would fix mine, cause an altenator is a fairly good chunk of change, maybe a belt first... See if you can turn the car on now and see if the gauges work, if so its not a fuse, rather a fusible link?
MysteriousXTC is offline   Reply With Quote
Old 04-01-2006, 09:22 AM   #4
sidewayz
Member#: 5810
2001 S366 2.5RS
low voltage.. has to be. check your battery
sidewayz is offline   Reply With Quote
Old 04-01-2006, 03:43 PM   #5
Parsons
Member#: 65688
2001 junkyard heap
Black/dirt
Default Thanks
The battery is brand new and the altenator (as well as the rest of the engine) has less then 5000 miles on it, so not sure if that would be gone already.
I don't think low voltage would short out just those specific things, as everything else works fine all the time.
Old 04-01-2006, 03:52 PM   #6
sidewayz
Member#: 5810
2001 S366 2.5RS
does the car start and run now? if not, the main relay power wire might have gotten fudged up.
Old 04-01-2006, 03:57 PM   #7
MysteriousXTC
Member#: 66771
93 L w/ V4 STi RA
low voltage can do some weird things... but its probably just some loose connection somewhere... fun part is finding it, G/L
Old 04-03-2006, 09:58 AM   #8
Parsons
Member#: 65688
2001 junkyard heap
Black/dirt
Default even worse now.
ok I figured what fuses were blown and replaced them. Drove it another 15 mins or so and the same fueses went again.
So I drove it home to park it and try to figure it out with the shop that did the work. On my way home I noticed that when I got to about 2-3k rpm (by ear, dash didn't work) the car would bog down real bad. I was going up a hill, downshifted to 4th and no throttle response. I coasted to the side of the road, turned it off and popped open the hood to see if anything was strange. Nothing. Went to start it again and all I get is clicks. So my battery was dead.
Called a friend to jump me. We jumped it, went about 100 feet and it died again. Now it wont start at all, I figure my battery is dead. Again, battery is brand new and engine has <5000 miles on it.
The fuses that popped every time were:
10amp Tail clearance (dash fuse box)
15amp turn back srs lamp (dash fuse box)
and the last time the 20amp lighting sw (engine bay fuse box)
Anyone? I figure my only choice now is to get it towed back to shop and have them fix whatever wiring problem they caused when they did the swap.
Problem is its getting inspected by a DoT officer in the next couple weeks for my salvage title. If it doesn't run, I am screwed. (although they are only inspecting the body repair AFAIK)
Old 04-03-2006, 06:56 PM   #9
sidewayz
Member#: 5810
2001 S366 2.5RS
I would try a new batt first. most of the fuses you listed have nothing to do with the swap.
Old 04-03-2006, 08:35 PM   #10
Gator GT
Member#: 37190
07 specB - 6spds,
4 tips, 3 LSDs, stg 2!!!
try your grounds. make sure they didn't skip any grounds or install them in less than desirable locations (plastic or sub-frame; instead of directly to chassis)
having less than the required (or designed) amount of grounds will always play with you.
GGT
Gator GT is offline   Reply With Quote
Old 04-03-2006, 11:42 PM   #11
Ds baruuuuu
Member#: 4724
01 01RS
brp
if you jumed it and it died like that sounds like your alt isnt charging check the wiring to the back of the alt and if thats good just take it out and checkers will test it i believe
Ds baruuuuu is offline   Reply With Quote
Old 04-04-2006, 09:39 AM   #12
Parsons
Member#: 65688
2001 junkyard heap
Black/dirt
My car doesn't know what it wants to do.
Yesterday I replaced all the fuses again, jumped it and let it run for about 20 mins. Then I drove it for about 30 miles without a problem. Only thing is my directionals weren't working the whole time.
Everyday its something different, I don't understand it.
I guess I need to check grounds next.
Old 04-05-2006, 09:08 PM   #13
Parsons
Member#: 65688
2001 junkyard heap
Black/dirt
Anyone?
Is there any way I can test which wires/grounds are causing the problem? I can't just look at this mess of wires and know what to check. I have pretty limited knowledge of this subject, hence the reason I brought it to a shop to do the swap.
10amp Tail clearance (dash fuse box) Is currently the only fuse that is burning out on me, all my other fuses are fine.
Also my heads up display (the stock one in the RS dash) and CEL aren't working/getting power.
Single DIN to double DIN aftermarket swap, needs dash kit? scott.olson Car Audio, Video & Security 4 04-16-2010 04:42 PM
sti swap with dash.... no need to merge harness? reality1011 Subaru Conversions 5 07-18-2006 09:48 AM
Swapping complete dash of USDM WRX/Forester into 98-01 Legacy ? Legacy Subaru Conversions 0 03-27-2005 07:34 AM
sti swap, need dash w/ everything, and pedals orangescooby Private 'Wanted' Classifieds 0 03-26-2005 03:08 PM
v7 swap and dash circuit svxtrem Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-08-2002 10:54 AM
