Old 03-31-2006, 10:53 PM   #1
downtown23
Member#: 72508
05 WRX
Black Pearl
Question Target Boost Question
Would running a cat-free TBE affect my Target Boost while running AP Stage 2. I've heard cat-free affects back pressure and wasn't sure if that would also affect hitting TB. Would like to see you what you guys thought before running the HWG map. Not too worried about being 2 psi away from TB but would be nice to hit the mark.
James
downtown23 is offline   Reply With Quote
Old 04-01-2006, 12:14 AM   #2
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
You want as little back pressure as possible on a turbo car. Having restrictions (e.g., a cat) will prevent you from hitting target boost. However, if you have a high-flow cat, it shouldn't place much restriction at mid to high end and won't affect the target boost much.
Also, 0.2 PSI below target boost is ok, but 2 PSI is A LOT! for 02-05 wrx the stock boost level is 13.5 PSI and the AP stage 2 target boost level is 15.8. If at stage 2 you are 2 PSI below the target boost, then there's something seriously wrong with your car or setup.
sandwi54 is offline   Reply With Quote
Old 04-01-2006, 12:53 AM   #3
downtown23
Member#: 72508
05 WRX
Black Pearl
Do you think adjusting the wastegate actuator arm would help at all? Or is that more for getting rid of the flutter sound and boost spike.
Old 04-01-2006, 12:58 AM   #4
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
Could you tell me what mods you have on the car first? What boost level are you hitting?
Old 04-01-2006, 01:00 AM   #5
downtown23
Member#: 72508
05 WRX
Black Pearl
TBE, Uppipe, Headers, Drop-in Filter, Snorkus Delete, AP Stage 2, Intercooler Hoses
Old 04-01-2006, 01:01 AM   #6
downtown23
Member#: 72508
05 WRX
Black Pearl
And I'm hitting just over .09 mpa which I believe is around 13.5 psi
Old 04-01-2006, 01:12 AM   #7
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
I am not sure if AP stage 2 can take headers but other people can confirm that. Did you check for any leaks? A leak especially in the uppipe may prevent you from hitting the target boost. What TBE are you running?
Old 04-01-2006, 01:15 AM   #8
downtown23
Member#: 72508
05 WRX
Black Pearl
I can triple check but last time I checked I didn't have any leaks in the setup. Perrin DP and Borla Hush CB
Old 04-01-2006, 01:25 AM   #9
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
That's weird. Are you reading from the AP live boost or your boost gauge?
Old 04-01-2006, 01:29 AM   #10
downtown23
Member#: 72508
05 WRX
Black Pearl
Boost gauge, I haven't tried using my AP yet.
Old 04-01-2006, 01:34 AM   #11
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
Try with your AP cuz that's the most accurate reading. It's what your ECU sees. Your boost gauge could be off.
Did you just put the TBE on and went to stage 2, or have you been at stage 2 for a while and just noticed the boost drop?
Old 04-01-2006, 01:38 AM   #12
downtown23
Member#: 72508
05 WRX
Black Pearl
Well....I did the mods at the same time and it was last summer but I never really new how to convert my gauge to psi so yeah it's been awhile but the pressure has always been the same since install
Old 04-01-2006, 01:41 AM   #13
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
I see. Yeah check your AP live boost reading and see if you still only get 13.5 PSI. Oh by the way, how were you checking your max boost? what gear were you in and were you going at WOT?
Old 04-01-2006, 01:47 AM   #14
downtown23
Member#: 72508
05 WRX
Black Pearl
I wouldn't think of checking it until at least 3rd. But I would usually check it WOT in 4th or 5th. I would punch it until the boost stopped going up.
Old 04-01-2006, 01:50 AM   #15
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
OK at least you checked it the right way. Well I guess there's not much we can do until you read the live boost from AP. One thing though, did the car feel faster? Stage 2 and stock are completely different cars.
Old 04-01-2006, 01:55 AM   #16
downtown23
Member#: 72508
05 WRX
Black Pearl
I went from stock to Stage 1 to Stage 2 and yes it felt faster everytime. It was confirmed by the buttdyno.
Old 04-01-2006, 05:21 AM   #17
NorthCoastWRX
Member#: 99176
04 WRB STi Stg II
[email protected]
I did the wastegate actuator mod to get near target boost on Stage 2. It also helped quiet the flutter, and the car is a totally different animal. It was very easy, just watch your boost carefully for spikes. I used my AP and seen a high reading of 15.7 lbs.
NorthCoastWRX is offline   Reply With Quote
Old 04-01-2006, 12:33 PM   #18
flyKen74
Member#: 82092
04 very slow WRX
Dirty PSM
same setup on mine + Perrin turbo inlet. I'm hitting 16.5 psi..just adjust ur waste gate about 1 and 1/2 turn..
flyKen74 is offline   Reply With Quote
Old 04-01-2006, 10:23 PM   #19
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
Did you get a chance to read your AP live boost? If it really is 13.5 PSI then you can try adjusting the wastegate like the previous two posts suggested.
Old 04-02-2006, 02:27 PM   #20
downtown23
Member#: 72508
05 WRX
Black Pearl
My boost guage was correct so I shortened the WAA two turns and I was hiting 16.3psi.
Game on baby
Old 04-02-2006, 09:13 PM   #21
sandwi54
Member#: 94532
2005 WRX SRR
Cobb Stage 2
Cool i am glad it worked out.
Old 04-03-2006, 12:25 AM   #22
EAkrish
Member#: 108617
2003 WRX
Yellow
can someone post how to adj ur waa please?
EAkrish is offline   Reply With Quote
Old 04-03-2006, 11:59 AM   #23
downtown23
Member#: 72508
05 WRX
Black Pearl
I found it by searching for Wastegate Actuator Arm Adjustment.
Old 04-18-2006, 04:18 PM   #24
ALaDDiN
Member#: 98294
2004 Honda Civic
2006 Acura TL
How do I determine how much to adjust the arm ? ?
ALaDDiN is offline   Reply With Quote
Logged target boost does not match target table cava23 Engine Management & Tuning 16 06-01-2010 12:21 AM
2006 wrx VF39 target boost question thadd677 AccessPort 1 08-04-2008 07:16 PM
Question about not hitting target boost bl0wnb0xerbabiE AccessPort 14 09-28-2007 09:54 PM
question about AP cal 91 oct map and target boost (possible problems) bubba03wrx Engine Management & Tuning 3 03-08-2005 05:12 AM
Cobb stage 2 target boost question MO REX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-27-2004 02:59 PM
