Old 04-01-2006, 01:08 AM   #1
wrx17psi
Member#: 111223
Default idle help
i got an 03wrx, invidia turbobackexh., coldair intake, stage2 clutch, and if your driving around for a couple hours it will idle normal but then after awhile it will idle up between 1200-1600 and the only way it will stop is if you tunr the car off for about 5min and ideas?
wrx17psi is offline   Reply With Quote
Old 04-01-2006, 03:49 AM   #2
dj_booduh
Member#: 70861
2005 Scoobie WRX
I don't have an intake, but I am willing to bet that might be the root of your problem. esp on th stock ecu the intake can be hell on the ecu. Maybe it is forcing the engine to adjust. Just throwing out ideas. Does anyone have any intelligent input as I am now spent.
dj_booduh is offline   Reply With Quote
Old 04-01-2006, 04:18 AM   #3
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
You might read up on the IACV - idle air control valve. Sometimes they can get dirty and will cause such problems as you mention. There's a nice long thread on it, somewhere.
specialev is offline   Reply With Quote
Old 04-01-2006, 07:16 AM   #4
wrx17psi
Member#: 111223
thanks for the help
Old 04-01-2006, 08:00 AM   #5
F3nrir
Member#: 62612
2004 WRX
BMW Silver Grey Metallic
Ive got the same problem, only happens during especially heavy traffic(lots of low gear and clutch work), and it can jump up to almost 3k at idle. So your not the only one whose noticed something like that.
MY04 wrx
BPM Turboback
Cobb Accessport Stg2
F3nrir is offline   Reply With Quote
Old 04-01-2006, 08:31 PM   #6
affinity1
Member#: 97266
'15 Forester 2.5i
Touring DGM
i have the same problem on my stock 03
affinity1 is offline   Reply With Quote
Old 04-02-2006, 05:58 AM   #7
wrx17psi
Member#: 111223
highest mines been so far is 2200
Unstable idle idle help.. WRXBob Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-10-2008 08:55 AM
high idle!!!! now choppy idle help! Thran Newbies & FAQs 18 02-22-2007 10:12 PM
high idle, now low choppy idle?!?! help Thran Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-17-2007 12:44 PM
Very rough idle...HELP! bouse1 Normally Aspirated Powertrain 1 08-10-2001 03:15 PM
ruff idle.......HELP! NateDogg Normally Aspirated Powertrain 7 05-27-2001 12:59 AM
